Rear-sets used...
  • jayw704
  • jayw704's Avatar
Re: Rear-sets used...
11 Oct 2010 08:39 - 21 Oct 2010 21:35
#405949
I used zx7r rear sets I picked up for $10 bucks on ebay and drilled new holes with bolts through spacers over the top to space them away from the frame where I wanted them. The shifter side I hated the way it shifted with the linkage so I took the stock shifter chopped it to length turned it backwards and ran a bolt through (gp shift style but much more firm feel) The brake side I had to trim off some of the flare on the pedal to clear the side winder and it was a super tight fit but used all the the zx7r ms, resivour and switch. I liked the fact that I was able to place them where I wanted. I actually ended up using the stock top mounting stud and only drilling one hole. It covered up the swing arm frame bolt so they need to be removed to pull the swing arm (but how often do we need to do that)
cant find a close up on the brake side but u get the idea
1978 KZ1000
Go Loud and go fast or dont go at all!!!
Last edit: 21 Oct 2010 21:35 by jayw704.
