Thrown together to ride til winter
  • damarble
  • damarble's Avatar
Re: Thrown together to ride til winter
04 Jul 2012 23:30
#533913
You've got to be kidding. That's retarded. As long as it's visible and lit I don't see what they can gripe about.
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
  • ramtough_63
  • ramtough_63's Avatar Topic Author
04 Jul 2012 23:50
#533921
when I got pulled over I wasnt sure why pu my kickstand down got off he came up complimented me on my bike and told me in indiana your plate has to be in the center (rear) of the vehicle with correct orientation mine was verticle off rear axle. if I remember right it was 187.00 dollar ticket
my nephew has an s10 with a crooked plate moulded into the corner of his tailgate no problems I have ran them in the back window of my car with no problems.
not sure if he was new or just pissed and wanting to write a ticket but with open header and integrated tail light I already have enough reasons for a ticket but if I dont get this plate lined out I will be chancing it
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
  • damarble
  • damarble's Avatar
05 Jul 2012 00:07 - 05 Jul 2012 00:12
#533924
What do they have to say about Jeeps with factory offset plates, or about ever trailer ever made? I can understand saying it can't be sideways but they're just being ticky tacky. Go fight real crimes and leave harmless customizations alone.
I do whatever I want to mine and if they don't like it they write the equivalent of fixit tickets, show up to court with proof you fixed it and they drop it.
Last edit: 05 Jul 2012 00:12 by damarble.
  • shaun86chevy
  • shaun86chevy's Avatar
05 Jul 2012 02:46
#533947
OMG les those triples rock unbelieveable work!!!!!
Ram, I've been suscribed to this build from page one I love it
I have decided to try and enlist les to build me a swingarm for my bike after seeing the work he
Has done for u. I have my build on here but I got pretty far and decided to start all over. I will
Start posting on it agian soon as I get this wedding outta the way. I also had to move but now i
Actually have a garage to work in instead of my sunroom lol. I doubt however that my bike will turn
Out half as good as urs.
  • rich67
  • rich67's Avatar
05 Jul 2012 04:18
#533953
Those triples are a work of art!
05 Jul 2012 11:31
#533996
Is it possible to increase preload on the rear shock?
Good Fortune! :)
  • ramtough_63
05 Jul 2012 14:43
#534039
Thanks guys cant wait to get busy with the swap but As th is has always been a budget build still accumulating parts
and Patton I I have screwed the dampening screws to the hard setting then backed them off a quarter tuen I know bothing about preload what does that consist of I do know the spring nut thing has a few more rounds I can can go down but not sure if it takes a speacial tool or exactly I I should mess with it
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
05 Jul 2012 18:22 - 05 Jul 2012 18:27
#534088
Shocks on stock bikes are designed to bottom out when the shock reaches maximum compression, before any hard parts hit the rear tire. There's usually a rubber bumper to soften the stop.
Common dual rear shocks usually have 5 different spring preload settings, ranging from soft to firm.
A mono-shock may have a threaded body with a large "nut" used to increase or decrease the spring preload.
Typically, a heavier load, such as a bigger rider or adding a passenger, may require an increased shock spring preload to afford a stiffer suspension and help prevent bottoming out.
If the spring is too weak, or if the suspension travel is too great, some hard part will likely hit the tire at maximum compression.
With some shocks, it might be feasible to fabricate an additional bumper to reduce the suspension travel at full compression.
In the case at hand, further increasing the spring preload might keep the tag from hitting the rear tire. It may be possible to use a large screw driver on a nut with indentations, and turn the nut by tapping the screw driver with a hammer.
The screws may be for damping adjustments, such as compression damping and rebound damping. Increasing the compression damping might also help stiffen the suspension and help prevent the tag from hitting the tire.
Good Fortune! :)
Last edit: 05 Jul 2012 18:27 by Patton.
The following user(s) said Thank You: ramtough_63
  • ramtough_63
13 Jul 2012 10:56
#535631
Got a Chance to go up to Les' and get some work done on my front end wheel
spacing, Made a support brackey for my license plate angle is a little extreme but
shouldnt have any problems folding it under bought a spanner wrench online to
adjust my preload (thanks Patton) Les had a Zx9 dogbone that has a slight
angle difference that gives the shock a quicker compression that that will probably
cure my problem if their isnt enugh adjustment
Thanks again Les cant tell you hou greatful I am for your help!
Attachment 100_4191.JPG not found
Mockin up the front
Gotta get busy on getting my front wheel rebuilt
Attachment 100_4241.JPG not found
Les bike is a work of art
Fast & Tight is the only way to describe it
Makes me want to start all over on mine LOL
Attachment 100_4252.JPG not found
Love this pic
Attachment 100_4260.JPG not found
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
13 Jul 2012 11:08
#535637
Great Pic! I saved that one. I was looking around this morning and found this tail modded like we were talking about, I think it would work.
Attachment tailandseat.jpg not found
Les
  • ramtough_63
13 Jul 2012 11:16
#535641
Gonna Have to try it for sure.
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • ramtough_63
13 Jul 2012 11:24
#535644
19 VS 17 the 19 looks Huge!!!!!
Attachment 100_4212.JPG not found
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
