my z650 / 1170 rebuild
  • kenty
  • kenty's Avatar Topic Author
Re: my z650 rebuild
18 Sep 2010 09:29
#399602
the front needed a frame rail for the lower engine mount so i cut it a little long and knocked it up into place ,this opened the frame a bit , :woohoo: more clearance cant be a bad thing
  • kenty
Re: my z650 rebuild
18 Sep 2010 09:31
#399604
because the mount had to reach back to the motor i made a removeable mount
  • kenty
Re: my z650 rebuild
18 Sep 2010 09:34
#399605
all that was left to do was the rear mount , the box section was already in from the previous motor so i made another removeable mount that simply bolts in place
  • kenty
Re: my z650 rebuild
18 Sep 2010 09:36
#399606
this is the mount , the angle section takes all the weight of the motor and with the mounts removed the motor is real easy to remove
  • kenty
Re: my z650 rebuild
18 Sep 2010 09:39
#399608
just to be on the safe side i ground some small flats inside the lower rails for a bit more clearance , the lower hole in the frame pic was welded up later because the gpz motor doesn't have the side mounts
  • kenty
Re: my z650 rebuild
18 Sep 2010 09:46
#399609
so i decieded the frame was complete and after blasting it clean at work it was ready for paint , you may notice some other frame mods , ill tell you about those later
  • kenty
Re: my z650 rebuild
18 Sep 2010 09:50
#399610
time for a breather ,, the colour was a badly mixed shade of kawa green that was just on the shelf , i dont think ill have much trouble finding my bike in the parking lot tho
  • kenty
Re: my z650 rebuild
18 Sep 2010 16:53
#399718
i decieded to use usd forks off a TL1000 but these are a bit short to bolt straight on and i couldnt afford any stepped yokes so i did something a little different . i got a spare bottom yoke and cut the lock stops and stem off flush
  • kenty
Re: my z650 rebuild
18 Sep 2010 16:55
#399720
then i flipped it over in the mill and set about thinning it out
  • kenty
Re: my z650 rebuild
18 Sep 2010 16:59
#399722
you might wonder where this is going , my idea was the botton yoke is much thicker than the original and with the lower side machined to sit over the top bearing the forks can be pushed through the yokes and still be gripped by the same amount as the original top yoke
  • kenty
Re: my z650 rebuild
18 Sep 2010 17:04
#399724
i didnt take too much off at first but i tried em on the bike and the idea works a treat so i thinned the yoke down to the same thickness as the original and due to the size of the yoke i've gained over an inch in fork length
  • kenty
Re: my z650 rebuild
18 Sep 2010 17:07
#399725
i cut the stem off so i had a ready made spacer to machine to machine to fit the top of the TL stem , i also cut some flats to mount the ktm risers onto
