'78 KZ1000 makeover
  • Old Man Rock
  • Old Man Rock's Avatar
Re: '78 KZ1000 makeover
20 Jun 2010 09:59
#377024
Whoa... Porche I realize others may claim "No it all" mentality but I for one would sure love it....
Please provide a tutorial on the plastic molding experience, procedure, tips, chemicals etc... Way cool no doubt....;)
How sweet is this.... B)
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • PLUMMEN
  • PLUMMEN's Avatar
20 Jun 2010 10:04
#377026
porchev914 wrote:
I have been way too busy with side projects! Between the week I spent playing with my new tubing roller, and the time I've spent putting together the stuff I need to make side cover molds and vacuum bagging supplies for carbon fiber covers, I have lost sight of the main objective! I got back to the roots this afternoon and finished off the front cradle cross brace. It's not perfect, but it's close enough that with the header in place, NO ONE will ever notice.
Now the only bracing I have left to do is the steering head and rear top tube sheet bracing, with the top center to perimeter tube braces, and I'll be done with the frame. The sheet braces will be MUCH easier that that damn front "X" brace or my upper shock mount :blink:
have you tried removing the mototor with that bracing yet? B)
  • porchev914
  • porchev914's Avatar Topic Author
20 Jun 2010 10:09
#377028
Yeah, you'll need your grinder to roughen up the ABS for resin adhesion. I shattered a RF900 fairing and glassed it back together. Just make sure your fit up is good, otherwise you'll get stress cracking in the paint down the road ;)
FRANKEN Z!
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
20 Jun 2010 10:14
#377032
i dont think i will be painting it . shes been down twice already lol.
i will just patch it together on the inside and ride her into the sunset.
does it matter if i use cloth or matting? is 1 just as stong as the other??
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • porchev914
20 Jun 2010 10:16
#377034
OMR
I would be quite the fool to strut around with a "know it all" attitude. The only thing I know for sure is that I don't know much at all :laugh: I'm still gathering tools/supplies, but I'll post a new thread so you guys can follow my success and failures :laugh:
FRANKEN Z!
  • porchev914
20 Jun 2010 10:20
#377036
I used 7/8" tubing on the X brace. It clears the engine and exhaust, but I'm going to remove the engine today. I'll let you know if I have to cut out the brace Plummen :blink:
FRANKEN Z!
  • porchev914
20 Jun 2010 10:28
#377039
Cloth is definately stronger than matting. Chopped strand matting is used for "bulking" up a laminate where strength isn't as important as thickness. Use cloth ;)
FRANKEN Z!
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
20 Jun 2010 11:07
#377045
Thanks Adam.B)
Cloth it is.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • porchev914
20 Jun 2010 12:03
#377065
And when you do it Mark, orient each successive layer of cloth 45 degrees to the last one. This will criss cross the glass fibers in 4 directions instead of 2, giving you a more multidirectional strength.
FRANKEN Z!
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
20 Jun 2010 14:43
#377080
Thanks. i will be sure to get that weave oriented right.
i've have a bad weave before.:P
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • porchev914
20 Jun 2010 14:56
#377082
Continuing with the bracing, I cut and tacked the top rear down tube sheet bracing:
Next will be the neck bracing. Looking at the Sanctuary Frame pics, it looks like the neck sheet bracing is more than one dimensional. Has anyone gone to the extra effort to semi box in the neck gussets?
FRANKEN Z!
  • Chopper513
  • Chopper513's Avatar
20 Jun 2010 16:18
#377096
Hello all i am restoring a 1980 kz1000 mark2 chain drive and need someone to send me a picture of the electrical component location behind left side cover to complete the restoration process please e-mail me at [email protected] please
