KZ1000G1 project
13 Apr 2007 17:07 #129779 by KZG1
KZ1000G1 project was created by KZG1
thought i would share what i have done over the winter. new rings, top end rebuild with the good stuff, some new web cams, and carbs. with new cams the engine came alive, night and day differance. just need to fix the crankcase breather leak and rivit in the new chain.
80 KZ1000G1
84 GPZ1100
Honda Trail 70
"You can't get paid if you don't go to work"
13 Apr 2007 17:10 #129781 by KZG1
Replied by KZG1 on topic KZ1000G1 project
80 KZ1000G1
84 GPZ1100
Honda Trail 70
13 Apr 2007 17:20 #129784 by KZG1
80 KZ1000G1
84 GPZ1100
Honda Trail 70
13 Apr 2007 17:20 #129785 by KZG1
80 KZ1000G1
84 GPZ1100
Honda Trail 70
13 Apr 2007 17:22 #129787 by KZG1
80 KZ1000G1
84 GPZ1100
Honda Trail 70
13 Apr 2007 17:23 #129788 by KZG1
80 KZ1000G1
84 GPZ1100
Honda Trail 70
13 Apr 2007 17:43 #129793 by KZG1
after i got the cyclinder head back for a local machine shop, i imediatly started to put the bike together. with the new cams i used the stock sprokets,i no i should have degreed it in but i didnt. long story short, no matter how many times of timing in the cams with the timing marks, it would start. hell i thought the vale job was a total waste of money cause i bent the valves. after almost giving up and gitting my shot gun out, i tried installing the intake cam on the 29 tooth, compression was 30lbs. so i then tried on the 27th tooth and the sea parted. big time compression....its alive
80 KZ1000G1
84 GPZ1100
Honda Trail 70
13 Apr 2007 17:47 #129796 by KZG1
i didnt change the exhaust cam at all, compression tested was 150+ in all cyclinders. i was releived
80 KZ1000G1
84 GPZ1100
Honda Trail 70
13 Apr 2007 18:06 #129800 by KZG1
80 KZ1000G1
84 GPZ1100
Honda Trail 70
13 Apr 2007 18:07 #129801 by KZG1
80 KZ1000G1
84 GPZ1100
Honda Trail 70
14 Apr 2007 12:12 #130053 by Sandy
Replied by Sandy on topic KZ1000G1 project
Looks AWESOME!B)
By the way..."28" is the pin-count.
1977 KZ1000 A-1
15 Apr 2007 05:13 #130265 by KZG1
thanks sandy, im aware of the timing on the 28th pin, bike wouldnt start. thats why i experimented with the 29th and then the 27th. on the 27th bike fired
80 KZ1000G1
84 GPZ1100
Honda Trail 70
