1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
- tk11b40
Re: 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
21 Jun 2009 21:36 - 21 Jun 2009 21:39
Roller bearing..
I was thinking a bushing, which the longer bolt would clamp down on, the bushing would be a slip fit into a peice of round urethene. In the early 80's long travel dirt bikes used a simular deal on the lower side of the chain.
I want to make two. First one I can mail to you, then if it works (you have a running bike to try it on), I;ll make the second for me.
What do you think?
Digital speedo, I would sure like to see a photo.
This weekend I got much done, well much for me, I move slow. Being a perfectionist gets in the way of progress. I cut into the lower bosses of the foot peg bolts like you recommended, looks real tight there. That sucks cause now the powder coat...:S
I also ran some oil cooler lines. I have never been a fan of the way the Japanese do it with two herken lines rubbing parallel beside the motor, so I tried something I have not seen yet.
341 gave me an oil cooler a few years ago, thanks Troy!!
What do you think?
What do you think?
What do you think?
Suzuki GSXR 750 slabside
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Last edit: 21 Jun 2009 21:39 by tk11b40. Reason: spelling
- tk11b40
21 Jun 2009 21:40
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- tk11b40
21 Jun 2009 21:45
Calhoun !!
BTW, that is an awesome clip of the guy smokin the rear tire around the track...
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- tk11b40
22 Jun 2009 01:13
Old Man Rock wrote:
Is this the Speedo? Will she install it?
Seriously,
I have questions.
1. how do you wire the tach assuming the Vapor has one?
2. how was the quality overall?
3. have you tried their rectifier?
Seriously,
I have questions.
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- mark1122
- Keep twisting it
22 Jun 2009 05:32 - 22 Jun 2009 05:40
That bushing may work just fine Ted.i have reamed the motor mount bolt holes out to the next size.my bolt measures 9.36mm or .369". Thanks.
the oil lines look PRO!
Nice work on the clamps.
I love the Swiss cheese look.Very cool.
Do u have a Dana2000 to run the tack?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 22 Jun 2009 05:40 by mark1122.
22 Jun 2009 07:41
i also have a vapor on my z1r,it gets the tach input from either the post on the coil(i have dyna coils),or wrap the wire around the spark plug wire.i still haven't gotten mine to read completely right on the tach(it is about 1500 or 2000 off,i think)but it is just that i need to do a little more program adjustment i think.
leon holmes
leon holmes
- Calhoun
- Hayabusa= I ride to the strip club in flip flops
22 Jun 2009 13:42 - 22 Jun 2009 13:51
Vapor--
Made in the U.S.A.
I really like mine!
It has a clock and thermometer and cool blinky lights.
I hooked the Tach wire to the coil wire instead of the plug wire and it works very well.
Mine pooped out on me and they sent me a new one with no hassles.Great customer service.
It has been perfect.
You can program the yellow light as a shift light and the red one as red line. How cool is that. The backlight is white and easy to see.
I ordered a kit for the Suzuki SV650 because my front wheel is similar.It is super quick to install and calibration was not that bad either.
Made in the U.S.A.
I really like mine!
80 IT175, 84 XL200, XT250, 95 ST1100 96 xr650l (30k miles),kz1000, KX250 97'
Last and most important 93 KX500.
Last edit: 22 Jun 2009 13:51 by Calhoun.
- mark1122
- Keep twisting it
22 Jun 2009 13:50
The front end top view looks great .
Just a heads up, clear the paint on the bars for a good ground under the horn side controls, or add a horn ground.I had horn issues due to this.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- tk11b40
22 Jun 2009 22:56
mark1122 wrote:
I have not decided on ignition but the Dyna 2000 seems to be the best choice. If I use the Vapor that would seal it. no tach cables spinning around and slopping oil.
The roller should be complete by Saturday 28th. I sketched one out, and since I got no lathe in the garage, Ed the magical tool maker has graciously volunteered to make 2.
I am thinking this is the ticket, so you get to test fire it. The roller would hold up real good with a bearing, but the bushing wieghs a whole lot less, and the only thing its for is so the Nylon roller gets spun a littel instead of gouged.
the oil lines look PRO!Nice work on the clamps.
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- tk11b40
22 Jun 2009 23:01
I really really appreciate this kind of information, a photo, so i can guess about how big it is, and I was wondering about the SV 650 thing, which you answered before I even asked.
Thank you thank you.
The vapor it is. That should be about winter though, the track will no doubt reveal some gremlin i will have to chase around.
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- tk11b40
22 Jun 2009 23:08
341 wrote:
Man I am already rethinking some stuff......
I wish you was here Troy.......
I need answers Scotty answers!!!
tk11b40 wrote:I am putting th bike together for the last time,
Hahahahahahahahahahahahahahahahahahahahahahahahahahahaha
hahahahahahahahahahahahahahahahahahahahahahahahahahahaha
Phew, well, ummm, last time, last time he says, last
time, chortle, snicker, guffaw. There is no last time, you can never escape, the mod addiction has you. All is lost, give up hope now. Last time, really.
Troy341
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- mark1122
- Keep twisting it
23 Jun 2009 05:28 - 23 Jun 2009 05:29
Here are some more nice guages. Old man rock has 1 of these.
www.acewell-meter.com/c1.php
I'm looking forward to triing the roller. Thanks.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 23 Jun 2009 05:29 by mark1122.
