Old KZ, new rider
- 88kidona78
Old KZ, new rider
14 Jun 2016 20:34
:woohoo: hey all, jt here. I picked up my first bike and have put maybe 1000 miles on it since early May.
The bike is a 78 kz650sr (d1 positively) which I bought with around 12,600 miles. It came with a windscreen and some saddlebags. I've removed both for the mostly in-town riding I do but plan to utilize them later for overnight trips.
Here are some pic's of it on the trailer home here in Colorado.
From what I can tell it has aftermarket 4-1 exhaust and seat, but otherwise appears factory and untampered with. Besides seemingly neglected sitting in peoples garages, it rides like it's just gettin' broken in. Anyways, cheers!
Attachment IMAG0213.jpg not found
Attachment IMAG0214.jpg not found
JT from Colorado
First Year Rider
1978 KZ650 SR
First Year Rider
1978 KZ650 SR
Re: Old KZ, new rider
14 Jun 2016 20:38
Welcome, nice bike.
14 Jun 2016 21:08 - 14 Jun 2016 21:09
Hello, jt, and WELCOME to KZr!
Congrats on acquiring and enjoying the very nice unmolested low-mileage KZ650.
[Please check your Private Messages.]
Last edit: 14 Jun 2016 21:09 by Patton.
- Barry2
14 Jun 2016 23:58
That color is called "Candy Persimmon red" Used to have on identical to that one. Might even be the same one.
What part of the country are you in?
1976 KZ900
- ThatGPzGuy
15 Jun 2016 03:43
Welcome. Nice bike but that seat is all kinds of ugly.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- wrenchmonkey
15 Jun 2016 05:07
Welcome aboard!
Super sleek KZ you found there. Congratulations on scoring such a fine example!
- 88kidona78
15 Jun 2016 13:08Barry2 wrote: That color is called "Candy Persimmon red" Used to have on identical to that one. Might even be the same one.
I'm in Colorado, it was found in Pueblo....the tachometer doesn't work.
ThatGPzGuy wrote: Welcome. Nice bike but that seat is all kinds of ugly.
Couldn't agree more!
Thanks for the welcome, I'm excited to get goin on this thing.
JT from Colorado
First Year Rider
1978 KZ650 SR
First Year Rider
1978 KZ650 SR
15 Jun 2016 13:55
Welcome aboard! Nice bike! The tach is probably fine. It is more likely that the tach cable has a problem.
Here are some tips that you may find helpful:
Many newbies and not so newbies run into or issues with their bikes which could be easily avoided with a little preparation or information. Here are a couple recommendations that I hope you will find useful.
Before riding your KZ you should take a little time to become familiar with it. Simple things like checking the oil, tire pressures, etc. are explained in the Kawasaki Owner's Manual. If you bike didn't come with one (they normally are in a little holder on the bottom of the seat) you can usually find one on eBay - be sure to get one for your exact year/model.
MANUAL
You really should consider buying the Kawasaki Factory Service Manual for your bike. The factory service manual provides instructions on the various maintenance procedures and schedules for your bike, procedures for diagnosing problems, proper torque values for the various fasteners (VERY IMPORTANT), and insight into how each system on your bike works even if you are not repairing that system. Studying the manual before you attempt performing service on your bike will impart an understanding of the system you are working on which will increase the odds of success.
The manuals usually are readily available for most models on eBay and other sources; but be sure to get one that has your specific year and model in it as there are differences between the various KZ650 models. I do not recommend Clymers, Haynes, or other aftermarket manuals as I have seen instances where they provide inaccurate advice. You may decide to use those to supplement the factory manual, but in my opinion they are not a suitable substitute. If you have trouble finding one for your model ask us to help.
TOOLS
WARNING! Do not even try to use Phillips screwdrivers on the Kawasaki cross head screws. Despite their appearance they are not Phillips screws. They are Japanese Industrial Standard (JIS) screws. The tips of Phillips screwdrivers are too long & pointed to allow the 4 blades of the screwdriver to properly engage the screws, so when you apply force the screw head slots will deform and look like crap. The fact is that Phillips screws were deliberately designed to have the screwdriver bit "cam out." This was done to prevent production line assembly from over-tightening, stripping, or breaking the screws. JIS screws do not have this problem. A proper fitting JIS bit can tighten a JIS screw to and beyond the torque spec without camming out. Here's the good news - you can easily modify standard Phillips screwdriver tips to fit the JIS screws.
I have ground down the tips of DeWalt #2 and DeWalt #3 Phillips to make them fit JIS screws. The large crosshead screws on the cases take modified #3 bits (or genuine #3 JIS bits). To modify the DeWalt bits you need to grind the very tip a little, then test fit, then grind a little more and test fit, etc. until the bit no longer "rocks" back and forth in the screwhead. Picture 1 below shows how a DeWalt #3 bit fits the case screws of my KZ650 after being ground properly. The #2 DeWalt bits can be modified the same way to fit smaller JIS screws. Pictures 2 and 3 below shows DeWalt #2 and #3 modified bits.
I did find a place that sells authentic JIS bits. They don't list the #3 bit, but if you contact them they can provide the #3 JIS bits even though they are not listed on the website. These folks were very easy to work with, and the authentic bits do work great. Here's their site:
www.rjrcooltools.com/shop_item_detail.cfm?subcat_ID=89
Pictures 4 & 5 below show a comparison between my home made modified bits with the authentic JIS bits, and picture 6 shows a comparison between Philips and JIS bit tips.
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
PICTURE 6
Before reaching for that wrench or ratchet consider the following. The bolts are steel, but your engine and front forks are aluminum. The bolts are much tougher than the aluminum and if over tightened will strip the aluminum threads. Although these can be repaired, preventing damage by applying proper torque will save you grief, time, and money. Tightening fasteners properly requires torque wrenches. Various vendors, including Snap-on, CDI, Sears, etc., market torque wrenches. The two most popular types are the bar type and micrometer type. Either will work, but the micrometer type is a bit easier to use, especially if you are tightening several fasteners with the same torque - such as cylinder head covers. You will need a torque wrench calibrated in INCH POUNDS for many of the bolts. You will also need a torque wrench calibrated in FOOT POUNDS for the larger bolts. Don't try to use the foot pounds wrench on the smaller bolts as it will not be sensitive enough at low torque settings to provide accurate torque. There are many fasteners that require low torque. These include such things as 6mm oil pan bolts, cylinder head cover bolts, etc. for which the torque in 61-78 inch pounds. These low torque bolts require a wrench that is accurate at low settings and this wrench should be graduated in inch pounds. In addition, there are numerous high torque fasteners such as the front axle nuts (51 - 65 foot pounds) or swing arm pivot shaft nuts (58 - 87 foot pounds). These require a wrench that is accurate at higher settings; this wrench should be graduated in foot pounds. Using the proper torque wrenches to correctly tighten fasteners will help prevent damage and contribute to a safe bike. The Kawasaki Service Manual will list the various torque specs for the bolts. I suggest you get the manual before buying the torque wrenches so you can decide which wrenches best meet the torque specs.
Consider buying a can of Kroil penetrating oil and use it to soak stubborn fasteners for a couple days before trying to loosen them. Remember, the original screws and bolts were installed on your bike when Jimmy Carter was President, so many of them may be hard to remove. Kroil can be bought online, at guns shows, and at some other venues.
MOTOR OIL
The ingredients in oils have changed over the years. For example, today's Castrol GTX oil (and pretty much all other AUTOMOBILE oil) is not the same as it was in the 1980's. Back then it worked great in KZ bikes. But, things have changed. Early AUTOMOBILE oils contained zinc phosphorus compounds (ZDDP) to protect engine components from metal to metal contact. This was good for engines, but it was found to be destructive to catalytic converters. Consequently, in AUTOMOBILE oils ZDDP was virtually eliminated and replaced with different chemistry generically referred to as "Friction Modifiers." These work fine and offer good protection for normal AUTOMOBILE engines. However, today's AUTOMOBILE oil "Friction Modifiers" are destructive to wet clutches. KZ bikes (and many other brands) have wet clutches. As a result of these oil chemistry changes a distinction needed to be made between those oils which are suitable for wet clutches and those which are not. That distinction was documented by the Japanese Engine Oil Standards Implementation Panel (JASO). JASO developed a number of different oil specifications for different applications. The specifications that apply to 4 stroke motorcycles fall under the "4T Specifications." Within the 4T specifications the JASO MA class oils are specifically formulated for 4 stroke motorcycles with wet clutches.
There are synthetic, semi-synthetic, and non-synthetic oils that meet the JASO-MA standard and any of them will work ok. However, using oils that are not designated as meeting the JASO-MA standard is destructive to KZ clutches.
Good luck with your bike. Ed
MANUAL
TOOLS
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
PICTURE 6
Attachment JISvs.PhillipsAngles-2-3-4.jpg not found
MOTOR OIL
15 Jun 2016 14:45 - 15 Jun 2016 14:46
Last edit: 15 Jun 2016 14:46 by SWest. Reason: sp
- 88kidona78
16 Jun 2016 12:51 - 16 Jun 2016 12:53
That's excellent knowledge, thank you. I will definitely be paying attention to what oil goes in next service (it was changed and is fresh with previous owner) and I was certainly thinking about using an impact driver while reading that, haha.
Now, the tachometer is certainly faulty. I bought a cable since it was originally missing. I cleaned the inputs and the readings I was getting were pretty wonky. So I pulled it apart and found the mount was broken, which increased clearance from the magnet so it wasn't really making contact...upon further inspection found the internal spring had snapped and twisted around itself.
Now I'm in the market for a new tachometer. My local junkyard couldn't find one.. Besides that, the tank is trash; rusted all to hell.
Minor grime
The outside of the tank - which happened while unloading from the trailer
Minor grime
Attachment IMAG0309.jpg not found
Attachment IMAG0335.jpg not found
JT from Colorado
First Year Rider
1978 KZ650 SR
First Year Rider
1978 KZ650 SR
Last edit: 16 Jun 2016 12:53 by 88kidona78. Reason: missed pic
