1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
Re: 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
24 Jul 2009 11:43
i just looked at some on ebay and the eye on the bottom appears to be aluminum,so they have to be attached to the chrome rod somehow(prolly threaded)maybe has a rollpin to lock them.they had to be able to assemble them so we should be able to dis-assemble them,i would think.
leon holmes
leon holmes
- tk11b40
24 Jul 2009 22:39
341 wrote:
Oh Crap the "Great one" is watching!!!:dry:
Hey Troy I'll be in the wonderful Northwest in a few weeks...
I want to see that tricked out 160!!!!!
Your blank posts are freakin' me out man. Yes I lurk. Troy341
Suzuki GSXR 750 slabside
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- 341
26 Jul 2009 06:52
Call me. August 8, 9 I'll be in Seattle for the races. Troy341
- tk11b40
26 Jul 2009 21:47
mark1122 wrote:
The Stock KZ forks are 30.5 Inches long, totally at rest on the bench, from top of tube to centerline of axle.
Now here is the freaky part, I think I have been posting 30-31 Inches on the GSXR Forks, which apparently is not correct. They are mounted on the bike, hardly any wieght on them, maybe 1/8 to 1/4 Inch compressed.
They measure 29 3/8 Inch from top of tube to centerline of axle. Sorry if I have confused anyone. The GSXR forks are no doubt somewhat stiffer on the spings, so the two should be near identical on ground clearance. I had originally used GSXR 750 forks which are an Inch or so shorter, the ground clearance did not look good, so 341 (Troy) explained the 750 clip ons are on the underside of the top plate,and the 1100 puts them on the top side of the top plate. Therby making the 1100 forks about an inch longer.
how long are your forks?
When i put the shocks into the original lower mounts(more upright), i regained the sag. the springs are not bad in the upright position(sag = 20mm), and too stiff when laid down(sag= 13mm). but i need shorter shocks or longer forks to regain the rake. the ground clearance is not bad.
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- tk11b40
26 Jul 2009 21:51
The stock KZ fork, skinny flexy spongy...all at no extra charge!!
I did not focus well so the pic is not perfect.
Any how 30.5 Inches...Measured I might add with a Scale I purchased in B.C. Canada..Just to make you Candian fellas more comfortable:laugh:
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- tk11b40
26 Jul 2009 21:56
I also took the top plate to the Bridgeport, and relieved the bottom side of in about an eight of an inch, this put the top plate an eight of an inch lower, which allowed me to pull the whole assembly down that 1/8 of an inch.
I cannot remember exactly how much ground clearance I have, I can check that next time I take the bike off the stand if you are curious.
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- tk11b40
26 Jul 2009 22:04
Ok so I am
Minus 1 inch (1 1/8 as meaured here, but I think it is loaded at least an 1/8 due to weight) with the new forks.
The top plate was releived 1/8 around the stem bolt face:
Gained an 1/8 there.
Overall the front end is approximately 7/8 " shorter than the stock set up. The stiffer spring rate of the 89 GSXR 1100 forks should take care of that.
Almost a perfect match. Lots and lots of thought went into this, I hope it helps any one thinking about doing the same thing. Upside down forks look trick, but they are typically a couple inches shorter.
I must have measured 10 sets of forks, all up side down they were all short. Troy is a GSXR NUT!! he helped me a great deal by loaning me all kinds of forks til we found what we were looking for.
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- mark1122
- Keep twisting it
27 Jul 2009 05:26
my zx9 forks are 28 3/4" long.
the rear shocks perform over bumps better in the proper upright position, due to having a better sag setting and this position, seems to return the proper spring weight and leverage that the shocks were designed for.
I think i will investigate raising the front. i thought i could have a sleeve made up, to put over the top of each fork, and into the top tree. this would allow the fork to slide up and down in the sleeve,(never reaching the top tree) then be clamped in at the right height(the sleeve would have a slit and a clamp like the tree does). does that make sense? raising the front would also add more weight to the rear to regain the proper rear spring weight.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- KawiConvert
27 Jul 2009 07:39
I don't think the sleeve would be strong enough to hold the forks. You could try to make or buy a lower top triple that already has a 7/8" drop from the top nut down to where the fork tubes are clamped. I would avoid a sleeve though if the fork tube doesn't make it into the clamp.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- 341
27 Jul 2009 16:09
Gp Suspension has extenders for the GSX-R forks
gpsuspension.com/products/newproducts_detail.php?item=1
. I bet that something like that could me machined if you wanted longer forks. All it takes is money. :laugh: Troy341
- mark1122
- Keep twisting it
27 Jul 2009 19:47
Thats interesting.
Thanks.
Thanks.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- tk11b40
28 Jul 2009 18:59
Mark,
Has roller showed up yet there in Canadaland?
You know I used to vacation in B.C. Always when crossing the border I would ask the border patrol/ mounty dude...
Will you tell my wife and daughter, "that Canada is where men are men, and wemens do what they are told?"
:laugh:
:laugh:
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
