KZ 900 TRANSFORMATION CONT. SEGMENT # 1
  • scooterG
  • scooterG's Avatar Topic Author
29 Mar 2010 21:38 - 30 Mar 2010 09:39
#357111
the questions begin...
vimeo.com/10526900
OK..sorry about that being locked/private.
Give it a look now, thanks
Last edit: 30 Mar 2010 09:39 by scooterG.
  • porchev914
  • porchev914's Avatar
Re: KZ 900 TRANSFORMATION CONT. SEGMENT # 1
29 Mar 2010 21:54
#357119
It seems to be a private video scooter....
FRANKEN Z!
  • trianglelaguna
  • trianglelaguna's Avatar
30 Mar 2010 03:19
#357136
try a few pics and a story line to get us seeing your build and where your heading...peace craig
also update yr signiture in your profile info to list your bike and info like we have,,,
it'll then show up each time you post...see my info below
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • scooterG
30 Mar 2010 09:06
#357186
sorry about that...I think I've gone "public" now
  • scooterG
30 Mar 2010 09:09
#357187
I'll work on those suggestions, thanks.
In the mean time did you see this? vimeo.com/10510901
  • porchev914
30 Mar 2010 23:09
#357374
You sir have quite a few questions. The video is a cool way to show what you intend to do and point out your issues. Now, to some of your questions.
Starting at the front, the tab on the front of the steering stem is the original steering lock. While it can be removed, you may wish to utilize it for a steering stop. The sheetmetal bracing on the down tubes below the neck is important. I personaly would not remove it, and in fact, I suggest you add bracing to the frame. When you're ready, we will supply you with frame bracing information. The tabs behind the lower rear motor mount were originally for your center stand. You can remove those, but I would wait to see if you can use them to connect your shock linkage to it. Yes, you will have to fabricate a mount for the top of the shock in the open area behind the carbs. The original top shock mounts can go, as well as the bracing around them. The frame in this area is no longer supporting the load of the rear suspension. The tail bracket removal is your decision. If you remove them, you'll need to figure out how to bolt the tail back on, provided you are keeping the stock tail piece. Of course, these are just my opinions, and many others will weigh in with theirs ;)
FRANKEN Z!
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
31 Mar 2010 06:17
#357411
Wellcome to kzrider.
Unfortunatly i cant view your post from work, its blocked. could u post a pic and add questions here?
U seem to have 3 post for this topic?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • porchev914
01 Apr 2010 12:28
#357718
Hey Mark, scooter was essentially asking what he could or could not cut off the frame, asking about bracing and the mono shock upper mount. He needs some guidance through the beginning of his build
FRANKEN Z!
  • scooterG
02 Apr 2010 08:22
#357935
FrankenZ: Thanks! I may have missed it but you didn't mention the lower shock mounts...I assume they and the two tubes that form a triangle in conjunction with the frame tube (third side of said triangle) can go...? It's the part that I comment on in the vid as having to go so the new swingarm can fit into position...
  • porchev914
02 Apr 2010 08:40
#357937
You're right scooter, I didn't. What you are refering to as the lower shock mounts are actually the passenger footpeg supports and exhaust/chain roller mounts. I believe you will need to remove these tubing sections to fit your swingarm. I know mine had to be cut off to fit mine, but I'm also reconfiguring my subframe :silly: You'll just need to figure out how to mount your exhaust and passenger pegs with the new swingarm. Its not a big deal, it just adds to your to-do list ;)
FRANKEN Z!
  • testarossa
  • testarossa's Avatar
02 Apr 2010 09:08
#357938
Welcome scooter. Looks like you are off to a good start. Thought that I would send you a couple of pics to help answer some of your questions in the video. Here's what I did for a steering stop:
Upper monoshock mount:
You can just about see my lower shock linkage mount in this picture. I can get a better pic for you if you need it. Basically you need to mount it on that lower crossmember where your centerstand tabs are. Porchev is right here. Leave those tabs on until you know where your mounts will be. Heck maybe you can reuse them.
You can also see one of my gussets in that picture. I have lots of frame brace pictures in my build thread. We also have some good reading for you when you are ready to dive into frame bracing.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • scooterG
04 Apr 2010 08:01
#358339
testarossa: Thanks for the pics! Huge help! fork stop...am I seeing that right? You knocked off the original on your frame then fabed a new one that lines up to engage the stop knobs (?) on your upper triple tree. Were those knobs there originally? Did you fab that triple tree or add the knobs to it? I was thinking my tree was made of something that couldn't be welded....?
frankenZ: Thanks for clarifying and educating me:) I'm thinking I may not be needing rear pegs in the end...may go with a solo seat configuration
