KZ650 Cafe' project
- Zmoto
Re: KZ650 Cafe' project
16 Aug 2009 10:55 - 16 Aug 2009 10:57
I'm going to be cleaning up the look for this cafe project useing some diamond plate that I have. I love polished diamond plate and have used it on different projects that I have, so this one will be no different. Here is a mock up of the side covers that I'm making:woohoo:
Last edit: 16 Aug 2009 10:57 by Zmoto.
- Zmoto
16 Aug 2009 11:04
I found an issue with the swingarm, there is to much play in it. I have a swingarm from an 80 model, but it is just slightly wider and wont go into place. I'd like to use it because it has bearings rather than the bushing. Has anyone swaped swingarms, and is it ok for me to just put ajack in the frame and open it up just a tad (and i do mean a tad) to put the swingarm in place? You can see where i circled in the pic, where the frame is wearing out the inside of the bushing. the caps that go on the 80 swingarm will prevent this from happening.
- mzandmz
16 Aug 2009 11:06
Is that plug wire labled wrong or it it just Me? #3 on #4??
New to Family, 1979 KZ440 LTD
- Zmoto
16 Aug 2009 19:39
its a coil that was replaced. eventually i'm going to put some new coils and perty ignition wires on it
- Mark Wing
16 Aug 2009 22:58
Yorba Linda Cal.
Yorba Linda Cal.
- Zmoto
17 Aug 2009 15:10
i realized after I posted that the frame may have squished in from ovwe torqueing it from the bushings being worn out and hammered. we are only talking about maybe 1/32".
I'll tackle it next weekend and post up on it:cheer:
- Zmoto
23 Aug 2009 06:52 - 23 Aug 2009 09:41
I know this is a little slow going, but I got the swingarm in useing of all things, the scissor jack out of my car:lol:
anyway, she's back on two wheels and ready for the steering head bearing upgrade. The pic also shows you a little of the relocation of the electrical components so the side covers will fit close to the frame.
I was thinking about tire sizes. was debating spooling up a 17" wheel to the hub, would a 140 be to wide?
Last edit: 23 Aug 2009 09:41 by Zmoto.
- Zmoto
11 Oct 2009 07:33
I have been working doubles for a while and havn't had any time to work on my KZ. But since then I have been working on a seat pan and ordered the Dyna S ingition, and got some new tires. I'll be posting more pics soon:cheer:
- Zmoto
25 Oct 2009 14:03
ok, got the Dyna Ignition in and the bike runs great, however, my carbs leak at the "T" junction in the middle of carb 2&3. Anyone have a sorce that I cane replace or repair this junction?
- thompsonmx100
25 Oct 2009 14:35
do you know if there are orings on the t or not if so then you may be able to just replace the oring or maybe use some sort of sealant that is fuel proof and dab that on to seal it. just some ideas that may be cheaper than buying a tee. otherwise call z1 they probably have them
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- Zmoto
25 Oct 2009 16:06
nah, its rubber that is molded to the T itself. I looked at Z1 a while ago for this item and didn't see it. I'll look again
- thompsonmx100
25 Oct 2009 17:23
I still might use some fuel proof silicone or try ebay
1985 gpz750
Kz 650
1985 gpz750
Kz 650
