gpz 1100
- porchev914
Re: gpz 1100
08 Jan 2011 10:46
The bike looks sweet! I like how the gsxr1k front looks. Did you paint a chrome kerker? It looks like a chrome mufflers a couple posts back.
FRANKEN Z!
- mark1122
- Keep twisting it
Re: gpz 1100
08 Jan 2011 11:03
camaroguy wrote:
she looks pretty good. I'm not sure about the silver swing arm though, since everything else is black, it looks out of place.
maybee try putting some black electrical tape on it, then stand back and take a pic. that way u can look at it both ways side by side ??
Well its been awhile since ive posted any updates. got the painting pretty close to done and now im laying out the stripes.looking at where ive got them just wondering if they look proportioned?also color looks slightly off?opinions please.strips are just scotch taped on ther plan is to get it alyed out and then clear over them[IMG] i469.photobucket.com/albums/rr57/serviceman08/001-2.jpg[/IMG
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- kz1k
- You Cant Fix Stupid!
Re: gpz 1100
08 Jan 2011 11:09
looking good, man the front and rear really make it. the swing arm really has a nice style to it too.
1978 KZ1000A2
- Marneman
Re: gpz 1100
08 Jan 2011 12:41
She looks sweet! Great job
77 KZ1000-A1 "Bushido" Project
82 KZ1000 LTD "Terri Lee"
You know what, I don't have a one to some other number of douche-bag scale. So.. Six!
- camaroguy
Re: gpz 1100
09 Jan 2011 03:52
Adam, yes thats the same pipe.ihad it ceramic coated.they sandblast it then stick it in this big vat of little balls to clean it inside and out then bake the coating on in oven.as far as swing arm color I was torn between the black finish and the stock looking zrx finish.its all powdered so ill probably leave it like this.still have to finish up brake lines and get my electronic guages.keeping a look out for a decent set of shocks for the rear.I did bid on a set of old fox shocks on e bay but went wayy over my price range.anybody got any good candidates laying around let me know.I found decent 83 GPZ head to replace the stock im running right now.just want to ride it awhile before aI tear the top end off it.cant wait to ride this thing.my daily ride is getting tired.
- camaroguy
Re: gpz 1100
09 Jan 2011 15:14
Not a good day in the garage. started wet sanding the painted parts to get real flat to put graphics on. burned thru the clear.can I just spot it with more base and then clear the whole thing or do I need to 400 sand and start all over?dont really want to start over but if thats what it takes?dumd a&* rookie mistake
- testarossa
Re: gpz 1100
09 Jan 2011 16:50
Wow, I just did the same thing last week on my bike. How far into the color did you get? Is it lighter, starting to see primer? I don't know how you could spot it and not have a line. If you have the paint, you're best bet would be to scuff it all and re-shoot the whole thing in color and clear over that. I feel your pain. I was going through all the same scenarios in my head last week. In the end you just have to suck it up an fix it right. Hopefully someone with more experience will chime in soon.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- porchev914
Re: gpz 1100
09 Jan 2011 20:34
Is the red just a straight base color, or is it metallic or pearl? What size is the spot you burned through? If you just barely broke through, you can get away with reshooting the clear over the entire tank. If it's a larger spot or it looks like you went through the base coat quite a bit, then you'll need to shoot some color. If it is a solid red and you feel comfortable with your spray gun management, you can just paint the area that you burned through and blend the color into the surrounding area, then clear the whole tank. If you are remotely apprehensive about blending a spot repair, it's better to shoot color over the entire tank and then clear.
FRANKEN Z!
- camaroguy
Re: gpz 1100
10 Jan 2011 02:52
thanks, looks like il reshoot the whole thing. like I said im a rookie and dont trust I would make it look right.man it was looking so good just before my sand paper started to get color on it.oh well.went ahead and practiced my buffing snyway.looks so good to bad i screwed it up.
- porchev914
Re: gpz 1100
10 Jan 2011 12:22
Don't beat yourself up over it. If you've never painted before, it's alot harder than most people realize. I was thinking about it last night, and I can't ever remember a time that I really recleared a spot I burned through with shooting color color first. Your instinct is right to reshoot color and clear over the whole tank. That will give you your best finished product.
FRANKEN Z!
- camaroguy
Re: gpz 1100
06 Feb 2011 12:05
Finally got the painting done and the bike reassembled with the exception of my crap rear caliper. had the wiring all put together and bike was real rough at idle. checked some of the threads on ignition set ups and found advance mechanism was seized. cleaned everthing and put back together.also at the suggestion of a bud shortened my plug wires and redid the cap ends.did all this and started bike seemed to run alot better. still a little popping on idle but decided probably goo enough to road test.yeee haaa this thing is really sweet at about 1/4 to 3/4 throttle.pulls front wheel easily in first 2 gears.I think the pilot jet needs fattened up just a little.that and a combo of the old stock ignition.which is on my want list replacing it with dyna.to fully complete will need to get guages mounted and replace rear caliper. also just today got a pair of zrx shocks coming.Ill post some more pics when I get the shocks. overall very pleased with almost final completion of bike.thanks all members for inspiration and this very cool web site to search just about any issue ive been faced with.
- testarossa
Re: gpz 1100
06 Feb 2011 12:10
Wow, that's awesome. Seems like all the projects are falling like dominoes. Can't wait to see the pictures.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
