76 KZ900 B1 - from crates.
- RobK
Re: 76 KZ900 B1 - from crates.
08 Nov 2010 15:42
Kidkawie wrote:
Thanks for the tip. Is this the kind of bit you're talking about...
www.brandsplace.com/0246-ams55138.html
Nice job on the tubes. I made a swingarm for a quad a while back using heavy guage tubing. I was going to buy a tubing notcher like you have, but I found I could bang out a birdsmouth in no time using a pneumatic deburr tool. I just traced a mark using a scrap piece of tubing. Use those spiral carbide bits like for engine porting.
My mule's got the funny idea you're laughin' at him. Now if you apologize like I know you're gonna...
- RobK
08 Nov 2010 16:04
testarossa wrote:
Thanks for the link. When I went to it I remembered that I'd been there before - lots of great stuff - thanks for being so diligent about posting. I'll try to return the favor and keep a good record of my project.
I recently stumbled across this site...
www.radicalducati.com/index.php?page=catalogo-rad
Which has given me some good trestle work (not really a shocker). I just have to figure out how to make something that fits the work already done.
You better believe my pics are on KZR. This link will take you to page 2 of my build: kzrider.com/index.php?option=com_kunena&...mit=20&limitstart=20
That's where it starts. Unfortunately it's all sorta spread out in my thread. If I have time later, I'll put all of the pertinant pictures together, and post them for you. Sounds like your idea is about the same way I did mine. You will probably need to do something like OMR for the upper mount. I was just lucky since the GSXR still had a double cradle frame. The newer bikes tilt the shock further back.
- RobK
08 Nov 2010 16:06
testarossa wrote:
Thanks - grinder is coming out.
RobK wrote:BTW - There is a small tab in between the centerstand mounts (about 1" tall).
Can anyone tell me what it's for? I bought this bike completely disassembled and so not sure what it's function is. My best guess is that it's the upper center stand spring mount, but would like to now for sure before the angle grinder comes out.
Thanks.
It's for the center stand spring. You can cut it out. You would have to be real creative to use a center stand with a mono shock setup.
- Kidkawie
- I bleed premix
08 Nov 2010 16:44
RobK wrote:
Yup. There's all different shapes you can get. It can run away from you though, so practice on a scrap piece.
Kidkawie wrote:Nice job on the tubes. I made a swingarm for a quad a while back using heavy guage tubing. I was going to buy a tubing notcher like you have, but I found I could bang out a birdsmouth in no time using a pneumatic deburr tool. I just traced a mark using a scrap piece of tubing. Use those spiral carbide bits like for engine porting.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- testarossa
08 Nov 2010 18:58 - 08 Nov 2010 19:00
Bookmarked that one. Thanks.
The pictures that I promised. The first are the bushings that I made to adapt GSXR pivot bearings to KZ1000 pivot bolt.
If you look closely at the crossbar where the center stand used to be, you can see the tabs that I welded in for the lower shock linkage. !/4" thick plate was used for the tabs.
BTW don't forget that you can click the picture for supersize.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
Last edit: 08 Nov 2010 19:00 by testarossa.
- RobK
08 Nov 2010 19:22
testarossa wrote:
Thanks for the pics. I'm gonna get the rolling chasis back together and then see if I can mimic (at least approximately the trail and rake of the ZX-6R), before figuring out where to put the mounts in.
- porchev914
08 Nov 2010 20:28
FRANKEN Z!
- porchev914
08 Nov 2010 20:30 - 08 Nov 2010 20:43
And from the side
Do everything you can to duplicate the donor bikes suspension geometry. It will have an effect on how the rear shock behaves, suspension travel, compression rate....blah blah blah. You're on track, keep it up
FRANKEN Z!
Last edit: 08 Nov 2010 20:43 by porchev914.
- Bad Kaw
- Flying Squirell
08 Nov 2010 20:49
Nicely done. I may have to copy off you later!
-KR
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- porchev914
09 Nov 2010 06:31
Copy away!
My top shock mount is very similar to irishwills bike. I took my inpiration (maybe a little more) from his design
FRANKEN Z!
- RobK
09 Nov 2010 16:16 - 09 Nov 2010 16:37
porchev914 wrote:
Thanks very much for posting - that looks just the type of solution that I'm looking for. Which swing arm did you use? I'm still learning my way around KZR, is your build thread here?
Last edit: 09 Nov 2010 16:37 by RobK.
- porchev914
09 Nov 2010 20:39
You bet it is. My build thread is here
kzrider.com/index.php?option=com_kunena&...w&catid=11&id=348089
and my swingarm thread is here kzrider.com/index.php?option=com_kunena&...ew&catid=5&id=349329
My swingarm is from an '08 Triumph Speed Triple. It's alot of reading though, enjoy
FRANKEN Z!
