Z200 Project / Lost cause??
- Stephens
08 Feb 2012 17:28 - 08 Feb 2012 17:32 #502822
by Stephens
Past bikes
1992 vfr400 nc30,1999 gsxr600, 2004 z750,Buell xb9s 2003,1992 bandit 400,2007 er6n,
Replied by Stephens on topic Z200 Project / Lost cause??
Side for side.
Only started this project a couple of weeks ago. Really should start up my own thread.
Will keep a keen eye on yours, its always nice to see other peoples take on things.
Past bikes
Last edit: 08 Feb 2012 17:32 by Stephens.
- faffi
- Thank you received: 36
08 Feb 2012 17:52 #502827
by faffi
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
Replied by faffi on topic Z200 Project / Lost cause??
Bike deserves an upgrade to hydraulic brakes.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
- iandz500
- Thank you received: 1
08 Feb 2012 18:39 #502835
by iandz500
Bikes: 1960 lambretta Li125 sold; 2001 Honda CG125 sold; 2006 Yamaha FZ6 sold; 1980 Kawasaki Z500 sold; 1967 BSA Bantam D10; 2008 Aprilia Shiver sold; 2010 KTM Duke 690R; 1954 BSA Bantam; 1980ish Kawasaki Z200
Replied by iandz500 on topic Z200 Project / Lost cause??
Definitely go for hydraulic brakes, what bike is your calliper off? I bought one for a z250 but it's for the wrong side, I'm wondering off I could switch it the same as yours Stephens?
IanD
IanD
- Stephens
09 Feb 2012 04:16 - 09 Feb 2012 15:33 #502931
by Stephens
Past bikes
Caliper came off of a kh125 which looks a lot like the z250.
Had to use kh caliper mount and make an adaptor plate and weld it to the kh mount.
All the braking force is behind the fork which works for me.
Sorry seem to be hi jacking your thread here.
I've started my own project thread.
Past bikes
Last edit: 09 Feb 2012 15:33 by Stephens.
- iandz500
18 Feb 2012 14:35 #504876
by iandz500
I think I might have to take the same tact with my kz250 caliper to get that to work.
Projects going to stall for a few weeks, I've got to swap the engine over on my '54 bantam as I have to take it for DVLA inspection before they'll let me put it on the road!
Cheers
Ian
Cheers
Ian
- Stephens
18 Feb 2012 15:23 #504883
by Stephens
Past bikes
Hope all goes well with that
Never had to take a bike for inspection other than an Mot, and that can be nerv wracking enough...
Past bikes
- iandz500
18 Feb 2012 16:55 #504894
by iandz500
- Stephens
19 Feb 2012 08:51 #505006
by Stephens
Past bikes
Nice bike
Looks like its a hardtail or is that a small shock at the back ?
Past bikes
- iandz500
19 Feb 2012 09:07 #505008
by iandz500
Cheers, It's a plunger frame, basically a rigid frame but the wheel spindle is fixed between 2 springs giving it a small amount of travel, plus the seats sprung so it's not too stiff, I've only ridden it round a field and a crapark so far, and it's mot'd for daylight use only. I'm not sure how practical it'll be on the road!
- Stephens
19 Feb 2012 13:03 - 19 Feb 2012 13:04 #505046
by Stephens
Past bikes
I bet wherever you ride it a crowd will form.
Seems that at all the bike meets we go to its always the out of the ordinary, older machines that get all the attention.
Who wants to get there first anyway
Past bikes
Last edit: 19 Feb 2012 13:04 by Stephens.
- iandz500
15 Mar 2012 20:34 #509900
by iandz500
I started work on my z200 again today, I stripped off nearly everything so can start from an almost blank canvas. I'm thinking of going for a daylight not to keep the bike as light and simple as possibl, plus all the wiring is shot, most electrical components are missing or broken and I hate electrics!!
I wired the generator directly to the coil, I then kicked it over but it turns out there's no magnets in the flywheel
Bugger!
I'm on the lookout for a replacement but could do with knowing what other kawasakis share the same part numbers
Cheers
IanD
Bugger!
Cheers
IanD
- iandz500
17 Mar 2012 11:35 #510192
by iandz500
Just been over to work to the workshop to carry on stripping the old girl down. I think I've now got absolutely everything off ready to start the 'dry build'
But first things first, I need to get the generator rotor/flywheel replaced to see if the engines any good. I'll not be spending any money until I ensure I can get the engine to run.
After that the plan is to keep it as a daylight Mot'd cafe style racer. It'll be stripped of all excess weight, brackets, frame lugs etc.
I'm planning on making my own adjustable clip on bars, rear set footpegs, clock brackets, seat and race hump, modified front & rear mudguards. It is going to be built on the strictest budget possible. I'll be selling off everything i've pulled off either on here or eBay.
It'll be fairly slow but I think I'll end up getting into my stride once I get the engine running!
