Canadian KZ305 LTD
  • ecannon
  • ecannon's Avatar Topic Author
Canadian KZ305 LTD
20 May 2012 12:40 - 20 May 2012 14:37
#523539
Brrrrat! That's my thoughts anyway. Picked up this little baby on Friday and yesterday spent about 4 hours pulling bits and pieces off and setting how it looks underneath!
Plans are, move rear set to passenger peg position, crop frame just behind rear shocks, new seat, tank, brakes, some clip ons and new paint. I'll post up some pics when I get home.
Daily
2004 Suzuki SV650
Project
1981 Kawasaki KZ305 CSR
Last edit: 20 May 2012 14:37 by ecannon.
  • Krazykz
  • Krazykz's Avatar
Re: Canadian KZ305 LTD
20 May 2012 17:18
#523585
Don't forget to post some pictures
  • ecannon
20 May 2012 22:38
#523670
Attachment uploadfromtaptalk1337564145835.jpg not found
Attachment uploadfromtaptalk1337564164591.jpg not found
Attachment uploadfromtaptalk1337564189979.jpg not found
Attachment uploadfromtaptalk1337564221428.jpg not found
Attachment uploadfromtaptalk1337564238184.jpg not found
Daily
2004 Suzuki SV650
Project
  • ecannon
20 May 2012 22:40
#523671
Attachment uploadfromtaptalk1337564270570.jpg not found
Attachment uploadfromtaptalk1337564282388.jpg not found
Attachment uploadfromtaptalk1337564307757.jpg not found
Attachment uploadfromtaptalk1337564318298.jpg not found
Daily
2004 Suzuki SV650
Project
  • ecannon
20 May 2012 22:43
#523673
Finally home after work.
Im almost at a frame, still gotta get the engine off, and them wheels n forks. First timer here so the easy bit is done (in my opinion), removing the rear wheel seems a little more interesting with chain n drum break n all.
For now, my self limited budget is another $750 to get it on the road, bringing total expenditure to $2000CAD
(sorry about the multiple replies, all the phone would let me)
Daily
2004 Suzuki SV650
Project
  • ecannon
20 May 2012 23:05 - 21 May 2012 03:35
#523683
Attachment uploadfromtaptalk1337565480358.jpg not found
Unfortunately it looks like most of the screws on this cover are stripped, so looks like a trip to a machine shop to get them drilled out and re threaded at $10/$20 a piece.
Attachment uploadfromtaptalk1337565491241.jpg not found
Attachment uploadfromtaptalk1337565506008.jpg not found
Got some rust to clean up, hopefully nothing harmful to the structural integrity
Attachment uploadfromtaptalk1337565515075.jpg not found
Gonna have to give the engine a gooooood scrubbing
Attachment uploadfromtaptalk1337565529708.jpg not found
Just had to update everyone as to where the project is at now. Only started 1 day ago, put about 4/5 hours work in so far, I don't think its to bad for my first time...
Daily
2004 Suzuki SV650
Project
Last edit: 21 May 2012 03:35 by ecannon.
  • ecannon
21 May 2012 03:39
#523756
Attachment not found
Attachment uploadfromtaptalk1337582281952.jpg not found
Attachment uploadfromtaptalk1337582290942.jpg not found
Attachment uploadfromtaptalk1337582301347.jpg not found
Attachment uploadfromtaptalk1337582311392.jpg not found
Daily
2004 Suzuki SV650
Project
  • DoctoRot
  • DoctoRot's Avatar
21 May 2012 04:25
#523758
ecannon wrote: Unfortunately it looks like most of the screws on this cover are stripped, so looks like a trip to a machine shop to get them drilled out and re threaded at $10/$20 a piece.
Damn how many screws are there? You might wanna try getting a impact driver, the hammer kind, and save yourself some money. they're pretty cheap (i got mine for $15) and they work great! especially on OEM screws because they are so soft. I have had a couple as bad or worse than the ones in your photos and still gotten them out. just my .02
www.amazon.com/Tool-Aid-SGT14950-Impact-Driver/dp/B000I1X6RU
  • ecannon
21 May 2012 04:50 - 21 May 2012 04:54
#523759
There's 5 or 6 on that cover alone... Not an exciting prospect. Im gonna be doing some shopping for tools (young first time mechanical worker trying to get my shop together), have a diver set of stripped screw removers, gonna give that a go as some have been nicely rounded off, the others are varying stages of stripped.
So close to ending the beginning! Just the front forks to remove and Mt first project is about to begin! :lol:
Daily
2004 Suzuki SV650
Project
Last edit: 21 May 2012 04:54 by ecannon.
  • Heyst
  • Heyst's Avatar
21 May 2012 11:02
#523806
Good luck with getting the screws out! I had the same issue with all my covers. them screws were held in good....I got lucky, I could tighten them just enough that they broke loose then unscrewed them, or cracked on the end of a screwdriver to break it sorta loose. beware of hitting on any plastic handle though... they explode.
Baseball = 1 ball
Basketball = 1 ball
football = 1 ball
Building your own hardtail? = 2 balls
1980 Kz550 Hardtail Project
21 May 2012 11:18
#523809
2 suggestions:
You need to order a can of Kroil (see: Kroil 1/2 pint (8 oz.) can - $8.50 ea. in link below). You soak stuck screws with this stuff for 2 or 3 days before trying to remove them and they will be 1000 times easier to remove - no kidding.
www.kanolabs.com
You need to get some Phillips screwdriver tips (#3 for the big screws, #2 for smaller screws) and modify them as shown in the link below. The screws on Kawasakis that look like Phillips are not Phillips; they are JIS - see link and the links it includes for explanation on how to make proper screwdriver bits.
kzrider.com/forum/13-bike-related/519588-tips#519601
  • ecannon
21 May 2012 14:38
#523841
Meanwhile in Canada...
www.amazon.ca/SG-Tool-Aid-SGT14950-Impac...d=1337621319&sr=1-89
After such a good start to the project, it seems to be slowing down with my lack of tools and knowledge. The front end is still attached so that should be coming off in the next day or two, then, until I have spare time to make a trip state side to pick up some goodies, it seems I`ll be slow going for a while.
On the states shopping list currently;
- hand impact driver
- kroil
- rustoleum
- spray gun
- any misc parts that I figure I might need between now and then
Sure hope it all fits in my saddle bags...
Daily
2004 Suzuki SV650
Project
