1977 KZ1000 Ltd
Re: 1977 KZ1000 Ltd
30 Jul 2025 06:41Am I correct in thinking it was deleted because it didn't clear the "Jardin" exhaust on the Ltd ????LTDs did not come from the factory with a center stand.
The frame does have the required mounts for one
I purchased a center stand and use it just for service
- sf4t7
Re: 1977 KZ1000 Ltd
30 Jul 2025 07:27
Mcdroid, curious to what was replaced or updated on that 77 KZ1000 cam chain issue you mentioned?
(sorry to hijack this thread)
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- Kelly E
Re: 1977 KZ1000 Ltd
30 Jul 2025 09:19
I installed an aftermarket center stand on my 77' KZ 1000LTD. I had make shims to wrap around the mounting bolts because the pivot bore ID on the stand were too big. Now it doesn't rattle. A chain drive bike with no center stand is a pain in the ass.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
1983 Honda CB 1100F
And more
Re: 1977 KZ1000 Ltd
30 Jul 2025 09:49Been to long ago to remember if Jardine's were the issue.Am I correct in thinking it was deleted because it didn't clear the "Jardin" exhaust on the Ltd ????LTDs did not come from the factory with a center stand.
Re: 1977 KZ1000 Ltd
30 Jul 2025 14:56
Yes, I think the Jardine pipes were the issue. I still have my original pipes but they aren't on the bike. I have a 4/1 and have a stop made to keep the center stand off the chain.
- Kelly E
Re: 1977 KZ1000 Ltd
30 Jul 2025 15:28
I put a Delkevik 4 into 1 on my 77' LTD. If you order the system for an A model it will come with the center stand stop. I didn't realize that the B model system doesn't come with the stop because they didn't come with the center stand. I called Delkevik because I installed a center stand and they sent me the center stand stop for free.
1983 Honda CB 1100F
And more
1983 Honda CB 1100F
And more
- Mcdroid
- Gone Kwackers
Re: 1977 KZ1000 Ltd
30 Jul 2025 16:05Not sure, that was in 1977...but I do remember the dealership stating that the rubber bits were deteriorating in the oil. The cam chain would then acquire unexpected slack rather rapidly through time. I do have some Kawasaki dealer updates from that period and I'll see if I have the one specifically about that issue. I'll let you know either way.Mcdroid, curious to what was replaced or updated on that 77 KZ1000 cam chain issue you mentioned?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
The following user(s) said Thank You: sf4t7, Gdizard
- Mcdroid
- Gone Kwackers
Re: 1977 KZ1000 Ltd
31 Jul 2025 13:27If you are a member of Kawasaki-Z-Classik.com, the specific Service Bulletin (4/1000-7) discussed the issue. The upper cam chain idler dampers were deteriorating in oil. I do not have a copy of the Service Bulletin, but it is posted in its entirety on the above site.Not sure, that was in 1977...but I do remember the dealership stating that the rubber bits were deteriorating in the oil. The cam chain would then acquire unexpected slack rather rapidly through time. I do have some Kawasaki dealer updates from that period and I'll see if I have the one specifically about that issue. I'll let you know either way.Mcdroid, curious to what was replaced or updated on that 77 KZ1000 cam chain issue you mentioned?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- sf4t7
Re: 1977 KZ1000 Ltd
31 Jul 2025 14:55 - 31 Jul 2025 15:19
Thank you Michael. I looked up the bulletin.
Not a hard update, I'll probably replace the rubber blocks just to be safe. I was afraid you were referring to the idler sprockets down in between the cylinders.
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 31 Jul 2025 15:19 by sf4t7.
