KZ 900 TRANSFORMATION CONT. SEGMENT # 1
- scooterG
- scooterG
- scooterG
- scooterG
- scooterG
- scooterG
Re: KZ 900 TRANSFORMATION CONT. SEGMENT # 1
22 Apr 2010 09:38
Don't know if you can see it but the motor mount is welded onto the top of that collar on one end. So remove the collar and issue develops with mount:(
- porchev914
22 Apr 2010 11:51
Relax scooter, I don't believe its as big a deal as you're thinking it is. Leave the welded collars alone, they're not hurting anything and can stay. In fact, if you add to or remove and replace those tabs for the shock mount, it wouldn't hurt to extend the tab reinforcements with them
FRANKEN Z!
- scooterG
23 Apr 2010 08:11
Sorry, not sure I get what you mean.
At any rate you don't see any harm/danger in attaching new shock mount to those collars...right?
What's that tiny tab on the other side of the cross bar for? The one that appears to be close to center.
- testarossa
23 Apr 2010 09:54
I believe that the small tab is for the centerstand return spring.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- porchev914
23 Apr 2010 11:29
Testarrosa is correct, the small centered tab is the centerstand return spring. When I referenced extending the tab reinforcement, I was talking about the "collars" the tabs are welded to. If it were me (and it will be in couple weeks) I would extend the collar a little more on the outside. This will reinforce the tabs you're going to add on the outside of the original tabs to beef them up. Is that any clearer?
FRANKEN Z!
- scooterG
02 May 2010 11:23
As I stated before the swing arm I have is a 02 ninja zx6r. I'm wondering if I'm thinking clearly about this?
It would appear that the dog bone linkage is slightly offset from center the way the swing arm is made. I've decided I'm knocking off the center stand tabs and will be fabricating new beefier mounts for the linkage to attach to frame. OMR stresses having the rear tire dead on center for good reasons. Because of that I've been assuming my linkage was going to attach dead center of the frame. That's a misconception isn't it? Can my linkage attach slightly off center? Say like a half inch? Or do I need to go get a different swing arm? I'm assuming as long as I can get this 02 I have to fit into the frame by slowly grinding each side of the inside frame welded pivot bolt spacers (like OMR demonstrates in his thread) that I'll be able to center the tire afterwords. I just need to make sure I'm understanding the dynamics here...how critical of an issue is the placement of the linkage to frame location in a safety/performance point of view?
- porchev914
02 May 2010 11:47
It's quite possible that the linkage/shock is offset a little from centerline. Is it an issue? I don't think it is. As long as the linkage is square to the frame, the shock's stroke is square to the swingarm and the shock is centered with the linkage, everything should work just like it's supposed to. But where are the pics? I think you'd get alot more help if you provided some visual info scooter
FRANKEN Z!
