'76 KZ900 (ZRX1200R) Build
  • NakedFun
  • NakedFun's Avatar Topic Author
Re: '76 KZ900 (ZRX1200R) Build
18 Jun 2013 14:35
#592888
So on Saturday while waiting for a potential buyer for our RV, I got to spend some hours working on the KZ. First off, I fitted the cover and belt drive for mock up.
[IMG
[IMG
Then fitted a little bling....
[IMG
Then rough cut the center out oof my Harley Cush Drive.
[IMG
Then using my brother's new lathe, turned it and trued it in prep for my collar and sprocket.
[IMG
Then turned my attention to putting on and fitting all the D&G Chassis motor mount stuff. Started with the front mounts.
[IMG
Then the rear chromemoly mount. Which eliminated the old mounts which had the battery box brace tabs. So I jigged the battery box in place and cut the brace down to a minimum and welded it into the new motor mount once in position. then cut down the old long bolt and rethreaded it.
[IMG
Then decided I ddin't like how my current location for the rear brake master resivior got mounted, so I decided to move it to behind the side cover. Made a new bracket and welded the bracket to the battery box. Came out nice I think.
[IMG
[IMG
Finished up by adding my last brace to the exhuast hanger mount.
[IMG
Then used my bro's lathe again to make some special bushings and my alternator stand off as can be seen on the RH side of the pic.
[IMG
Well, that is all I got done, not much. It will be a couple of weeks before I can do more as I will be out of town on vacation. Hopefully my wheel will be back and I can get that fitted up!
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
18 Jun 2013 15:35
#592892
Wow, that guy must have been really late! :lol:
Looking great!
The Kaw List:
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
18 Jun 2013 15:46 - 18 Jun 2013 15:47
#592893
Looking at your remote alternator, I was reminded that there are some shots of a cool setup like that in the documentary "Z1: The Movie".
I believe the bikes with this setup are all Egli built bikes. I can't find any pictures that exactly match what I remember seeing, but here are some examples of Egli remote alternators.
Maybe someone who actually remembers where they put their copy of the DVD can take some screen shots...
My dad's '74 Z1
'00 ZRX1100
Last edit: 18 Jun 2013 15:47 by DOHC.
  • NakedFun
18 Jun 2013 16:12
#592903
Cool pics! So far all the belt drives I have seen are one off's and most don't keep the electric starter operable. I wanted to keep the starter in tact. Did have to order a different belt as one was really too long and one was too short for where so want the alternator.
Cory
1976 Kawasaki KZ900
  • DOHC
  • DOHC's Avatar
18 Jun 2013 16:33
#592905
NakedFun wrote: I wanted to keep the starter intact.
I think I could live without the electric start, but I haven't actually tried. Those stupid batteries are always on the edge of dead anyway, so I frequently end up pop starting the bike.
I've been wondering if it would be possible to fit the alternator from a ZX11 or possibly the similar Suzuki Katana units down into the recess for the KZ1000 starter motor.
These alternators looks to be a bit larger in diameter than the starter, but might be close enough? They are smaller than an automotive unit anyway.
My dad's '74 Z1
'00 ZRX1100
  • NakedFun
18 Jun 2013 16:55
#592908
I think finding a way to drive them with gears would be the most difficult challenge of using them in place of the starter. My kick start is deleted as it would not work with my pegs from Les.
As far as alternator size, this is a permanent magnet alternator with built in regulator so it is a simple 2 wire hookup and self regulating 40 amps come out... Also has the option for a failure light with a third wire. Much cleaner, reliable charging system IMHO. I am building my own electrical system since I really enjoy designing and fabricating that stuff.
Cory
1976 Kawasaki KZ900
  • Hollywoodmx
  • Hollywoodmx's Avatar
18 Jun 2013 22:43 - 18 Jun 2013 22:44
#592980
79MKII wrote: Wow, that guy must have been really late! :lol:
Looking great!
AHhaha! :lol:
Hey Naked are you putting a cover on it? It looks like the belt is right where your lower part of your leg will be. With the SC cover of my bike it's dangerous for the same reason, it was rubbing on my jeans even when I was trying to avoid it..
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 18 Jun 2013 22:44 by Hollywoodmx.
  • NakedFun
19 Jun 2013 00:27
#592994
Kind of a guard.... Lol
Cory
1976 Kawasaki KZ900
  • NakedFun
30 Jun 2013 00:32
#594404
Buchanan's sent my reworked wheel back... Getting closer....
[IMG
Cory
1976 Kawasaki KZ900
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
02 Jul 2013 11:28
#594704
sweet!
  • NakedFun
24 Jul 2013 11:40
#598053
Quickie Update... Almost finished the belt drive alternator. May machine an additional brace for the main pivot bolt and FINALLY got the right belt. Machined up a custom turnbuckle for setting tension.
[IMG
[IMG
No onto the wheels... Since I ended up trying a different hub, now I need to machine .385" off the hub to get the cushdrive into alignment and need a big lathe for that swing....ugh! May have to disassemble and the reassemble the rear wheel... what a PITA!
Cory
1976 Kawasaki KZ900
  • StreetfighterKz
  • StreetfighterKz's Avatar
24 Jul 2013 15:11 - 24 Jul 2013 15:11
#598084
Cory,
Your project looks great! I like the innovation you're putting into it.
Now, I just need to hop back over to my 900 project since you've given me some inspriration. I've drug it out way too long...
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 24 Jul 2013 15:11 by StreetfighterKz.
