1977 KZ1000 new life
  • rslingshot
  • rslingshot's Avatar Topic Author
13 Aug 2010 19:16 - 13 Aug 2010 19:46
#390747
It started life as a 1977 KZ1000 but as you can see it is far from that now. I have all the body parts and a few motors that I have had for a long time, And now I am tired of it sitting there doing nothing, so now I guess it is time to do something with it. My youth in side me says slam it ,stretch it ,and strut it but the wiser man inside says monoshock it,a little lower , a little longer but with style.
Last edit: 13 Aug 2010 19:46 by rslingshot.
  • donthekawguy
  • donthekawguy's Avatar
Re: 1977 KZ1000 new life
13 Aug 2010 20:37
#390770
I like the long low look myself. Mono shock and usd forks are always cool on an old bike.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
14 Aug 2010 02:42
#390793
I second Don....and if you ever decide to move the bike along to a new owner...it'll sell a lot quicker and for more money with a monoshock. Once you make any permanent mods to the frame geometry, it is a slippery slope...but then I'm sort of a purist. :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • rslingshot
14 Aug 2010 13:43 - 14 Aug 2010 13:43
#390867
Put some work in friday night and about 6hrs today. Friday night went ahead and cut the damaged lower frame/motor mount out,and some of the sub frame.Then I made a new lower frame/motor mount and an upper cross bar for the monoshock conversion.Then I started on the side cover mounting brackets,I have to make new mounts when I rework the subframe.Saturday I started deseaming the tank and finished the gas cap conversion. I had to finish this first because the guy who does my body work is moving at the end august. Deseaming the tank took some time because you have to make sure there is no leaks,its alot of work but I like the look of it after it is done.After that I fixed a few broken fins on the cylinders,then sand blasted the cylinder head,cylinders,and oil pan hopefully I can get to the cases by monday.I will try to take as many pics as I can along the way but sometimes I just get cranking and forget to stop and take a pic you know how it is.
Last edit: 14 Aug 2010 13:43 by rslingshot. Reason: add pics
  • rslingshot
14 Aug 2010 13:46 - 14 Aug 2010 14:36
#390868
My daughter showed me how to upload.
Last edit: 14 Aug 2010 14:36 by rslingshot.
  • rslingshot
14 Aug 2010 14:32
#390873
Pics of the tank,and broken fin fix/sand blasted
  • Old Man Rock
  • Old Man Rock's Avatar
14 Aug 2010 17:05
#390900
Nice job on the fin repair.... B)
You obviously have the tools & skills... Sweet!
Will be following this post for sure.... ;)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • rslingshot
16 Aug 2010 16:42
#391484
Put some more time in today not much but some. Picked up some PJ-1 fast black paint tested it on the cylinders dont look to bad so I think I will go with it. Now I am waiting on my tapered bearing set for the frontend. I didn't have a good stem to use so I will have to make one so if I get the bearings in tuesday I will start on that because I need to get it rolling. I started drawing my top and bottom tripple clamps over the weekend and a kickstart block off plate.
  • trianglelaguna
  • trianglelaguna's Avatar
16 Aug 2010 18:00
#391507
sweet...what is the skinny on the pj-1 paint..any good...i like the color...nice
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • Kawickrice
  • Kawickrice's Avatar
16 Aug 2010 18:59
#391519
I like where this is going. You seem to have the tools and the knowledge to make her a sweet ride.
I was just talking to my brother tonight about mono shocking one of my bikes, probably my KZ 650. He happens to have an 86 GSXR 750 roller that would donate the parts. I just don't know if I am ready to take on another project of that magnitude just yet.
Anyways keep the pics coming as I am sure it just might motivate me. B) B)
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • PLUMMEN
  • PLUMMEN's Avatar
16 Aug 2010 19:50
#391538
  • rslingshot
17 Aug 2010 03:59 - 18 Aug 2010 18:00
#391575
Started makeing a new steering stem tonight. The one I had was bent and I did not have a extra old kz bottom clamp so I will make one. I left some stock on the top and bottom so when I cut the clamps I will be able to fit it the way I need it.
Last edit: 18 Aug 2010 18:00 by rslingshot.
