1978 z1-r
Re: 1978 z1-r
13 Sep 2010 06:02
#398189
Here's a good place to get metric stainless or chrome bolts to dress things up:
Bolts
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: 1978 z1-r
13 Sep 2010 06:22
#398192
Aasevens,
can you get a picture of the front down tubes showing how the front down tubes are overlayed with some more tubing that has been split and welded on.i have wanted to show the guys that,because it could be added into other non z1r frames when they stiffen them up with gussets.powder looks good.i know what you mean about getting one part re-done and then not wanting to put grubby pieces back next to it.keep us posted,
  • trianglelaguna
  • trianglelaguna's Avatar
Re: 1978 z1-r
13 Sep 2010 06:29
#398194
i was thinking the same thing when i saw the frame...very nice...you gotta go new look now for sure when adding parts back on...nice
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • kz1k
  • kz1k's Avatar
  • You Cant Fix Stupid!
Re: 1978 z1-r
13 Sep 2010 06:40
#398200
very nice restoration. you got my moral up for my own build.
1978 KZ1000A2
  • PLUMMEN
  • PLUMMEN's Avatar
Re: 1978 z1-r
13 Sep 2010 07:31
#398210
  • JakeB
  • JakeB's Avatar
Re: 1978 z1-r
13 Sep 2010 14:54
#398311
That freshly powdered frame sure is a familiar sight! Spend as much time as you can on it and do it right, if not you will regret it and end up redoing it anyway.
As far as price to powder a frame; I think mine was about $150 to sandblast and powdercoat it. I'm not exactly sure because I did a bunch of other parts at the same time and he never really told me what he charged for each piece.
Lookin' good! B)
1978 Z1-R
  • MFolks
  • MFolks's Avatar
Re: 1978 z1-r
13 Sep 2010 15:09
#398315
If you want to prevent scratches when installing the engine,rags and heavy layers of tape help a lot.
Also keep in mind that powder coating is an insulator, so take a tap (M6x1.0) and clean out the many holes where ground wires will go.
The Negative(-) battery terminal post will connect to the engine mounting bolt, I'd say remove the powder coating in this area down to bare metal and to prevent rusting, use a very thin coat of the silver anti-seize.
I use anti-seize on axles and bolts I plan on removing in the future.
  • asevans
  • asevans's Avatar Topic Author
Re: 1978 z1-r
14 Sep 2010 11:10 - 14 Sep 2010 11:20
#398656
to have the frame and all the other parts blasted and coated it cost $230. i was pleasantly surprised. thats not bad.
1976 kz900 Mostly stock
1978 Z1-R Project
Last edit: 14 Sep 2010 11:20 by asevans.
  • asevans
Re: 1978 z1-r
19 Sep 2010 15:08
#400068
Leon,
Shoot man i just realized you wanted me to take a picture of something.
Well here is where i am now. got some stuff back on.
1978 Z1-R Project
  • asevans
Re: 1978 z1-r
19 Sep 2010 15:14
#400069
I wanted to get the rear wheel painted and back on so i can have a roller but ran into a little problem.
Thats two bolts broke off. drilled the one that was broke off closest to the wheel and i just cant get it out. i doubt it has ever been off before. just look at the rear rotor.
So i dont know. maybe somebody has an idea?
1978 Z1-R Project
  • asevans
Re: 1978 z1-r
19 Sep 2010 15:19
#400071
1978 Z1-R Project
  • z1kzonly
  • z1kzonly's Avatar
Re: 1978 z1-r
19 Sep 2010 17:30
#400118
Soak with "PB Blaster"!
Heat with a hand held propane torch, soak again.
Be patient! Let soak overnight.
If you have to, use a drill press and drill out and heli-coil them.
