1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
  • tk11b40
  • tk11b40's Avatar Topic Author
Re: 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
12 Aug 2009 20:08
#313511
:laugh: I pulled Ed into my office and showed him your comments...
He really liked them!!
I have the swing arm shock mounts removed (Ed did that too), so some pictures will follow in a day or so.
Gonna line up the shocks, clamp the new mounts down, pin them, then Eds buddie will weld them in place.
Suzuki GSXR 750 slabside
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
The following user(s) said Thank You: Randombeat
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
12 Aug 2009 20:19
#313514
thats great that u have pals that can help u out.B)
i'm sure it wont be long now, and u will be riding that baby.:) have u sellected a rake angle?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • tk11b40
13 Aug 2009 22:36
#313810
Soon as I get the rear shocks all cyphered, I'll Cypher the rake.
This is how I did the rear shock traingulation to make certain they are paralell, and square.
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
  • tk11b40
13 Aug 2009 23:39
#313820
Making the Mounts and then lining them up, that was plenty of work.
A good welder hates it when he gets a freaky funky set-up, cause so many people blame the welder when something gets moved all out of whack during the weld process.
In the Patternshop (yea i are a journeyman Patternmaker) we always pinned stuff that needed to stay in just the right place.
I used some 1/8" aluminum welding rod to pin the brackets into place after positioning them. A chunk of 3/8" ready rod also keeps them in place, and a set of Kant twist clamps. Now the welder has no worries.
After they are welded down, the welder just needs to melt the Aluminum rod right into the 4 holes drilled for them (the pins). I will then blend the surface, so you will never know there were pins there.
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
  • tk11b40
13 Aug 2009 23:41
#313821
The pins....
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
  • tk11b40
13 Aug 2009 23:42
#313822
Ready for welding.....:laugh: :woohoo:
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
  • tk11b40
13 Aug 2009 23:46
#313823
mark1122 wrote:
I' have gone for a few hard rides and there is NO sign of wear yet .it looks like it is going to work great . Thanks Ted.B)
Mark....
What size chain is that??
It's scarrin me!! I hope it is a 630 non o-ring, or I am looking at a new problem for my bike....
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
  • Z1109R Fin
  • Z1109R Fin's Avatar
14 Aug 2009 02:49
#313831
No worries TK. It is not vitally important to line up front and rear tires exactly spot-on. My guess is that you´ll have to move rear tire to right to make chain clearance. Lining up the chain is more important.
This is how I did my swing swap to my ´83 ELR with a ZRX1100 swing. Could give you some ideas:
kzrider.com/index.php?option=com_kunena&...w&catid=11&id=254238
Z1000R ´83...Slightly modified...
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
14 Aug 2009 06:30 - 14 Aug 2009 06:31
#313847
Yes that is a 630 non O Ring chain. what part is scarring u?
My 2 sprockets line up perfectly.
Next time i need a new chain i think i will Squeese the frame a bit more and get an O ring chain.
Now that u have welded the shock mounts on, u have selected your rake, haven’t u?
by moving the mounts forward or back u will raise or lower the rear end, thus adjusting the rake. i found that 1 inch change in rear height = about 1 * of rake change.
I tried to get my bike to sit level and the rake was about 27*. now that I have the shocks upright the rake is 22.5*. Too steep.
how did u determine where to place the upper and lower shock mounts?
Do u know what your spring rates are yet? or what kind of the shocks were used on last?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 14 Aug 2009 06:31 by mark1122.
  • tk11b40
14 Aug 2009 22:07
#314010
I'll tell you, I am thinking I'll have about .040" clearance between the frame and the chain. Yours looks about like .060".
So I am thinking while looking at the photo...crap what if thats a 520?
Now I know you have a 630, so not so worried.
The rake, now the swing arm is at Eds waiting for a tig welder. I need the wheelbase to cypher the rake.
What is the exact distance from the frame mount to the rear axle on your swing arm? with that information i could cypher the rake without my swingarm.
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
  • tk11b40
14 Aug 2009 22:17
#314014
So I am putting on the details drain tubes etc. and had to figure out a way to sanitize the float drain tubes.
I had a scrap chunk of urethane, drilled four holes in one end. 1 hole out the other.
I took a 1/8" drill and connected the four holes to the single one.
Slipped the float bowl drain tubes into the fitting, with a dab of silicone to seal it, then ran a single tube out the back, looks much nicer. B)
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
  • tk11b40
14 Aug 2009 23:39
#314018
stoppee wrote:
low siding in turn 2 Spokane Race Park
11B40...I don't want to bring this up, as this brings up a tramatic event. But all your riding years were not smooth and trouble free. As you recall, you did have problems that one day, while leading the pack of scooters down the straight stretch at SRP! A little to hot in the turn, to many hard parts on the ground, wheels up...well you can see the results! Hope you learned that some things are not ment to turn!
Ahhhh Lovely memories....
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
