1977 KZ1000 new life
  • porchev914
  • porchev914's Avatar
Re: 1977 KZ1000 new life
17 Sep 2010 13:33
#399359
I can see where your concern would be OMR; just looking at it, it seems it may not be braced well enough yet. At the same time, the mount design is identical to a stock sportbike shock mount with the exception of the lever being longer which is what I think you're concerned about. Also a consideration are rslingshots mount thicknesses- they are signifigantly thicker and wider than most of use are using, giving them much increased flexural/torsional/tensile strength. That said, I was more cautious in my design like OMR was and braced the hell out of my shock mount :laugh:
FRANKEN Z!
  • rslingshot
  • rslingshot's Avatar Topic Author
17 Sep 2010 15:52
#399385
Old Man Rock wrote:
Hmmm... I don't know about those upper mono brackets being enough guys... One good jolt (road pot hole) and you'll know for sure.... :blink:
"T" cross member with vertical support to top mount...
I went through the same debate... Went with additional support and I've had no issues... Nor have I had a shock rammed up my booty.... :blink: :S
Ugly, possibly... Have to relocate electrical panel and electronics including battery cage, Yup but strong as hell... No booty shock :woohoo: B)
3 Axis Support...
Without a doubt I need to brace the top shock mounts. I will make some gussets out of 3/16 plate. The bottom one I will tie into the lower frame rail also with a flat plate. As far as the electronics haven't got that far yet, but I don't see any major problems (I hope)
  • rslingshot
18 Sep 2010 10:22
#399617
porchev914 wrote:
I had thought about doing it the way you went, but in the end I decided it was more pleasing to my eye, and gave me the most room for electrical stuff for the down tube to follow the contour of the sidecover
Ya I like that but what is the rod end for if the other end is welded?
  • porchev914
18 Sep 2010 12:56
#399654
Very observant! I still need to cut the top of the subframe off and make mounts so the subframe will be removable B)
FRANKEN Z!
  • rslingshot
21 Sep 2010 16:58
#400682
Been a little lazy the last few days,but I got some work done today.
I made some gussets from 3/16 flate plate and braced the monoshock mount, finished relocating all the side cover mounts and started capping the frame where the subframe use to mount. I like the look that it has now with the new subframe,it looks more up to date (I think).
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
22 Sep 2010 13:54
#400930
ah,more pics man!
:laugh:
  • rslingshot
23 Sep 2010 17:21 - 23 Sep 2010 17:41
#401279
Started building my swingarm today. The material is 6061 t6 extruded aluminum 1.625 X 3.250 with a .188 wall with a center rib and a .375 outside corner rad. I am going to use Hayabusa bearings in the pivot tube and make some bronze bushings to fit the axle, the reason for this is I have many sets of Busa bearings and most of my jig fixtures are set up for Busa's or GSX-R 1000's, it makes life easyer.
Started with the pivot tube 2.00 o.d .375 wall, quick skim cut and bore the bearing holes.
Then the swingarm sides, ruff cut the length, layout taper cut,cut them out preheat and weld them back up.
The key to a good aluminum weld is clean clean clean. I always preheat aluminum when welding it keeps you from having cold starts and cracking. Once you found that sweet spot lock it in and rock and roll. You can tell the difference between the left leg and the right one, the left one is off but once you get it dialed in your good to go.
If I dont get too busy tomorrow I will try to get the ends of the arm cut and make some fixtures for my jig, I don't have any for a 240 arm.
I have to say that I am in no way saying this is the only way to build a swingarm. That is not my intention, there are a lot of ways to do something this is just my way. If you can get an idea or you have an idea good let me know, again this is just the way I DO IT!. If you are or somebody you know is building a swingarm be real sure its right because bad things happen when stuff breaks at 100mph.
Last edit: 23 Sep 2010 17:41 by rslingshot.
  • 9am53
  • 9am53's Avatar
  • homebrew, and some bbq
23 Sep 2010 17:57
#401291
that paint is gonna be nice.
  • rslingshot
24 Sep 2010 04:05
#401362
I'm not keeping that paint,thats just some body work that I had. I hope your kidding!
  • 9am53
  • 9am53's Avatar
24 Sep 2010 04:29
#401364
no, I actually like the yellow purple and black scheme...it's different
  • rslingshot
24 Sep 2010 10:07
#401411
if you have a good tail section and side covers I will trade if you want. I'm just going to paint them.
  • Nelson
  • Nelson's Avatar
24 Sep 2010 22:04
#401558
well I'm impressed. Any of you guys build entire frames from scratch? Seems like you're not too far from that now.
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
