750 cafe racer
- thompsonmx100
Re: 750 cafe racer
10 Oct 2009 14:11
Terry to answer your question, no the subframe will be welded to the frame. I will probably run some wires through the frame and such I thought about maybe trying to find an aluminum one that would work. I could just weld some tabs on the frame and bolt it on. I might give it some more thought though. Damn gotta spend more time on ebay. :laugh:
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- mark1122
- Keep twisting it
Re: 750 cafe racer
10 Oct 2009 15:48
I painted mine with a rattle can. i am still feeling it out on the rd.its not bad but i'm so glad i didnt powder coat it right away. i will add some more frame braceing before i do my final paint job as well.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- thompsonmx100
Re: 750 cafe racer
10 Oct 2009 16:51
Yeah Mark I'm gonna go the same route. I'm gonna play with color combos and stuff. feel it out make sure everything is as I want it. kinda hard to go back on powdercoat.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- gpzrox
Re: 750 cafe racer
14 Oct 2009 16:08
That holes and screen thing on the starter cover, I have seen somewhere bunches of smaller holes in the front sprocket cover. Might go well with your look.
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
- thompsonmx100
Re: 750 cafe racer
14 Oct 2009 20:03
Oh yeah the sprocket cover is getting the same treatment. As well as other parts. I did the the coil brackets last night. I lightened them by 16 grams. not to bad considering they only weighed 150 grams to start with. I'm gonna do just about everything i can get a drill bit through. :laugh:
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
25 Oct 2009 17:10
Good evening. If any of ya'll have been following my threads like my differences between 82 and 85 gpz 750 motors you know that I have ran into a snag trying to put my 82 gpz 750 motor in my 85 gpz 750 frame. well I have come up with a solution I had to cut some of the case. this first pic shows the 85 motor.
If you notice on the left the mount is narrower than it is on the 82 or kz 750
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
25 Oct 2009 17:11
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
25 Oct 2009 17:12
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
25 Oct 2009 17:14
and another one. I am also making an aluminum plate for the front right hand mount as I can not use the rubber one an that side. I will finish this tomarrow.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
31 Oct 2009 20:27
Heres some pics of my progress lately. I have rebuilt my forks and painted them black. I also painted the frame and wheels white I also finished the front motor mounts mounted the the rear tire hugger. waiting on my subframe to show up. I ordered a cr 250 subframe should cut down on weight and be easier to work with.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
01 Nov 2009 18:51
Well I finished the tire hugger and threw a 15 minute paint job on it. Looks kinda cool. Not the actual color green im going for but I like the way it pops with the white.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
02 Nov 2009 16:36
mounted the rear of the tank tonite. Just made a little bracket that welds to the backbone works nice and simple. Also recieved my subframe and began removing brackets from it. Should get it mounted this week.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
