Modified KZ1000 Hopefully a knee-dragger project.
- mark1122
- Keep twisting it
Re: Modified KZ1000 Hopefully a knee-dragger project.
22 Mar 2009 18:02
u will be fine with the ground clearance. i have the same forks too. most guys get away with shorter forks. i have a complete zrx12 rear end.
if u want to go 200mm tire later u can get a zx7(?) rim. it is narrower in the hub and a 6" rim. if u what to go that route pm me for details.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Calhoun
- Hayabusa= I ride to the strip club in flip flops
22 Mar 2009 18:12 - 22 Mar 2009 18:37
OOooooooooooww! :woohoo: :woohoo: 200 mm tire. Tasty!
80 IT175, 84 XL200, XT250, 95 ST1100 96 xr650l (30k miles),kz1000, KX250 97'
Last and most important 93 KX500.
Last edit: 22 Mar 2009 18:37 by Calhoun.
- Calhoun
22 Mar 2009 19:29 - 22 Mar 2009 19:43
I'm thinking about a gold bass boat paint job.
Last edit: 22 Mar 2009 19:43 by Calhoun.
- mark1122
- Keep twisting it
22 Mar 2009 19:36
Calhoun wrote:
No that would be the cream filled variaty. these are just rubber.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Bad Kaw
- Flying Squirell
23 Mar 2009 19:45
Yeah, yeah. And quit freakin' about the ZX9R front-end; it'll work.
-KR
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- Old Man Rock
24 Mar 2009 04:18
200mm versus the 180mm tire width equates to 3/4 of an inch. No one will truly see the difference... Besides, what does that extra 20mm do for ya on the road...
Same time, with my 180mm tire on the 5.5" rim, tire to chain ~ 1/2 to 9/16" clearance.
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Calhoun
24 Mar 2009 17:27
O.k., new stem bearings and seals. Front end is all bolted together and she is on the ground. I have not even shortened the kickstand!
I am sure it will drop or raise with the new swing arm and rear wheel. So now for the hard part, the rear. Got a new ebc front left rotor for 85 bucks, not bad. one of mine is way the hell off. So I will get the other one and some new pads.
The 170 or 180 tire will be just fine. I don't care for really wide tires, they look cool but make some bikes hard to turn in my opinion.
- mark1122
- Keep twisting it
24 Mar 2009 17:38
Just in case u didnt know. You can straighten brake disks. set up a dial indicator and use a hammer and a block of wood. piece of cake. They are soft.mine were out .080"
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Calhoun
25 Mar 2009 14:05
One of the rotors is waaay off. Yikes! I would not know where to start from in order to straight it. But I have will feel better with new rotors and pads.
Here is my clearance type picture.
25 Mar 2009 19:36
i don't think you will have a problem with that kinda clearance once you get the pipe on just be careful on speed bumps and no offroading:laugh: you will be fine.
my.02
leon holmes
my.02
leon holmes
- mark1122
- Keep twisting it
25 Mar 2009 19:51 - 25 Mar 2009 19:52
I have no clearance problem with those same forks. Most guys run shorter forks. Very few run the zx9's.
Its the same with the turning radius. its way smaller, but u get used to it and know its limitation. No problem.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 25 Mar 2009 19:52 by mark1122.
- Calhoun
25 Mar 2009 20:42
Came up with headlight mounting and started with the key switch.I plan to put the key switch in where the zx9 switch was.I am using the stock headlight and bracket.It looks like it will come together quickly and easily. I just need a small dish shaped cover for a hold down for the switch.I need to decide where to mount the speedometer, The pick up wire is not very long so the speedo will probably end up just above the rear of the headlight. I will make a small bracket and weld it to the headlight housing. I also plan to fabricate an indicator light panel, you know turn signal-neutral-high beam.I will get some l.e.d. lights in different colors.
I also blasted and painted my switch covers. I used a flat black instead of semi gloss. Cindy, My girl, has started filling in the lettering with yellow and white and red. (There will be rear foot pegs on this bike.
I still need to make a steering stop but have not gotten a bottle of gas for the mig welder.
