my 1980 Z1R and 900 projects
  • RoyNor
  • RoyNor's Avatar
Re: my 1980 Z1R and 900 projects
01 Apr 2008 10:06
#203524
Sounds clever that one, in case you need to change something on the swing.
That s the constructors privilege, isn't it? :cheer:
Do you manage to take out that bearing without splitting the cases?
And you know what happens if you start on the engine...suddenly you have bought new parts for $$$$$$$$ :p
(that's what happens me every time)
Dial up, that's a nightmare when you are working with pictures.
I have sent you a private message regarding the triple trees. :P
  • 531blackbanshee
  • 531blackbanshee's Avatar Topic Author
  • Vendor
  • Vendor
01 Apr 2008 12:27
#203544
ah yes changeups are the fabricators privilege.i have not been able to pull the cover behind my countersprocket to see if i can get to that bearing from the outside.if it doesn't have snap rings i should be able to.i have been too busy working on other peoples stuff to work on my own.i had to go out to the shop lastnight and take the pics,while i was heating up a cr80 honda cyl.to install the sleeve.then deck the head and cyl.on a polaris,it never stops.i would not know what to do if it did.i do machine work for a couple of local shops and some independant guys,plus work a full time job 7:30-4:30 5 days a week selling forklift parts.but it keeps me outta the bar.
  • 531blackbanshee
  • Vendor
  • Vendor
01 Apr 2008 12:40
#203550
galaxian i would love to have an old 2stroke twin yamaha.rz,rd,tz,i would probably prefer a rz so i could throw one of my banshee engines in and fly down the road,legally.i have built several swingarms and a-arms for bikes and fourwheelers.i flattrack raced my banshee for 8 years and still have them to play on when i can.i still have my first 1978 kz1000 z1r that i got when i was 15.i was an idiot had it geared really low and would make hour long runs on the highway buried in redline most of the time,seven topends in about four years.what a learning curve.if you brake enough stuff you will learn how to fix it eventually.
  • PLUMMEN
  • PLUMMEN's Avatar
01 Apr 2008 12:56
#203552
yeah life is one big learning curve for most of us!many 13:1 streetbike motors way back when only to realize i could do the same thing with a bigger motor on pump gas!:( :laugh:
  • Zedone
  • Zedone's Avatar
02 Apr 2008 02:31
#203665
Hey 531blackbanshee, nice rides you have!!! Z1R looks great, your swingarm design looks real good & nice welds by the way. Is your truck a 71 or 72? I've got a 69 Chevy short fllet for hauling my bikes around. Keep us posted in the pic department, once again NICE work, regards, Doug :)
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
  • galaxian
  • galaxian's Avatar
02 Apr 2008 05:59
#203686
531BB,
i was heavily into the rd/rz for many years and have only gone back to 4 stokes about 7 years ago. I still have tons of rd parts here and there with a vsion of building an RD/TZ combo. What kind of HP are your banshee motors getting? My rd was dynoed at 47 at the wheel at one point not earth shattering but was pretty quick.
1977 KZ1000A1, 1979 KZ650 C3
  • 531blackbanshee
  • Vendor
  • Vendor
02 Apr 2008 06:36
#203695
my old stock stroke .060 over motor went 50hp.on a dynojet.that was with a flywheel that i had built a weight that weighed 11oz.and pressed and welded on.i have a +4mm stroke crank engine with stock cyls.that are ported and polished,with ram valves with tdr reeds,34mm keihin carbs,15cc combustion chambers in a cool head,teflon coated skirts,ceramic coated dome wiseco pistons that are .020 over,matched cases,pro design intake,currently have pro circuit pipes on it.i have a few different set of pipes and silencers,depending on application.i have never had the stoker motor on a dyno,although it feels healthier on the bottom and mid range and still has the topend of the other motor.i have 2 banshee's and three motors.one that i am just finishing for some asphalt drag racing locally.
here are some more pics of the z1r.
  • 531blackbanshee
  • Vendor
  • Vendor
02 Apr 2008 06:39 - 02 Apr 2008 06:40
#203696
and the swinger out of the bike.
Last edit: 02 Apr 2008 06:40 by 531blackbanshee.
  • 531blackbanshee
  • Vendor
  • Vendor
02 Apr 2008 06:42
#203697
top side.
  • 531blackbanshee
  • Vendor
  • Vendor
02 Apr 2008 06:44
#203698
  • 531blackbanshee
  • Vendor
  • Vendor
02 Apr 2008 06:45
#203699
right side.
  • 531blackbanshee
  • Vendor
  • Vendor
02 Apr 2008 06:48
#203700
last shot for now.i will post some more pics after it supports it's own weight.
