Doctorot's '78 KZ1000 build
  • Bozo
  • Bozo's Avatar
  • Ride it like u stole it
Re: Doctorot's '78 KZ1000 build
08 Nov 2016 01:41
#747541
Very very nice great work, keep the photos coming
  • Zedone
  • Zedone's Avatar
08 Nov 2016 17:38
#747596
What media did you use on the pockets.... 90 grit AO or did you use glass? I wanted to machine pockets also on my rearset adapters but decided to punch them right through for the same reason you mentioned... no cnc here just a Craftex CX600 (almost identical to a Grizzly G-0704) The hangers look really nice Doc... nice clean lines. I made custom hangers by hand using 7075 T6 but their just flat .250" stock, I plan to remake them similar to what you have done using .500-.750" 7075 T6. What type of aluminum did you use? I just (finally) bought a half decent compressor (18 cfm @ 90) but am waiting to buy a blast cabinet. The rearset adapters are in the process of being wet sanded/polished and aren't finished yet... keep up the excellent work,
Cheers,
Doug
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
  • DoctoRot
  • DoctoRot's Avatar Topic Author
08 Nov 2016 21:04
#747604
those look nice Doug. I used 80 grit glass. They are cut from .75" 7075
The following user(s) said Thank You: Zedone
  • larriken
  • larriken's Avatar
08 Nov 2016 22:02
#747607
Nice work Doc, this is a great thread and a great build!
  • Zedone
  • Zedone's Avatar
08 Nov 2016 22:20
#747610
Thanks Doc, your paint work looks flawless also... I have 2 complete sets of bodywork to do (gloss black w clear) this winter... if I can get time,
Cheers
1977 KZ1000A1
  • DoctoRot
16 Jan 2017 12:59 - 16 Jan 2017 13:00
#752311
Ok time to get back on this thing. I have been distracted by work, school, the holidays, traveling...blah blah blah. I ended up doing some mods on a buddies kz650, polished the cases, new rotors, and new seat cover. body work is out for paint currently. Im jealous, this thing runs sweet.
Anyway I have made a list of stuff I need to do to get the 1000 back on the road.
> rebuild the forks.
> Re-install head. (I had to take of the head to drill and tap the emission ports for some set screws to plug them, also there were two stripped screw holes that i didn't see the first time around. so that needs to go back on.)
> Install carbs
> Finalize battery tray/ electronics position
> plumb the brakes
> install new chain
> WIRING
> tuning
> burnouts
Last edit: 16 Jan 2017 13:00 by DoctoRot.
  • DoctoRot
22 Jan 2017 00:26 - 22 Jan 2017 00:28
#752640
Battery/electronics trays finished and rubber mounted! gotta pull them off to massage a couple small spots and then paint. With the sidecovers on it will form a pretty big storage space which is something I loved about the stock bike. I can easily fit a sixer in there B)
Also got the head back on and the motor buttoned up.
Last edit: 22 Jan 2017 00:28 by DoctoRot.
  • NobleHops
  • NobleHops's Avatar
  • Vendor
  • Vendor
  • A happy present from the earth!
23 Jan 2017 18:18
#752782
Your fabrication skills (among others) are really incredible. Form AND function.
Nils Menten * RestoCycle LLC * Tucson, Arizona * USA
Proud sponsor of KZRider: kzrider.com/forum/14-vendor-forum/604812...on-shocks-usa#751083
Vapor blasting with free shipping! www.restocycle.com
Discounted Ikon Shocks! www.ikonshocksusa.com
  • DoctoRot
01 Feb 2017 00:24 - 01 Feb 2017 00:42
#753372
Rebuilding the forks turned out to be a bit of a debacle. when I got the dust seal off there was deep pitting on the stanchion tube which is what caused the fork seal to leak. It was surprising considering the condition of the forks otherwise. Tracked down a new set and am waiting on new bushings before putting them back together. Fork legs will get new paint.
Because I remade the caliper mounts with them on the inside of the fork legs I had to remake the fender mounts. They will get paint soon as well.
I splurged on these RS34 carbs this summer. I got them test fitted to check my cable length, and to figure out a support for them. Any suggestions where I should start with jetting? motor has Wiseco 1075, mild cams, street port and polish, and free flowing header.
Last edit: 01 Feb 2017 00:42 by DoctoRot.
  • Sprengstoff
  • Sprengstoff's Avatar
04 Feb 2017 00:56
#753620
Those pinstripes look pretty good, and so does the paint job. Makes me think about using pinstripes too now :) i've never used it before
  • davido
  • davido's Avatar
04 Feb 2017 02:29
#753624
On the pinstripes,.I was advised by a painter friend to start with one colour (in your case the red) Paint everything red.Then mask off the red pinstripe,paint everything black,mask that off then go for the silver. Remove the masking and you have all your pinstriping done. This way,the pinstripes retain their brightness as they are first on the undercoat.
I was a bit dubious about it,me being a first time painter at the end of a very long project build, but it actually worked out very well.
Anyway,nice build ,nice build thread.Well done and good luck with the carb jetting.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • DoctoRot
Re: 78 KZ1000 build (I'm learnding)
04 Feb 2017 13:24
#753649
more than one way to skin a cat. I think the way you described is better for two reasons 1. much less time and materials in masking. 2. instead of creating high points where the lines are it creates recesses, which are easier to fill with clear and cut and buff for the "flush" look.
