New member Bobber build
- Spratz
06 Nov 2015 15:50 - 06 Nov 2015 15:55
Well this is my first time posting. I recently picked up a 1978 Kawasaki KZ650C it is my first KZ i have ever owned and the first bobber build i have ever attempted. The couple questions I have are the ignition key does any company make a replacement that I can mount else wear (I am removing the Speedo and tac Assembly) Has anyone had any luck with the air intake box removal and replacement with pod filters? Forward controls were can I get some that doesn't cost hundreds of dollars. I think that's about it for right now.
And if anyone needs stock 1978 KZ650 parts let me know what you need i might be willing to part with some. Bars, shocks, Guage cluster, signals ect.
Last edit: 06 Nov 2015 15:55 by Spratz.
Re: New member Bobber build
06 Nov 2015 15:55
Where are the pics?
- Spratz
06 Nov 2015 16:01
I just started the build so i havent gotten very far.
- peter1958
06 Nov 2015 16:04
:ohmy:
www.kzzone.com/
- KZB2 650
06 Nov 2015 16:11
Man That's almost too nice to cut up but to each is own..... say a prayer for Ed its gonna break his heart.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
06 Nov 2015 16:14 - 06 Nov 2015 16:16
Last edit: 06 Nov 2015 16:16 by 650ed.
- OutsiderKZ900A4
- peter1958
Re: Re:New member Bobber build
06 Nov 2015 16:28
This might help you with the carbs.
www.kzzone.com/
06 Nov 2015 17:27
Making a statement. I'm gone. :dry:
06 Nov 2015 18:26
- Zephyrrider
06 Nov 2015 19:11 - 07 Nov 2015 18:32
:evil:
Mick
1994 ZR750 Zephyr C4.
Last edit: 07 Nov 2015 18:32 by Zephyrrider.
06 Nov 2015 21:11 - 07 Nov 2015 06:29
He already cut off the rear of the frame. Be sure to weld on some cross-bracing.
DimeCityCycles may have forward controls n stuff, but I doubt that there's anything cheap there or anywhere else.
You might want to do all of the routine maintenance before spending any time or money on the extraneous stuff.
Kawasaki service manual. new battery. engine oil & oil filter. air filter. brakes. forks. etc etc etc.
PS: save the frame tail piece so the next guy can weld it back in place, but the frame is probably ruined. or someone else might could use it.
Last edit: 07 Nov 2015 06:29 by martin_csr.
