KZed Police bike
- motorscot
Re: KZed Police bike
09 Nov 2011 02:53
This afternoon I installed Otakar's HID front headlamp kit. I am pleased overall with the setup, but I was hoping for more out of the "city light" led. I will update tomorrow after voltage/amperage tests. I couldn't run the bike after install due to a possible leak from the vent/overflow assembly under the tank. There has been an odor of gas over the last week that I couldn't pinpoint. When I removed the tank to run the wires to the battery, I saw some gas on the backbone and some seepage
On to the kit:
What is included
Close up of the new light with the LED city light at the bottom (left in the pic)
Stock headlamp mount cup
After removing enough material to slide the lamp into place. The LED protruded far enough to block easy insertion and now fits into the large slot in the bottom of the cup
The light installed. I will have to put a bead of clear silicone to keep the light in position. The lamp will rotate without the bead around the outside edge of the mount ring (not the outer trim ring)
On to the kit:
Attachment IMAG0123.jpg not found
What is included
Attachment IMAG0124.jpg not found
Attachment IMAG0128.jpg not found
Attachment IMAG0129.jpg not found
Attachment IMAG0130.jpg not found
Attachment IMAG0131.jpg not found
- motorscot
09 Nov 2011 03:08
I then ran the rest of the wiring and mounted the ballast.
Close up of the new lamp and LED
The ballast mounted on the inside of the fairing on the left inner side, the supplied double sided foam wouldn't hold the ballast against the unfinished fairing. I went with 3M trim tape instead
I ran the direct to battery wires through the grommet access plug which allows for access to the fairing reflector
Light on Hi-beam (city light LED only)
HID Xenon light on Lo-beam
HID light only, not the best pic or background
Top shot of the LED only
Top shot of the HID only
Overall I am very happy. The install was a breeze other than the cup having to be notched and the tank removal to run the wires
Total time: 1 hour
Attachment IMAG0132.jpg not found
Attachment IMAG0134.jpg not found
Attachment IMAG0133.jpg not found
Attachment IMAG0135.jpg not found
Attachment IMAG0136.jpg not found
Attachment IMAG0137.jpg not found
Attachment IMAG0138.jpg not found
Attachment IMAG0139.jpg not found
Total time: 1 hour
- motorscot
14 Nov 2011 22:07
I finally got a chance to ride the bike today and see how the new headlight works in the daytime vs other vehicles and how the charging system would be affected.
Verdict: Excellent
Visibility: Very good. It shows up mucho better than the old halogen around town and on the highway. I feel much safer.
Energy consumption: Very Good. It draws less power than the old light. Previously, I had 2 greens with no light, 1 green with the halogen on, and no greens with the brakes and halogen on
Now, 2 greens with the HID on, with one of them flickering at idle with brakes on.
Draw is around .7 volts. Normal is 14.3-14.5 @ 4000 rpm, HID drops it to 13.5+
I can live with that
Thanks again to Otakar!!
Verdict: Excellent
- motorscot
25 Mar 2012 11:28 - 25 Mar 2012 11:31
Finally pulled the trigger on a new exhaust system. MAC Exhaust from DennisKirk.com, part number #44444, black header and collector with chrome canister
www.denniskirk.com/mac/4-into-1-black-he...p44438.prd/44444.sku
Worst part was having to remove the crash bar to fit the new header. Test ride showed strong power throughout the range with pronounced crackle and pop during off throttle engine braking. The carbs are stock rebuilt/reconditioned units from oldskoolcarbs (ebay) using 125 mains. I will finish installing the 127.5 mains this afternoon and report back.
System was well put together and will work on any 82-06 KZ-Police (contrary to what Denniskirk says). Saddlebags are unaffected and now I have much more room to access the oil drain plug and filter. The center stand uses a bracket that the system provides, and I used clear silicone adhesive to adhere the rubber bump stop from the stock system to the bracket (blue masking tape in last pic). Can't wait to ride it again today post jet swap.
Attachment pic1.jpg not found
Attachment pic2.jpg not found
Attachment pic3.jpg not found
Attachment pic4.jpg not found
Attachment pic5.jpg not found
Attachment pic6.jpg not found
Last edit: 25 Mar 2012 11:31 by motorscot.
- motorscot
01 Apr 2012 21:24 - 02 Apr 2012 23:50
So, the jets have been swapped and while I was at it, I decided to finally replace the leaky valve cover gasket, clean up some wiring, clean up some parts, and replace the fork oil
prior to blasting with aluminum oxide
post blasting
Attachment valve1.jpg not found
Attachment valve2.jpg not found
post blasting
Last edit: 02 Apr 2012 23:50 by motorscot.
- motorscot
01 Apr 2012 22:15 - 02 Apr 2012 23:58
Baking in the oven for 30 minutes at 170 degrees
Attachment valve4.jpg not found
Last edit: 02 Apr 2012 23:58 by motorscot.
- motorscot
01 Apr 2012 22:24 - 02 Apr 2012 23:51Attachment valve3.jpg not found
Primered
Last edit: 02 Apr 2012 23:51 by motorscot.
- motorscot
01 Apr 2012 22:33 - 02 Apr 2012 20:09
I also had a lot of leaking and blowby from my American Classix oil cooler adapter: I decided to replace the rubber lines and Zephyr oil cooler with real fittings and hoses
new -6an fittings, also shown is the crankcase breather I blasted and painted, I also modded the airbox by sealing the lower hole and running tubing to the upper hole for case venting
Another view, in the second pic. the lines are running on the right side, underneath and along the frame. Cooler is a -6an inlet and outlet from Earl's. Everything was purchased through Summit Racing. Almost forgot, I had to get two -6an to pipe fittings to attach the new hardware to the oil cooler adapter
Attachment plumbing1.jpg not found
Last edit: 02 Apr 2012 20:09 by motorscot.
- motorscot
02 Apr 2012 18:13
Another view, showing the new crankcase breather assembly painted and with new vent hose to the upper airbox hole. The lower one has been sealed off
Attachment plumbing2.jpg not found
02 Apr 2012 23:34Hoping a carb vent hose hasn't been sealed off. :huh:motorscot wrote: Another view, showing the new crankcase breather assembly painted and with new vent hose to the upper airbox hole. The lower one has been sealed off....
- motorscot
02 Apr 2012 23:49Patton wrote:Hoping a carb vent hose hasn't been sealed off. :huh:motorscot wrote: Another view, showing the new crankcase breather assembly painted and with new vent hose to the upper airbox hole. The lower one has been sealed off....
How so? I removed the EGR equipment. I only have 1 vacuum line attached for the carb to tank feed. If I screwed something up, please tell me
02 Apr 2012 23:56Unused vacuum nipples should be sealed/capped/plugged.motorscot wrote:Patton wrote:Hoping a carb vent hose hasn't been sealed off. :huh:motorscot wrote: Another view, showing the new crankcase breather assembly painted and with new vent hose to the upper airbox hole. The lower one has been sealed off....
Vent nipples should remain open to atmosphere.
Okay to run hose from crankcase vent into airbox, or catch-can, or open to atmosphere.
