KZ650 Cafe' project
- Zmoto
KZ650 Cafe' project
08 Aug 2009 21:55
Hey all, thought some of you 650 fans would have a place to fill my head with ideas. I have this 1979 KZ650 that I would like to Cafe and upgrade. this might be a slow project, but it will be worth it in the end i thinkB)
this is what it looked like when i got it home
the first thing i did is go through the carbs
here's what they look like now with new 117.5 mains, air adj. Idle, and new needle and seats
While i'm going through the bike, the main thing i'm having troble with is figuring out how to do the tail section. I have already gotten rid of the crome fender. (It was damaged anyway) Does anyone now a good source for cafe' kits or parts.
- thompsonmx100
Re: KZ650 Cafe' project
08 Aug 2009 22:55
EBAY! Thats where i went for my seat. I just type in cafe under mc parts and theres a few fiberglass seats there for sale. I'm also building a cafe bike. In my own taste.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- TerryK
08 Aug 2009 23:12 - 08 Aug 2009 23:22
Some links I found:
www.caferacer.ca/caferacer_cms/index.php...s&catid=13&Itemid=23
Some inspiration for you:
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
Last edit: 08 Aug 2009 23:22 by TerryK.
- TerryK
08 Aug 2009 23:25
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- KZ250LTD
- Zmoto
09 Aug 2009 06:27
Thanks for the inspiration guys, the wheels are turning faster now. I'll try and post some progress pics in the near future. I have to get her on the operation table.
- anarki650
09 Aug 2009 08:23
I cut up a beat to hell gas tank and welded it to my stock seat pan to fab my bum stop seat, I've got some pics in the gallery for other angles and what not. Another great place I found is
www.roccitycafe.com
, he's got quite a bit there. Also check out
www.dotheton.com
for more ideas and inspiration than you can digest. Can't wait to see what you with the old girl!!!!
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
- thompsonmx100
09 Aug 2009 09:39
Not to thread jack but Terry you know benji! I love his stuff hes an artist builds some cool bikes
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- Zmoto
09 Aug 2009 12:53 - 09 Aug 2009 12:56
got the carbs installed, and she fired right up. now, about the nasty air system they have on these things. has anyone just taken a hose to connect the two together and bypass the hole thing? If i just leave it alone with nothing on the end, wont it suck air too, or does it just push air out?
Last edit: 09 Aug 2009 12:56 by Zmoto.
- thompsonmx100
09 Aug 2009 13:02
you can just disconnect the system take all the hoses off. I have some block off plates for the 750/650 that say gpz on top for sale if youre interested
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- sabell
09 Aug 2009 14:12
Yes, you can run a heater hose from port to port on the valve cover. Make sure you plug the hole in the air box if you are using it.
'78 KZ1000A2
'79 650SR
'79 650SR
- anarki650
09 Aug 2009 15:20
I've got a valve cover off a 77 b1 that doesn't have the nasty air system. It'll bolt right up and give you a cleaner look. PM me if you're interested, we can work something out.
09 Kawasaki ER6n
Omaha NE
Omaha NE
