750 cafe racer
- thompsonmx100
Re: 750 cafe racer
01 Oct 2009 16:50
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
01 Oct 2009 16:54
While I was taking stuff off I made my soda blaster and cleaned my master cylinder up and my calipers. I then painted the calipers. I don't think the rattle can I used will hold up too long. I was more or less trying to see what the color would look like on the bike.
The master cylinder came out cool. I went over it with steel wool and soap. I don't know why I used soap Plummen recommened it. So feel free to chime in Plummen
It has a works racing look to it.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- mark1122
- Keep twisting it
Re: 750 cafe racer
08 Oct 2009 14:36
Great job on the project so far.
U may want to take a minuet and see what u will need to make the sprockets lined up before u finalize the shock mount and such. U will have chain to tire and frame issues to overcome, if that tire is as big as it looks. What size is it/ 180?
U will need an offset front sprocket and u may need to clearance the frame.
U could cut the frame at the cross member under the swing-arm and spread the frame. Or heat the inner frame rails and squeeze them flat on the inside with a C lamp.
U may have to turn down the sprocket hub to get the chain closer to the tire as well.
Just have a look and see where u are heading before u button her all up. U should be able to run a 520 chain if u can find a front sprocket? What size chain does it run now?
Good luck.
Good luck.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- thompsonmx100
Re: 750 cafe racer
08 Oct 2009 15:26
You bring up some valid points Mark. I will be using a 530 chain. From what I can tell with the swingarm mounted the chain slider has plenty of clearance from side to side. I want to use a 1/2 inch offset sprocket from American classix then fine tune the alignment by turning down the hub. I don't think you need to clearance the frame any. Guys are running 180 rears on these things with the stock swinger. I just hope a 1/2 inch is enough. The tire that is on that rim is actually a 190 but I do have a 180 that will probably go on it. For extra tire to chain clearance. Thanks for the compliments and comments. I enjoy reading what people think of my project. I may post some more pics tonite. I cut the subframe off
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
08 Oct 2009 17:57
well heres some pics of my frame de-bracketed and smooth. And its desubframed. Did he just de-subframed? Yes he did. did he just refer to himself in the third person? Yes he did.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
08 Oct 2009 17:58
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
08 Oct 2009 18:00
I cut the subframe off so I can build a new one. Cause with the new tank the subframe wasn't high enough on the frame. As can be seen in the other pics.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
08 Oct 2009 18:03
Now heres a couple of pics of my modified starter cover. I wanted to give it some cool retro racer look. The grill is painted the same color as the calipers. I really wanted some course brass mesh. But I was unable to find any locally. If anyone has any ideas let me know.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
08 Oct 2009 18:04
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- mark1122
- Keep twisting it
Re: 750 cafe racer
10 Oct 2009 07:16
thompsonmx100 wrote:
I dont know how wide the 750 frame is but these issues i have mentioned are all vallid with a kz1000 frame.
1/2 offset should clear the frame on a kz, but 5/8" will not. is the rim a 6" or 5.5"? what year and model?
I had to go 170 tire to gain clearance on mine. unless i was to offset the rim.
I like the starter cover. the mesh u are useing looks good to me.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- thompsonmx100
Re: 750 cafe racer
10 Oct 2009 10:24
Thanks Mark the mesh is growing on me. I might try to find a different paint. But otherwise i like it. The swingarm and rim I'm using are 2005 gsxr. its 5.5 rim now the frame is 85 so its quite different from earlier 750's I have an 82 and its 1/2 inch narrower. I dont think I'll have any clearance issues up or down like you did with yours. If I need to I will probably squeeze the frame to gain clearance. this is gonna be ridden before I Powdercoat anything. Then I will stand back every nite and drink a few of my favorite beverages and stare at it till I get it right. Then I can paint and powdercoat. keep the comments coming. I've got like 1100 views on this thread and like ten comments left. Is it cause I'm not old. I mean if OMR was building this thing ther would be a bazillion comments. :laugh: Love your work OMR got to get work now.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- TerryK
Re: 750 cafe racer
10 Oct 2009 11:06
That cover looks badass! Are you going to make the subframe removable?
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
