Z200 Project / Lost cause??
- iandz500
04 Feb 2012 19:35
Evening from snowy England, not been about for a few years since I sold my z500. Well
I got a new Z today, a tiddler.
Collected my Z200 today, not as good as it looked in the photos (actually it looked crap in the photos too!!)
Had to drive down to snowy Somerset, then across to Devon and back up to Aylesbury, it's still on the truck cos its too bloody cold to unload it into the factory!!
I'll unload it tomorrow and get some photos of it loosely assembled with the tank panels etc
But here's a sneak preview.
Snow/salt/grit covered wheel (hides the rusty rims!)
Watch this space for a very slow and probably fairly unsuccessful rebuild/project, no idea what I'm going to do with it yet
IanD
IanD
Bikes: 1960 lambretta Li125 sold; 2001 Honda CG125 sold; 2006 Yamaha FZ6 sold; 1980 Kawasaki Z500 sold; 1967 BSA Bantam D10; 2008 Aprilia Shiver sold; 2010 KTM Duke 690R; 1954 BSA Bantam; 1980ish Kawasaki Z200
- faffi
Re: Z200 Project / Lost cause??
04 Feb 2012 19:50
You can probably save the fork legs by grinding them down with an oily, very fine sand/emerald stone until nothing no peaks remain - pits doesn't hurt seals in my experience. Rubber gaiters will hide the ugliness.
The 200 engine was infamous for overheating and rapid wear, but I think the KL250 and Z250C engines will fit. May be worth doing since the 200 looks like a real Kawasaki of the era, like a downsized Z650. It will most likely be a money pit, meaning you probably never will get much of your money back. So it's only worth doing if you really want the bike - or the practice.
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
1980 F1 engine
B1 Points ignition
- iandz500
04 Feb 2012 20:19
Thanks for the fork tip, would 1200 grit wet and dry paper be ok?
I've heard araldite (2 part epoxy resin) is good to fill any pits??
IanD
IanD
- faffi
04 Feb 2012 21:12
I've never bothered filling the pits as they've never hurt any of my seals. The paper is too soft to get rid of the minute peaks in my experience, and you need to get them all out. In the end, you shouldn't be able to scratch butter
I have a very soft stone that I use in the end - dry - and if it snags the least I grind some more.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
1980 F1 engine
B1 Points ignition
- iandz500
05 Feb 2012 08:58
Unloaded her into the 'bike shed' at work, I loosely assembled all the parts out of the box just to see what's there and whats missing.
I'm thinking I'd like to build a cafe racer, modelled on the small Ducati and Honda racers of the 60's.
Here's how I've left her;
I think I'll need to do a bit more work than the sticker under the seats implies!!
IanD
IanD
- Old Man Rock
05 Feb 2012 10:04
She's actually in good shape....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- faffi
05 Feb 2012 10:53
I agree, it does seem like a decent starting point. Your idea for the build sounds like a good'un
1977 KZ650B1
1980 F1 engine
B1 Points ignition
1980 F1 engine
B1 Points ignition
- Stephens
08 Feb 2012 07:59
I got a tiny 200 that i'm in the throws of cafinating
I say do it,parts a pretty cheap and can be found with a bit of searching.
Kawasaki did a klt200 three wheeled atv which shares the engine so pistons a springs can be had..
I'll try to post up some pics tonight if i get a chance.
Past bikes
1992 vfr400 nc30,1999 gsxr600, 2004 z750,Buell xb9s 2003,1992 bandit 400,2007 er6n,
- matt_finish
08 Feb 2012 10:34
I like it!
I am doing a kz250 single right now. The klx off road bikes share the platform with the kz250 single and even the mojave quad, and they come in 200cc... parts should not be an issue if you do your "seuthing"...
Keep posting pics! Matt.
1980 kz250d1
1981 husky 250xc
prior builds:
1982 kz440ltd (in the kz400.com site under 440cafeish)
1999 triumph 955i
several zundapp 50cc-250cc builds
(plus more bikes than I'd like to admit)
I am an instructor of automotive refinishing and repair at the collegiate level, so I can generally help with paint, body, and generial service questions if you have them.
1981 husky 250xc
prior builds:
1999 triumph 955i
- iandz500
08 Feb 2012 15:02
Cheers guys, I don't suppose you know what bikes share the front brake calliper do you? I bought one for a z250 not noticing its for the wrong side!
I started cleaning her up today and found some wildlife;
Snails under the number plate light,
And a spiders web in the speedo,
I'll see what else I can find tomorrow when I get stuck into it!
IanD
IanD
- Stephens
08 Feb 2012 15:42Before.
Rear hoop and seat mounts
Cb750 seat,too small for frame and wrong shape
Pinched seat in to make it narrower and fit rear hoop, extended down and lengthened.
Bars are just to get the idea. Got some billet clip ons.
Frames now finished and at the powder coaters
Hated the idea of a cable front brake so i bought a caliper and lever from a kh125 and made a bracket.
Flipped the forks round to fit the caliper behind fork (I think its probably safer).
Only problem is the speedo drive running backwards so I'm going to make a space to take its place and run a digital speedo.
Past bikes
- iandz500
08 Feb 2012 17:07
Looks good, have you got a projects thread on here? When you say flipped the forks round how do you mean side for side or just turned each leg through 180 degrees?
Cheers
IanD
Cheers
IanD
