76 KZ900 B1 - from crates.
- RobK
Re: 76 KZ900 B1 - from crates.
04 Nov 2010 10:46 - 04 Nov 2010 10:48
...then spend a ridiculous amount of time trying to get the angle with the fish-mouthing jig, (before realizing using an plain-old angle grinder is simpler and faster). Then of course I would have not had the pleasure of creating this piece of jigging...
My mule's got the funny idea you're laughin' at him. Now if you apologize like I know you're gonna...
Last edit: 04 Nov 2010 10:48 by RobK.
- RobK
04 Nov 2010 10:51 - 04 Nov 2010 10:52
Last edit: 04 Nov 2010 10:52 by RobK.
- RobK
04 Nov 2010 10:54 - 04 Nov 2010 11:03
Last edit: 04 Nov 2010 11:03 by RobK.
- RobK
04 Nov 2010 10:55
- RobK
04 Nov 2010 11:00
- RobK
04 Nov 2010 11:02
Been working on those subframe stays for a while now as getting them to fit nicely has proved pretty time consuming, but I'm nearly there. I'll post when I weld 'em in.
- porchev914
05 Nov 2010 11:34
Trick parts take time to make. I know I have a sizable pile of tubing and such that have incorrect lengths, bends, notches orientations. It's the price I pay for learning a hobby :silly:
FRANKEN Z!
- testarossa
05 Nov 2010 13:02
Nice looking project Rob.
You might try looking for a zx-10r front wheel as well. The front wheel on mine looks the same as those zx-6r wheels. It might broaden your search a little.
I am dying to know how you got that tube to bend around a wooden form so cleanly. What wall thickness is that tube that you used. How long was the tube that you were pulling on?
BTW, who's the cyclist in the family? I spy a Park Tool Crank puller on your pegboard. :dry:
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- ready2ryde1985
- got to love these kzs
05 Nov 2010 19:17
Nice bike I am plannin a similar build to my kz 700 def gona subscribe
84 kz 700 a1
82 kz550 ltd
82 kz550 ltd
- RobK
07 Nov 2010 20:04 - 07 Nov 2010 20:05
testarossa wrote:
The tubing is about 1/10" thick (measured with a micrometer, not sure if I found a low spot and it's supposed to be 1/8"). Still pretty new to metal sizing.
I actually bent three bars. The first one I heated (with propane), and the second two without. There was a difference, but not a huge one. Perhaps oxy-acetylene would have made a bigger difference, as propane doesn't really get terribly hot. The bars were about 5' long and I have another 2' piece (of larger diameter) tubing I used for leverage. I would have liked to go longer, but the setup in the shop didn't allow for it.
The jig was made from 2 pieces of 7/8" MDF (clamped and glued together), jog-sawed and sanded to shape. I then used a router to cut a pretty deep channel, which the tubing fit into very snugly.
Also, not sure if you can see all the lag-bolts in the jig (7), but that thing was very securely attached to a workbench. Te bench is in turn bolted into two ledger strips that are bolted into the studs of the garage wall. It's pretty stout.
I was reminded that I am not quite as stout as the bench when I tweaked something in my shoulder on one of the more aggressive heave-hos. :blink:
BTW - good spot. That is indeed a Park Tool Crank puller - been messing with bicycles since I could crawl
Last edit: 07 Nov 2010 20:05 by RobK.
- RobK
07 Nov 2010 20:06
ready2ryde1985 wrote:
Just recently became aware of the KZ700. It's a fairly rare beasty, no?
- RobK
07 Nov 2010 20:07
porchev914 wrote:
..yeah and a little flesh and blood. :lol:
