'78 KZ1000 makeover
  • porchev914
  • porchev914's Avatar Topic Author
Re: '78 KZ1000 makeover
01 May 2010 14:14
#364754
I'm fairly confident I will have an overall net loss in weight for the machine. While the stock swingarm and wheel set is heavy, the single sided swingarm isn't exactly light weight either. I still need to weigh the stock front end and the GSXR front end for a comparison, as well as the Triumph rear wheel.
FRANKEN Z!
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
01 May 2010 15:36
#364770
Just to put in my $.02 -
The cross bracing is probably overkill but if you're talented enough to do it - why not? It looks cool and will provide at least as much added rigidity if not more than the standard single brace.
Every ounce is critical in serious racing where less is more, but in the real world I don't think you'd ever notice the difference in weight - probably not in frame stiffness either - so whatever you want is just fine. :) Here's what a professional shop did to my MKII frame back in the early 80's:
The Kaw List:
  • porchev914
01 May 2010 21:19
#364876
My sentiments exactly!
FRANKEN Z!
  • porchev914
23 May 2010 13:06 - 23 May 2010 13:08
#370213
Soooo, minor setback last night. I had loaded a bunch of tools (including my welder) into my truck and headed out to my fathers old place to fix a few things. It was a long day and I didn't pack everything back into the bed as carefully as I should have. I was 80 miles into my return trip home at 11:30 pm and this guy pulls up beside me on the freeway and starts honking and pointing at the ground. I think he's a nut and ignore him. I've got my wife and 3 girls sleeping, and I'm leary of a stranger honking and telling me to pull over at midnight on a SoCal freeway. Eventually, I roll down my window (he was persistant) and he yells that I have a hose hanging down and sparking behind my truck. :angry: I knew right then what had happened. This is what happens when you don't pack your tools up right-
This is whats left of my mig gun :( So my work will slow until I can get it replaced...Those RS34's need to be cleaned and rebuilt..
FRANKEN Z!
Last edit: 23 May 2010 13:08 by porchev914.
  • camaroguy
  • camaroguy's Avatar
23 May 2010 14:30
#370242
that blows
  • Old Man Rock
  • Old Man Rock's Avatar
23 May 2010 15:24 - 23 May 2010 15:25
#370269
:pinch: :pinch: :pinch: :pinch: :ohmy: :whistle: :pinch: :pinch:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 23 May 2010 15:25 by Old Man Rock.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
23 May 2010 15:33
#370273
That sucks. luckily its a simple fix. i hope there not tooo expensive.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • testarossa
  • testarossa's Avatar
23 May 2010 17:57
#370319
Damnit! No good deed goes un-punished. I saw all of these new posts on your thread, and I thought "Cool, Adam's been busy."
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • porchev914
23 May 2010 19:00
#370338
Yup, I've been busy alright....learning a $100 lesson! :angry: I can't get too mad, I could have prevented it with 2 minutes of time and $.03 worth of zip ties :blush:
FRANKEN Z!
  • porchev914
27 May 2010 18:15
#371488
A trip to the welding shop and my bank account $112 lighter, I have a replacement Radnor mig gun. It was cheaper than the Lincoln tweco replacement gun AND heavier duty. Though I doubt it would hold up to the "drag behind the truck on the freeway" torture test the first gun failed to endure.
The repair of my toy has allowed me to contiunue the shock mount fabrication being chronicled in my Chassis thread
kzrider.com/index.php?option=com_kunena&...imitstart=300#369819
FRANKEN Z!
  • porchev914
27 May 2010 18:44
#371495
Thanks to a $20 donation I made to another member here, supercharged, I have donor aftermarket side covers.
BTW, supercharged has a very nice collection of bikes including his bad ass roots blown KZ :woohoo: I could spend hours pouring over his bikes :cheer:
The plan: to use these covers as plugs to make tooling molds and replicate these in carbon fiber. I still need to order some tooling gelcoat for the molds, and a vacuum pump :whistle: Harbor freight, here I come!
FRANKEN Z!
  • bhardy501
  • bhardy501's Avatar
27 May 2010 19:27
#371502
I hav enjoyed reading your build up so far. Lots of great info and love the porsche with the small block. Here is a pic. of my last hotrod motor in an old 78 ford truck (its a redneck thang). It was a blast to drive and before I put the 2x4 intake and scoop on it everything was under the hood. I loved the look on the kids faces driving the new mustangs when my ratty old ford 1/2 ton pick up blistered them taking off from a red light.
1980 KZ1000B LTD
