KZ1000G1 project
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: KZ1000G1 project
15 Apr 2007 05:16
#130267
Your bike is looking really nice...I like it!
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • kz1000g
  • kz1000g's Avatar
15 Apr 2007 08:07
#130310
I see you changed the head. I am thinking a lot of my problems are related to trying to use the fuel injected head with the carbs.
Your information about the cams is really food for thought :unsure:
Looks great.
Paul Sr.
kz1000g
  • pyxen
  • pyxen's Avatar
15 Apr 2007 09:44
#130335
That looks awesome!
Nice work :)
84 KZ550-F2 LTD
93 ZR550-B4
  • WISCONSINKZRACER
  • WISCONSINKZRACER's Avatar
18 Apr 2007 07:03
#131471
looks awsome, but you may want to run those oil cooler lines inbetween the carbs and over the motor to the oil cooler, even though those lines are braided, that rubber hose will melt, thats what happened to my buddys kz1000. the bike looks really nice though, keep up th good workB)
  • KZG1
  • KZG1's Avatar Topic Author
11 Apr 2008 08:06
#205688
here is an update on my KZ, did a front end and rear swap. only thing left to do is rear master cyclinder and i will be complete.....i swear
80 KZ1000G1
84 GPZ1100
Honda Trail 70
"You can't get paid if you don't go to work"
  • KZG1
11 Apr 2008 08:07
#205692
i have 3 more pics
80 KZ1000G1
84 GPZ1100
Honda Trail 70
  • KZG1
11 Apr 2008 08:10
#205694
i also think i will need some sort of sterring stabilizer
80 KZ1000G1
84 GPZ1100
Honda Trail 70
  • KZG1
11 Apr 2008 08:12
#205695
Here is a pic before i made changes, the GS is my brothers
80 KZ1000G1
84 GPZ1100
Honda Trail 70
  • solomrus
  • solomrus's Avatar
11 Apr 2008 08:33
#205699
where did your neck angle end up falling?
my guess is you're pretty close to 20 degrees, maybe between 18 and 20.
try dropping the rear a little bit to put some more rake in it. that might slow down the steering enough to avoid going with a damper.
or, if you have some room, drop the front tubes down in the clamps. or a little of both.
just my .02.
mine was sitting at 19/20 degrees with the 636 top clamp and clip ons. i put a z1000 clamp on, and i gained 2.5 more degrees because it allowed me to drop the front tubes lower. i'm kind of stuck with the ass of my bike in the air, because that's the look i want.
--r
198o kz1ooo Bravo Four
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
11 Apr 2008 08:35
#205700
nice bike,good job.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
11 Apr 2008 11:22
#205756
what front end did u use, and where did u find the headlight bracket? Very nice job.it looks killer.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • KZG1
12 Apr 2008 10:14
#205927
Hey solomus im using the Z1000 top clamp myself with the Z bar mounts. I milled off the original ignition switch housing, then made an adapter out of aluminum that mounts to the two tabs that are on the Z clamp. That way im using the orig KZ ignition and gauges.
Mark, i got the headlight bracket from Chaparral, front end is from a 04 Zx636
80 KZ1000G1
84 GPZ1100
Honda Trail 70
