1980 KZ 1000 B4 LTD 1327 Build
- Powerstroke_fan
Re: 1980 KZ 1000 B4 LTD 1327 Build
24 Sep 2012 17:19
are you running a busa front end? O i was told the rear hub would have to be machined. I guess ill know for sure once its mocked up.
1977 KZ 1000 work in progress
- 4TheKZ1000
24 Sep 2012 17:35
Looks like a nice ROCKET build in the making....good start....good luck!
- JEFFG1
24 Sep 2012 17:48JEFFG1 wrote: not sure what you me by frt.end as far as the hub i took nothing off of it and the chain has never hit the tire but i had my swingarm made for me. all i had to do was dent the frame about 3/8th. if you run a offset sprocket you will have to hog out the inside of the cover that covers the frt.sprocket my tire also sits in the center of the bike it is not offset to the right have put alot of miles on the road and the strip so it is done rite no problems at all.[/quote its a stock frt, with a gsxr wheel and marauder brake disc. and calipur
1976 KZ 900 PRO STREET 1977 kz1000 dragbike project
- JEFFG1
24 Sep 2012 17:50
i dont know what just happened but it is a stock kz frt. gsxr wheel marauder cal. @ disk
- Powerstroke_fan
24 Sep 2012 18:47
so what year and model gsxr? And does it bolt right up with stock kz axle bolt? Does the disks bolt right up to the rim? Sorry for so many questions. I really want to update the front end also.
- rich67
24 Sep 2012 19:37 - 24 Sep 2012 19:48
Here's how i provided clearance also i would go with the 530 chain , modern 530 chains are lighter and just as strong as old 630 chains . also gsxr rims will not fit kz axle's,but just about any thing can be made to fit with a little effort
. I really like the start of your polishing.
Last edit: 24 Sep 2012 19:48 by rich67.
- Powerstroke_fan
24 Sep 2012 21:49
Thanks, its alot of work polishing i worked on it alot more today. But usually just little day by day. Ya i didnt know how jeffg1 did it. Iam looking to run a gsxr rim or rim to closely match the rear busa rim and i hear the handling and stopping abilities are greatly improved. I was just trying to see what all goes into it so i can decide the best route to go about it. I will have the frame notched while its apart. to allow for the chain. Got the change going out tomorrow morning for the pistons. Cant wait to get the parts back. Even tho i still got alot to do.
Anyway i have been looking into lock up clutches. I see Joe at pitstop sells a two stage snowflake lock up for a reasonable price. Even includes the labor of installing the buttons. Anyway how does everyone check there oil level with aftermarket cover? I think i would see if theres a way to install a sight glass. But then again i got a oil cooler that will be going on there. So a sight glass might not do any good. I was looking before when i bought the cooler at summit racing and they had check valves that open at 2 psi. Think those would be safe and efficent in keeping the oil in the cooler while the motor is off allowing you check the oil level via the sight glass? I know iam rambling just a few ideas running thru my head. You know how it goes
- Powerstroke_fan
24 Sep 2012 22:20
Here is a couple pictures of some of the stuff i already have.
Heres the oil pressure guage i got that i wanna get hooked up. And a few of the fittings i will be using.
Here is how the motor looks now. I still got more to go but its coming along.
Attachment IMG_0295.JPG not found
Attachment IMG_0296.JPG not found
Attachment IMG_0298.JPG not found
Attachment IMG_0297.JPG not found
Attachment IMG_0301.JPG not found
- les holt
25 Sep 2012 17:14
I bought one of Joes MTC lockups, machined it to take the sight glass, no biggie but did have to open up some of the bolt holes, it wouldn't bolt up the way it came. No fault of Joes, MTC's doings.
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- Powerstroke_fan
22 Oct 2012 16:24 - 22 Oct 2012 16:40
So yesterday i broke down and bought alot more parts. Spent over $500 on stuff. Bought mtc two stage lock up from pit stop, New stock clutch fibers and springs. rear busa caliper and bracket. Aluminum 1000 J cam end caps. I got some other stuff also just cant remember what all i got. Anyway i am ready to order a new REAR sprocket for my new build and i am wondering which will be the best size to go with? This bike will be street ridden. I dont want it reved out at 55 or 60. I will be getting a special sprocket made so i want to get the right size first time round. Currently iam running a 39 tooth on the rear. I thought about stepping up one tooth? I think iam running a 15 on the front but not sure.I will discuss front sizes later when i get to that point. Anyway iam taching about 4.5g at 55 if i remember correctly. Would like to get it down a bit yet still have some bottom end power also. so what does everyone think will be the best size?
Last edit: 22 Oct 2012 16:40 by Powerstroke_fan.
- mark1122
- Keep twisting it
22 Oct 2012 16:44
it's best to wait until u get the rear tire mounted and measure from there. u will need a 1/2" to 5/8" offset. no need for a custom sprocket. u can get them off the shelf from D&G and others. i have a spare 5/8 x 16 x 630 if u need 1.
i heated the inner frame rails and squeezed it in with a large C clamp to gain chain clearance, and had the rear hub milled as well.
u should think about more crank case venting and a Honda 900f starter for more cranking power, also a sprocket support plate. i needed that stuff for my 1327, and 1200.
i went through all of this in my build thread.
have a look here. it may have some info that can help u.
kzrider.com/forum/11-projects/103381-76-kz900-upgrade
just holler if u need an explanation.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Powerstroke_fan
22 Oct 2012 17:01
The sprocket iam discussing will be on the rear and i have looked for a 630 busa rear sprocket but cant find any but found websites that make them. I am having les mill the rear hub for me as we speak. I have debated on the starter i know i will probally need one. Havent ever heard about more crankcase venting? I will look into that.
