1978 z1-r
Re: 1978 z1-r
23 Aug 2010 16:03
Patton wrote:
Just noticed the chart shows QTY 0 and that there's a "blank" space under Availability, for every part listed in this chart.
Not seeing it on ebay either.
The search continues.
- otakar
Re: 1978 z1-r
23 Aug 2010 16:07 - 23 Aug 2010 16:11
I did have luck fixing those in the past. You can email me or PM me. Last time they were available from SUDCO they were $288, and that was about 4 years ago.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 23 Aug 2010 16:11 by otakar.
- asevans
Re: 1978 z1-r
25 Aug 2010 13:34
Sudco doesnt make them anymore. redline cycle can get them from Japan for $250.
Leon if your interested we can split a set or i can sell you my extra right side when i order the set.
1976 kz900 Mostly stock
1978 Z1-R Project
1978 Z1-R Project
Re: 1978 z1-r
26 Aug 2010 07:22
i'm in!
you have a pm.
you have a pm.
- asevans
Re: 1978 z1-r
02 Sep 2010 12:13
ok got a question. How do you get this race off the stem? Ive got new tapered bearings for the front end. its strange because at the top of the shaft it protrudes out and gets thicker. do you have to cut it or just beat the hell out of it? got all the other bearing races off. this is the last one.
by the way i sent the frame and swingarm and other pieces to the shop to get coated. should have them back by the end of the week. ill post pics of course we it get it back.
thnax
Aaron
thnax
Aaron
1978 Z1-R Project
1978 Z1-R Project
Re: 1978 z1-r
02 Sep 2010 13:12
you can try to carefully get a chisel in there and knock it off.i use a cutoff wheel on a die grinder and carefully cut a slice(like if you were trying to cut the remaining part into a c shape)until it is thin and then use a chisel to break it then it comes off easier.hth,
- MFolks
Re: 1978 z1-r
02 Sep 2010 13:55
The race was probably installed hot and shrunk in place. I'd do it like Leon said, with a die grinder and cutoff wheel.
- asevans
Re: 1978 z1-r
12 Sep 2010 22:43
alright quick update.
got the frame and parts back friday. while i was waiting put in new fork seals. that was interesting. after much research on this site i came up with the old broom stick and electric impact method. after a couple hours i finally figured it out.
also put new tapered stearing stem bearings in and new swing arm bearings in.
ive been painting parts and im almost ready to get the front forks and wheel back on.
heres a few pics of the powder coat.
1978 Z1-R Project
1978 Z1-R Project
- asevans
- asevans
- asevans
Re: 1978 z1-r
12 Sep 2010 22:51
ok figured out how to post several pics.
yeah when i first seen my frame sitting there in the shop i had a huge smile on my face. it is pretty awesome. i cant believe how nice it turned out. im afraid to even touch it. the only bad part about having your frame powder coated is, now i feel like every piece i put on the bike has to be brand new and shiny.
1978 Z1-R Project
1978 Z1-R Project
- camaroguy
Re: 1978 z1-r
13 Sep 2010 03:03
dont get to carried away with the might as well phase. next thing you know your budget build gets out of hand.what does it run to powder a frame?
