83 KZ750 out of moth balls
- trexmon
- 83 KZ750 L3
03 Nov 2015 17:07
It's been sitting in my garage for over 25 years! Got it running just banging my head against the wall trying to get carbs sorted out. Running good except won't idle or run at low RPM's. Guess I have to pull the carbs AGAIN and reclean the pilot areas.
Re: 83 KZ750 out of moth balls
03 Nov 2015 17:23
Pics of plugs?
- JR
03 Nov 2015 17:25
Welcome to the site. Looks like an L3 or 4.
Love that style and colour. Have patience with the carb. You'll get there eventually. Guitar string or nylon bristle + compressed air might help.
- trexmon
- 83 KZ750 L3
03 Nov 2015 18:07
After sitting so long rough running can be expected. Bear in mind the valve guide seals are probably hard and if not leaking, they soon will.
03 Nov 2015 18:30
This tutorial was centered on the Suzuki version of the BS CV carbs, but the Kawasaki version is almost identical. Read through and you may get some tips.
Remember: short cuts are long cuts when it comes to carbs. Biting the bullet and tearing the carbs down and doing the job right will save time in the end (although most people don't believe it until they fail a couple three times). zeus.mtsac.edu/~cliff/storage/gs/Mikuni_...Rebuild_Tutorial.pdf
- trexmon
- 83 KZ750 L3
03 Nov 2015 18:59
Great tutorial! Have 1 question. Do pilot screws need to be covered when done adjusting (after you have drilled & removed cover) and if so with what?
- mjg15
03 Nov 2015 19:05
L3 is a great bike, you are lucky to find one. Check for vacuum leaks at manifolds. Thats common after sittng so long, and don't be surprised if it springs leaks at head and base gaskets when you start running it
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- ThatGPzGuy
04 Nov 2015 01:42trexmon wrote: Great tutorial! Have 1 question. Do pilot screws need to be covered when done adjusting (after you have drilled & removed cover) and if so with what?
Nope. leave 'em.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- trexmon
- 83 KZ750 L3
04 Nov 2015 04:00
1 other unrelated question. Under the gas tank where the fuel level sensor connects there is a hose outlet. I have nothing connected to it. Where should hose run? Can't find anything in the manual.
Thanks for all the info.
04 Nov 2015 05:08trexmon wrote: 1 other unrelated question. Under the gas tank where the fuel level sensor connects there is a hose outlet. I have nothing connected to it. Where should hose run? Can't find anything in the manual.
There is a leak catcher funnel cup around the sending unit. It's there in case the sending unit seal fails so the fuel doesn't dump on top of the hot engine. You should get a long piece of hose and route it down by the rear wheel, to the side so if it were to dump it wouldn't soak your rear tire.
The following user(s) said Thank You: trexmon
- GPzMOD750
Re: Re:83 KZ750 out of moth balls
04 Nov 2015 07:43
Check your carb holders (boots) for vacuum leaks. High idle that can't be adjusted down is a classic symptom. I spray carb cleaner around the boots while it's running if the idle drops or it dies that's your issue.
