'78 KZ1000 makeover
- mark1122
- Keep twisting it
Re: '78 KZ1000 makeover
20 Jun 2010 16:42
porchev914 wrote:
if i add more to mine at that same area in your pic , i would add these.
I'm not sure what u are asking?Looking at the Sanctuary Frame pics, it looks like the neck sheet bracing is +++more than one dimensional. ++++
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- mark1122
- Keep twisting it
20 Jun 2010 16:48 - 21 Jun 2010 09:04
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 21 Jun 2010 09:04 by mark1122.
- mark1122
- Keep twisting it
20 Jun 2010 16:50 - 20 Jun 2010 16:56
Plummens
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 20 Jun 2010 16:56 by mark1122.
- mark1122
- Keep twisting it
20 Jun 2010 16:52
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- porchev914
20 Jun 2010 22:18
FRANKEN Z!
- porchev914
20 Jun 2010 22:23
But instead of just welding in a flat plate, I added some more dimension to it to increase the gussets rigidity by cutting 3/4" pieces of 1" tube for the holes I drilled
FRANKEN Z!
- porchev914
20 Jun 2010 22:27
After welding in the tubes, I added a strip of 3/4" wide sheet to the open edge of the gusset. I measured the length of the curve, cut the strip and tack welded it on just one end.
Then I hammered the strip into the curve until it conformed well enought to tack up.
FRANKEN Z!
- porchev914
20 Jun 2010 22:31
Once tacked into place the edge was fully welded, from the front and back sides. Don't ask me why, I just did. The completed neck gussets:
FRANKEN Z!
- porchev914
20 Jun 2010 22:34
Here is the right neck gusset tacked in place. I used paint stripper on the neck area in stead of grinding the paint off. You can really tell the difference trying to weld to the frame when it hasn't been ground clean. I'll run a grinder along the edges prior to full welding
FRANKEN Z!
- porchev914
20 Jun 2010 22:49 - 20 Jun 2010 22:57
A shot of the neck gussets from the back.
So now the gussets may not be completely boxed, but they should offer increased rigidity over a flat plate.....I think. At least this is what the Santuary neck gussets look like, sooooo I hope those guys know what they're doing :ohmy:
FRANKEN Z!
Last edit: 20 Jun 2010 22:57 by porchev914.
- testarossa
21 Jun 2010 04:21
How thick is that neck gusset plate stock?
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- mark1122
- Keep twisting it
21 Jun 2010 05:13
Ok ,now i see what u mean. yes they did do that,except for the 3/4" pipe addition. it appears that they just have a hole.Nice touch.
I think the pipe would only need to be about an 1/8" long to provide the same strength. not sure that extra length adds extra strength.i'm not an engineer,this is just a guess.i'm not being negative bud, just talking. Great job Adam.
there is a member hear that has a press, that will cut those holes and emboss the hole at the same time, for rigidity.
i wish i had a welder, and torches,myself.
It would be great to be able to do all of this stuff myself.
Nice job.
Nice job.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
