KZ1000G1 project
  • KZG1
  • KZG1's Avatar Topic Author
KZ1000G1 project
13 Apr 2007 17:07
#129779
thought i would share what i have done over the winter. new rings, top end rebuild with the good stuff, some new web cams, and carbs. with new cams the engine came alive, night and day differance. just need to fix the crankcase breather leak and rivit in the new chain.
80 KZ1000G1
84 GPZ1100
Honda Trail 70
"You can't get paid if you don't go to work"
  • KZG1
Re: KZ1000G1 project
13 Apr 2007 17:10
#129781
80 KZ1000G1
84 GPZ1100
Honda Trail 70
  • KZG1
13 Apr 2007 17:20
#129784
80 KZ1000G1
84 GPZ1100
Honda Trail 70
  • KZG1
13 Apr 2007 17:20
#129785
80 KZ1000G1
84 GPZ1100
Honda Trail 70
  • KZG1
13 Apr 2007 17:22
#129787
80 KZ1000G1
84 GPZ1100
Honda Trail 70
  • KZG1
13 Apr 2007 17:23
#129788
80 KZ1000G1
84 GPZ1100
Honda Trail 70
  • KZG1
13 Apr 2007 17:43
#129793
after i got the cyclinder head back for a local machine shop, i imediatly started to put the bike together. with the new cams i used the stock sprokets,i no i should have degreed it in but i didnt. long story short, no matter how many times of timing in the cams with the timing marks, it would start. hell i thought the vale job was a total waste of money cause i bent the valves. after almost giving up and gitting my shot gun out, i tried installing the intake cam on the 29 tooth, compression was 30lbs. so i then tried on the 27th tooth and the sea parted. big time compression....its alive
80 KZ1000G1
84 GPZ1100
Honda Trail 70
  • KZG1
13 Apr 2007 17:47
#129796
i didnt change the exhaust cam at all, compression tested was 150+ in all cyclinders. i was releived
80 KZ1000G1
84 GPZ1100
Honda Trail 70
  • KZG1
13 Apr 2007 18:06
#129800
80 KZ1000G1
84 GPZ1100
Honda Trail 70
  • KZG1
13 Apr 2007 18:07
#129801
80 KZ1000G1
84 GPZ1100
Honda Trail 70
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
14 Apr 2007 12:12
#130053
Looks AWESOME!B)
By the way..."28" is the pin-count.
1977 KZ1000 A-1
  • KZG1
15 Apr 2007 05:13
#130265
thanks sandy, im aware of the timing on the 28th pin, bike wouldnt start. thats why i experimented with the 29th and then the 27th. on the 27th bike fired
80 KZ1000G1
84 GPZ1100
Honda Trail 70
