AHRMA Vintage Superbike Middleweight Racer
- DoubleDub
Re: AHRMA Vintage Superbike Middleweight Racer
14 Dec 2011 17:49
So I've been thinking out a paint scheme for the bike. I think I'll be doing a classic Kawasaki green with white stripes. The paint I'm looking at using is from
Eastwood.com
and is called
Lime Squeeze Green
and is part of their Muscle Car color lineup.
I've also been thinking about giving the bike the name, but realized that my wife has already named it. I'll have a sign shop make up some stickers for me from one of the following. Of course, the Kawasaki name plates will stay on the bike after being cleaned up and touched up.
Attachment p35720.jpg not found
Attachment themistress1.PNG not found
Attachment themistress2.PNG not found
- mark1122
- Keep twisting it
14 Dec 2011 17:54
that should look great. i like her name too.
any luck with the spark plug yet ?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- DoubleDub
14 Dec 2011 17:56
I also found some cool articles that I think RonKz650 had posted over on the kz650.info site that I thought I would repost here:
- DoubleDub
14 Dec 2011 17:59mark1122 wrote: that should look great. i like her name too.
Thanks for reminding me - I need to email the rules folks and ask about the 750 head. I'm also looking at buying another engine for parts that *should* have a good head, cylinder, and piston set as I'm concerned about the rust on the #2 sleeve.
Going to try to clean up the sleeve tonight to see if it might be serviceable, but I'm not betting on it.
- mark1122
- Keep twisting it
14 Dec 2011 18:00
for some reason , i can see the green paint pic but i cant see most of your other pics. i'm at work and they block all the good stuff.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- DoubleDub
14 Dec 2011 18:01
Yeah, they must be blocking PhotoBucket as that's where they are coming from.
- DoubleDub
15 Dec 2011 14:01
Dopped an email to the rules committee guy. From the sound of it (no clear answer yet as he had a few questions) since the Kz650 and Kz750 heads are almost identical I should be ok to use it. But I'll wait for the final answer before moving ahead with the head at all.
I'll see what I can do about the spark plug anyways. Hoping to do some wrenching this evening. I'd really like to get the frame stripped so we can start working on bracing.
- DoubleDub
15 Dec 2011 20:55 - 15 Dec 2011 20:56
Started taking apart the 750 head to clean it - the ports weren't covered in the past (before I got the engine) and it almost looks like there is red clay in them.
Anyways, things went just fine on 3 of the valves, but on the other five I can't get the buckets to budge. Just wondering if you guys have any tricks on freeing up a stubborn bucket...
Last edit: 15 Dec 2011 20:56 by DoubleDub.
- DoubleDub
16 Dec 2011 19:17
Spent a little bit working on the rusted sleeve with a greeny and some lube. No luck, there is way too much rust in there for it to survive anything but a bore job.
Going to have to find a new liner (at a minimum) and/or good jugs with liners. I have talked with member here who is selling a motor with damage on the cases but good compression, might have to pull the trigger and get it. More spare parts never hurt anyone, right? :dry:
- DoubleDub
18 Dec 2011 23:21
Fun With A Cylinder Head
I started tearing apart the Kz750 head in preparation and found the head full of sand and what looks like clay. I think all the parts need is a good washing and it will be ok to run for a season. Pics are attached below. None of the grit/grime appears to have been there when the engine last ran as I don't see scoring marks or gouges from it - I'm fairly certain it got in the engine because the intake/exhaust ports weren't covered. I do have one lifter/bucket that is stuck and I’m trying to figure out how I can get it to release. Five of the other buckets were stiff, but I was able to work them free and remove them. I have a feeling there is some sand or dirt trapped between the bucket and the head causing it to bind. Hopefully it doesn’t score the bucket much as I try to remove it.
Also got most of the peripheral stuff stripped down on the front. The brake master cylinder will have to be replaced or rebuilt. I have an aftermarket unit but I need to make sure it is big enough to power two calipers.
Had to drill out the screws on the headlight shell. It’s in pretty rough shape on the inside and will need to be blasted before being sealed and repainted. I need to retain the headlight shell without the the headlight and blinkers for the AHRMA series.
- KZ250LTD
Last edit: 13 Feb 2012 17:37 by KZ250LTD.
- DoubleDub
19 Dec 2011 10:13KZ250LTD wrote: Yikes looks pretty gross. For the money (reasonable KZ650 heads can be had for $25-75 on ebay) I'd probably get one that isn't full of clay. JMHO tho
Likely what will happen since my cylinders need to be swapped also. Just trying to see if the 750 head is salvageable. I'm going to give it a good soap and water bath once I get it all disassembled and then see how the valves seal. If it needs works, it will get put on the shelf until I can send it out to have it worked on/ported, etc.
