my z650 / 1170 rebuild
- kenty
Re: my z650 rebuild
18 Sep 2010 17:12
the lucky thing is the TL stem fits the 650 frame and bearings are available off the shelf , i did make a small adjustment to the bottom yoke along the way but it turns out i didnt need to , i recessed the stem hole to give me a bit more length but after machining the yoke to size i had to push the stem back down and pin it
- kenty
Re: my z650 rebuild
18 Sep 2010 17:14Please Log in or Create an account to join the conversation.
- kenty
Re: my z650 rebuild
18 Sep 2010 17:18
i had to make up some spacer tubes to fit inside the new yoke because the new yoke has a larger hole than the fork tops but everything tightens up nicely .
- kenty
Re: my z650 rebuild
18 Sep 2010 17:22
because i dont like to chuck things away if i can put them to use i cut the TL top yoke up and made some mounts for my turn signals
- kenty
- T_Dub
Re: my z650 rebuild
19 Sep 2010 02:51
Thats some nice work, bit of ingenuity goes a long way.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- Mark Wing
Re: my z650 rebuild
19 Sep 2010 11:22
Looks great, love hopped up 650'sKeep up the good work.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- kenty
Re: my z650 rebuild
19 Sep 2010 11:52
this is how it looked whaen i first fired it up , cb400 twin shock rear end and a different exhaust , with mounting the motor so low i can easily get the barrels off in the frame , which is lucky as this motor had lots of problems
- kenty
Re: my z650 rebuild
19 Sep 2010 12:02 - 19 Sep 2010 12:11
the motor had a bad rumble / rattle from the transmission so i had to take it out and investigate , turns out one of the output shaft bearings was worn out so i replaced it, stuck it back in and it still had a noisy rumble ,so i took the clutch out just to run it without the trans turning and it had a noisy crank as well , i got this motor as a supposedly running example , ye it ran but i decieded to strip it to see what else was wrong , the rings were so thin its a wonder it ran at all , on closer inspection they had a T shaped cross section , now i've never seen rings wear out like this so rather than rebuild the motor i had a word with a mate who runs a breakers , just so happens he had a bike for breaking goin cheap , yet another gpz ! but had to be broken and not returned to the road , ideal !!
Last edit: 19 Sep 2010 12:11 by kenty.
- kenty
Re: my z650 rebuild
19 Sep 2010 12:04
doesnt look much , but only cost me £100 , about $170 ???
i stripped the motor and found it had 1170 pistons , very nice :ohmy:
- kenty
Re: my z650 rebuild
19 Sep 2010 12:07
it also had a mono shock rear end with a wp shock and a one off ally lower link , someone put some effort into this
- kenty
Re: my z650 rebuild
19 Sep 2010 12:08
nice bit of welding, i thought it would be rude to chuck it away so i decieded to monoshock my frame
