1978 z1-r
  • asevans
  • asevans's Avatar Topic Author
Re: 1978 z1-r
15 Aug 2010 19:11
#391124
Thanx Jake. ill check your project out. Whats the title?
1976 kz900 Mostly stock
1978 Z1-R Project
  • JakeB
  • JakeB's Avatar
Re: 1978 z1-r
15 Aug 2010 20:01
#391141
No problem, you will need to remove the bearings before powder coating. The grease would drip out and ruin the finish when they bake the powder. Replace the bearings with new ones, Z1E has them here. After leaving them in the freezer over night I just gently tapped the new bearings in using a socket as a driver. I've also heard that some people press them in using a piece of all-thread and some nuts and washers.
My project thread is "78 Z1R Winter Project" located here.
Good luck!
1978 Z1-R
  • asevans
Re: 1978 z1-r
15 Aug 2010 20:04
#391143
ahh yes. sorry Jake, i watched your project as you were doing it. nice job. your thread is what got me fired up about mine. what you did is exactly what i want to do to mine. mines in a little worse shape though. ive been meaning to go back and look more closely at what you did. Glad you chimed in and reminded me.
1978 Z1-R Project
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: 1978 z1-r
16 Aug 2010 07:13
#391235
good work getting it all apart.
you won't be disappointed in the powdercoated frame.i would really like to pull mine down and pc the frame.can't go wrong following Jakeb's thread he sure did a nice job on his.
keep us posted,we need more z1r threads :) .
  • PLUMMEN
  • PLUMMEN's Avatar
Re: 1978 z1-r
16 Aug 2010 07:19
#391237
testarossa wrote:
Cool project. As for the swingarm bearings, I believe that there is a special tool made for pulling them. I got mine out by hammering them from the opposite side. I ruined a socket extension in the process.
spend $20 and have a machine shop or welding shop press em out for ya B)
  • PLUMMEN
  • PLUMMEN's Avatar
Re: 1978 z1-r
16 Aug 2010 07:21
#391238
just remember once you powder coat a frame its very hard to fix screw ups and rock chips,unlike paint which is easy to have fixed B)
  • asevans
Re: 1978 z1-r
23 Aug 2010 12:00
#393244
oouch.. thats going to cost me..... i think it was already broke.....just glued together or something. i noticed it was cracked and just touched it and wham.... its the left side
1978 Z1-R Project
Re: 1978 z1-r
23 Aug 2010 12:46
#393250
asevans wrote:
...think it was already broke.....just glued together or something. i noticed it was cracked and just touched it and wham.... its the left side
:unsure: Left side what?
Good Fortune! :)
  • 531blackbanshee
  • Vendor
  • Vendor
Re: 1978 z1-r
23 Aug 2010 12:57
#393254
fairing/headlight bracket.
sudco did have em.
  • 531blackbanshee
  • Vendor
  • Vendor
Re: 1978 z1-r
23 Aug 2010 13:44 - 23 Aug 2010 13:48
#393259
i just called sudco and they said that they are discontinued.that sucks cause i need the right side .
hth,
Last edit: 23 Aug 2010 13:48 by 531blackbanshee.
Re: 1978 z1-r
23 Aug 2010 14:19
#393265
:unsure: Repair by welding isn't feasible??
Might check current availability with Bike Bandit where these parts are listed.
Good Fortune! :)
  • muddy1
  • muddy1's Avatar
  • 1980 Kz1000 LTD B4
Re: 1978 z1-r
23 Aug 2010 15:49
#393283
If you are to use "Bike Bandit" call them before you "buy" anything, I was able to add several items to my cart, checkout, pay, etc...only to find out the part is not in their inventory..
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
