Engine flooding
  • kznutter
  • kznutter's Avatar Topic Author
Re: Engine flooding
30 Aug 2025 06:03
#916569
First of all, i would like to thank wookie 58 for doing the repairs to my relay. Very much appreciated.
put it all back together today, but unfortunatly it still wont start. I'm not sure what the problem is now. At first it looked promising. I heard everything click into place, but no, still struggling.  I think its getting to much fuel as it started dripping out of the drain hole in the exhaust pipe. I think the injectors are sticking open, that's my theory. It must be an ECU problem. Probably why it's been parked up all these years
So plan b it is. What is a good set of carbs for this bike, and where can I get some.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: Engine flooding
30 Aug 2025 12:47
#916583
Have you checked the resistance of the temp sensor ?
The following user(s) said Thank You: kznutter
  • kznutter
Re: Engine flooding
31 Aug 2025 01:42
#916601
Yes, i have basically checked every thing you can test and all was within speck except the relay, which you repaired. When I put it back on I could hear everything clicking into place which gave me hope. But it did the same thing, it would fire up for several seconds then stop, then nothing. I would turn the ignition on and off, and no response from the electronics. The only thing you can't test is the ecu, so it must have a fault. So I'm going to source some carbs, so I need to know what are the best. I have read that VM28 carbs are a good match.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: Engine flooding
31 Aug 2025 12:11
#916633
There are more tests you can do, if you’re interested I will send you the details
  • kznutter
Re: Engine flooding
08 Sep 2025 04:11
#916891
Sorry not been online about this problem, i had a commission that needed finishing.
Right, I have decided that the fuel injection system is coming out, and going to fit carbs. What type of carbs can i fit to this bike, and where can I get them.
  • TexasKZ
  • TexasKZ's Avatar
Re: Engine flooding
08 Sep 2025 04:20 - 08 Sep 2025 04:28
#916893
As I recall, the port spacing is the same on yours as on all other carbureted 900/1000/1100 engines, so you can fit a used set of stock BS34s or an over priced set of 29 smoothbores, or some brand new Keihin or Mikuni carbs. Webike, APE and Dynoman stock new ones.
There should be an old thread or two around here on that topic. Maybe archived???
Last edit: 08 Sep 2025 04:28 by TexasKZ.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: Engine flooding
08 Sep 2025 04:50
#916896
Also don't forget that if the injectors are mounted in the head (I don't know on your model) you will need to get some blanking plugs made up to fill the holes when the injectors are removed
  • kznutter
Re: Engine flooding
08 Sep 2025 23:45
#916927
TexasKZ, thanks for the advice, that's really helpfull, will start looking.
Wookie58, i have a plan for blanking the holes up, hopefully it will work.
Thanks for all the advice guys.
  • kznutter
Re: Engine flooding
13 Sep 2025 09:13
#917085
Howdy peeps,
took the good advice and purchased a set of BS34 carbs. They are surprisingly in very good condition, but, as to be expected, the o rings need replacing. Have looked on the Internet and can't seem.to find anyone that just sells o ring sets. Also I need to replace the intake manifolds. Any suggestions where I can find said items.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: Engine flooding
13 Sep 2025 12:16
#917093
Howdy peeps,
Member Nessism will supply quality "O" ring kits (stashed in a birthday card from the US), Z-Power in the UK will supply manifolds
  • kznutter
Re: Engine flooding
24 Sep 2025 00:23
#917573
Howdy peeps,
Just a follow up on this saga, the bike is bike running, needs a tune up, other than that, well happy.
just a question, the emissions system on it, do I need it, or can I get rid of it, also there was a slight poping coming out of carb no1. Could that be a sign of it being a bit lean or an air leak, or even that crapped out emission system.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: Engine flooding
24 Sep 2025 01:42
#917576
You can delete the emissions system (there are several posts on here relating to this)
