1977 KZ1000 Ltd
- pjw1960
1977 KZ1000 Ltd
29 Jul 2025 06:50
Hello,
Thank you for letting me join, I have a 1977 KZ1000 Ltd which I am gradually recommissioning after many years off the road. I have rebuilt the brakes, front and rear. Cleaned and relined the tank....cleaned out the carbs, which were minging...and now have it running on all four. Number one cylinder was reluctant to join the party but is working now.
The top end sounds a bit loud....not sure if I have a sticky valve (or valves)
Any thoughts?
Many Thanks
Peter
Any thoughts?
Many Thanks
Peter
1952 Sunbeam S8
1977 Kawasaki KZ1000 LTD
Re: 1977 KZ1000 Ltd
29 Jul 2025 09:09
Welcome from the UK Peter, where in the world are you ?
Re: 1977 KZ1000 Ltd
29 Jul 2025 09:16
My first thought would be to check cam chain tension. Check your oil for any residue that may have come from a disintegrating cam chain guide. Next, check valve clearance and timing.
- pjw1960
Re: 1977 KZ1000 Ltd
29 Jul 2025 09:31
Hello, I'm In SE London
1952 Sunbeam S8
Re: 1977 KZ1000 Ltd
29 Jul 2025 09:55I’m in Leicestershire:) Warren’s not a million miles away in KentHello, I'm In SE London
- pjw1960
Re: 1977 KZ1000 Ltd
29 Jul 2025 10:05
I’ll do the oil and filter this weekend and see what I find.
Also if you don’t mind, another question….it only has a side stand…which is a bit of a pain. Is there a reason to not have a centre stand?
cheers
p
cheers
p
1952 Sunbeam S8
- MFP-Joe
- forever 18 when on my bike
Re: 1977 KZ1000 Ltd
29 Jul 2025 10:35
Welcome also from germany.
( If the original mounting-bosses are still weldet under the frame, you just have to search for the original centerstand...?)
Greetings, Joe
The following user(s) said Thank You: pjw1960
Re: 1977 KZ1000 Ltd
30 Jul 2025 04:00
If memory is correct the LTD version came without a centerstand, but one can be installed. You will need the stand and hardware. Just be aware that the LTD is a little lower to the ground because of the 16 inch rear wheel so it's harder to put the bike on the center stand. I have the 1980 LTD. I added the sidestand.
- MFP-Joe
Re: 1977 KZ1000 Ltd
30 Jul 2025 04:19
I once had a 1977 KZ1000 LTD that I converted slightly into a cafe racer. This frame had centerstand mounts and a centerstand. But of course, I can't guarantee that it was factory-installed like that...
Greetings, Joe
Re: 1977 KZ1000 Ltd
30 Jul 2025 04:19Does the exhaust have the required clearance or does it need a little "mod" ?If memory is correct the LTD version came without a centerstand, but one can be installed. You will need the stand and hardware. Just be aware that the LTD is a little lower to the ground because of the 16 inch rear wheel so it's harder to put the bike on the center stand. I have the 1980 LTD. I added the sidestand.
- Mcdroid
- Gone Kwackers
Re: 1977 KZ1000 Ltd
30 Jul 2025 05:46Yes, pay attention to the rubber bits on the inside of the motor. If this bike has been off the road for a number of years, the previous owner may never have attended to the factory recall of 1977 KZ1000 models for replacement of internal rubber cam chain adjusters. I had a new 1977 KZ1000A1 and it would never stay in tune until a Kawasaki mechanic noted the recall and replaced the necessary bits.My first thought would be to check cam chain tension. Check your oil for any residue that may have come from a disintegrating cam chain guide. Next, check valve clearance and timing.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Re: 1977 KZ1000 Ltd
30 Jul 2025 06:26
LTDs did not come from the factory with a center stand.
The frame does have the required mounts for one
I purchased a center stand and use it just for service
The following user(s) said Thank You: MFP-Joe, pjw1960
