Rear-sets used...
  • racer54
  • racer54's Avatar Topic Author
Rear-sets used...
26 Oct 2009 18:03
#329812
Lots of you guys use rear-sets when you build your bikes. I've tried searching and looking up project bikes, but frankly, it's time consuming. What I'd like to know is what rear-sets are you using? Are there any that bolt onto the stock KZ foot-peg bolts or are you drilling new holes on the frame where needed or are you bolting them onto a plate you weld onto the frame? If off a modern sportbike, which model bike are you using them off of? Seems I remember someone used some off a ZX12 and one person welded some headnuts onto the frame to use as anchors for the rear-set bolts. Having to use a linkage to hook to the shift shaft, were you able to use what came with the rear-sets off the bike or did you have to fabricate a new link-age arm? Suppose that would work the same with the brake link-age also?
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Rear-sets used...
26 Oct 2009 19:18 - 26 Oct 2009 19:19
#329851
I used Tarozzi rear sets made specifically for the Kz on both my 1000 and my 900 project. I also used head nuts on my 900 to mount the passenger pegs brackets.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 26 Oct 2009 19:19 by StreetfighterKz.
  • zippy
  • zippy's Avatar
26 Oct 2009 20:30 - 26 Oct 2009 20:31
#329861
I also went with Tarozzi rearsets. Work great and are very well built.
Last edit: 26 Oct 2009 20:31 by zippy.
  • zippy
  • zippy's Avatar
26 Oct 2009 20:31 - 26 Oct 2009 20:33
#329862
Last edit: 26 Oct 2009 20:33 by zippy.
  • zippy
  • zippy's Avatar
26 Oct 2009 20:35
#329863
and here
  • timebomb33
  • timebomb33's Avatar
26 Oct 2009 21:04
#329868
irishwillhas a couple of sets brand new still in the package or at least he did.
I THINK MY POWERBAND BROKE
  • Old Man Rock
  • Old Man Rock's Avatar
27 Oct 2009 04:58 - 27 Oct 2009 04:59
#329897
You truly only have a few choices...
As mentioned, sets designed for direct bolt on... Exceptionally good quality but expensive $400+...Ouch!
Or any used set where you fab a steel plate for direct bolt on and your set bolts onto the plate... <$100 for all.
Or you weld bolts/buts directly onto your frame...
I accomplished all for under $50 including the rear sets.
And yes, I have since corrected the reverse shifting mechanism.... :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 27 Oct 2009 04:59 by Old Man Rock.
  • Sinners Saint
  • Sinners Saint's Avatar
27 Oct 2009 11:59
#329944
I'm going to do a similar set up with some cbr 900rr rearsets. I still need the shifter side rearset though, anyone got one?
  • thane_420
  • thane_420's Avatar
27 Oct 2009 14:10
#329954
i used '01 zx12 rearsets. used stock shifter linkage
welded nuts inside of some tubing to make mounts. the brake setup is stock also
73 kz900 1075,mre clutch,race cut tranny,cams,airshift,34 flatslides, custom rear wheel
76 kz900LTD gsx-r suspension swap, mikuni 29mm smoothbores, stock engine
72 suzuki gt750 2-stroke triple
  • zippy
  • zippy's Avatar
28 Oct 2009 04:41
#330047
You can get the Tarrozi rearsets for $ 199 here.
guzzino.stores.yahoo.net/collectibles.html
  • Old Man Rock
28 Oct 2009 05:36
#330054
Zippy... eeewww nice site... saved to KZ900 favorite folders! ;) B)
Since you quoted me... I stated direct bolt on, these sets seem to me anyways would still require some modification plates to fit on the KZ series.... Easy enough...
Either way, extremely nice pricing!
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • StreetfighterKz
28 Oct 2009 07:40
#330071
www.americanclassix.com/streetfighter_general.html
Tarozzi rearsets. Direct bolt on for either the drum or disk brake models...$259.50
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
