1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
- Marneman
Re: 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
30 Aug 2011 11:54
It's great to see you up and working on the bike again. Great track day pic too
77 KZ1000-A1 "Bushido" Project
82 KZ1000 LTD "Terri Lee"
You know what, I don't have a one to some other number of douche-bag scale. So.. Six!
- tk11b40
01 Sep 2011 03:30Thanks guys..
I have new question which I also posted in another thread on the electrical section.
Bought a new Ignition switch from Z-1 Enterprises, an EMGO 40-80600.
The new switch has a 6 pin connector, the wiring diagrams show a 4 pin, and the new harness on the bike also has a 4 pin.
The 6 pin ign. connector plugs right into the 4 pin and the wires line up correctly brown white blue, and red to brown white blue and red.
The two extra wires on the switch i do not understand what they are for.
A second White wire, and a green wire with a red stripe.
Ideas????
Suzuki GSXR 750 slabside
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- 79MKII
- Love Them Kaws!
01 Sep 2011 09:42
Buy 4 wires, get 2 free! :laugh: I've heard of these 2 versions before....hopefully somebody will chime in with an explanation. Might be OK as is but I'd hate to try it before hearing that it's OK. You could always call Jeff...he probably knows what's up with that issue.
The Kaw List:
- testarossa
01 Sep 2011 10:44 - 01 Sep 2011 10:47
I think you just plug it in and go. I stole this little tidbit from Z1E's website:
Notice what that last line says? If it were me, I would make sure the wire colors match, and maybe call Jeff to confirm function. I wouldn't blame you for being cautious of electrical stuff, given your battery issue.
EDIT: Lookin' good on the Monster. Nice to see you back on two wheels. Also, good work on the Dyna mount. Someone told me that they don't like vibes too much. You might consider putting a rubber pad in there to help dampen that a little.
Ignition Switch with 2 keys - KZ650 KZ750 KZ900 KZ1000 Z1
EM40-80600
Equivalent to OEM: 27005-086 27005-042 27005-092 - 27019-003 -
Replacement Ignition Switch for Kawasaki KZ650B/C/D KZ750B KZ750G Z1 KZ900 KZ1000A-A3/B/C/D 1976 KZ400D3. Fits both 4-pin and 6-pin connector blocks.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
Last edit: 01 Sep 2011 10:47 by testarossa.
- tk11b40
02 Sep 2011 02:38Testarossa,
Thank you for the encouraging advice, I have done just that, AND it appears the wires match perfectly, (the 4). I wish I knew what the others were there for, but guess it does not matter.
SOOOO.. big night..all the electrics are on, and I am confident after referencing the wiring diagram about 3 dozen times, I am hooked up correctlty at least enough to start it. (it ran before) but all this new stuff I had to re-check.
It still looks to be in parts and pieces, but this means the project has come to near end. The stator, regulator/ rectifier, and Dyna Ignition were the last improvements, now it's time to put it all together and ride it.
I just sat in the garage, amidst the mess, and drank a celebitory beer.
It will be a week before I ride it, but dam, there it is ALL there..just need to re-assemble for about the 40th time.
Anybody reading this needs to know there is no better place to get your parts than Z-1 Enterprises, without the stuff they carry, and knowing it's right when you order it, this thing would have been pushed over a cliff long ago..Thanks Z-1.
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
02 Sep 2011 10:16
awesome spot to be in, congratulations!!!!!!!!!!!!!!!
just sitting there looking at it,knowing that it "should run" when you set it all back together.
definitely a cool spot.
- mark1122
- Keep twisting it
02 Sep 2011 12:08u have probably already adjusted this, but i would feel bad if u hadn't, and something happened.
so dont forget to reset the rev limiter. 15000 would be hard on the valves and pistons.
i set mine as low as it would go and tested it. i could hear it work.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Prouty
02 Sep 2011 12:43
Good job Sfc. Ted! This is as good as getting back from Iraq! HoneyBadgerRacing has a new bike!
If you ain't first, you're last!
- 79MKII
- Love Them Kaws!
02 Sep 2011 13:32
Looks awesome! By the way...how do you bend your aluminum...like the 90 deg bend on your ignition mounting bracket? Looks perfect.
The Kaw List:
- tk11b40
02 Sep 2011 16:54
Thanks for the compliments!
I would be the guy who set the rev limiter too high and blew the motor first day out, when i get back in the garage that is thing 1 to do ..:blink:
Bending Aluminum...cool that you noticed.
I have some experiance with heat treating aluminum, and a little known fact is that it gets real cooperative (generally) at about 900 degrees. I warm it with a propane torch, and just tap with a dead blow, you can tell it's gonna cooperate when the "ting" sound turns into a "thud". This means the little molecule fellas are ready to party.
Problem is you can heat it too much and either just plain melt it, or make it brittle. Play around with the "ting" and "thud" method..I think you'll hear what I mean. I bent the bracket in the bench vise using this method.
Yee-haaaaaw team Honeybadger!!
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
The following user(s) said Thank You: Bad Kaw
- mtbspeedfreak
02 Sep 2011 16:58tk11b40 wrote: Yee-haaaaaw team Honeybadger!!
You should definitely name it Honeybadger!
2000 ZRX 1100
1976 KZ 900- Daily Driver
- mark1122
- Keep twisting it
02 Sep 2011 17:02
Ted, can u get enough heat out a small plumbing propane torch to get a good bend?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
