New member introduction, kz750
  • AndrewBat
  • AndrewBat's Avatar Topic Author
05 Jun 2015 07:45
#675353
Attachment image.jpg not found
Hi kzriders!
I thought id introduce myself. Im a new member who is new to the kz world. I used to own a 1972 f6 but sold it. Wasnt willing to dump money into a bike that i could t take on the highway. I just purchased a 1980 kz750 on craigslist and its being dropped off tomorrow. It runs but one cylinder is running rough some times. Since the bike was stored 2 years before i got it i assume its mostly due to bad fuel and gummed up carbs. Ill be doing an oil change, cleaning the carbs and maybe new plugs if needed.
The bike is mostly stock except for the turn signals and handle bars (from what i can tell).
  • AndrewBat
Re: New member introduction, kz750
05 Jun 2015 08:01
#675354
Also im sure i have a bad/stuck float as one carb leaks gas. Out the overflow port. So tearing out carbs is my first priority.
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Jun 2015 08:30
#675358
Welcome,
Looks like a runner. I have a thread on a 550 I picked up with the same issues. Pics as you go will help others to advise you.
05 Jun 2015 09:09
#675364
Welcome aboard!
Here are some tips that you may find helpful:
Many newbies and not so newbies run into or issues with their bikes which could be easily avoided with a little preparation or information. Here are a couple recommendations that I hope you will find useful.
Before riding your KZ you should take a little time to become familiar with it. Simple things like checking the oil, tire pressures, etc. are explained in the Kawasaki Owner's Manual. If you bike didn't come with one (they normally are in a little holder on the bottom of the seat) you can usually find one on eBay - be sure to get one for your exact year/model.
MANUAL
You really should consider buying the Kawasaki Factory Service Manual for your bike. The factory service manual provides instructions on the various maintenance procedures and schedules for your bike, procedures for diagnosing problems, proper torque values for the various fasteners (VERY IMPORTANT), and insight into how each system on your bike works even if you are not repairing that system. Studying the manual before you attempt performing service on your bike will impart an understanding of the system you are working on which will increase the odds of success.
The manuals usually are readily available for most models on eBay and other sources; but be sure to get one that has your specific year and model in it as there are differences between the various KZ650 models. I do not recommend Clymers, Haynes, or other aftermarket manuals as I have seen instances where they provide inaccurate advice. You may decide to use those to supplement the factory manual, but in my opinion they are not a suitable substitute. If you have trouble finding one for your model ask us to help.
TOOLS
WARNING! Do not even try to use Phillips screwdrivers on the Kawasaki cross head screws. Despite their appearance they are not Phillips screws. They are Japanese Industrial Standard (JIS) screws. The tips of Phillips screwdrivers are too long & pointed to allow the 4 blades of the screwdriver to properly engage the screws, so when you apply force the screw head slots will deform and look like crap. The fact is that Phillips screws were deliberately designed to have the screwdriver bit "cam out." This was done to prevent production line assembly from over-tightening, stripping, or breaking the screws. JIS screws do not have this problem. A proper fitting JIS bit can tighten a JIS screw to and beyond the torque spec without camming out. Here's the good news - you can easily modify standard Phillips screwdriver tips to fit the JIS screws.
I have ground down the tips of DeWalt #2 and DeWalt #3 Phillips to make them fit JIS screws. The large crosshead screws on the cases take modified #3 bits (or genuine #3 JIS bits). To modify the DeWalt bits you need to grind the very tip a little, then test fit, then grind a little more and test fit, etc. until the bit no longer "rocks" back and forth in the screwhead. Picture 1 below shows how a DeWalt #3 bit fits the case screws of my KZ650 after being ground properly. The #2 DeWalt bits can be modified the same way to fit smaller JIS screws. Pictures 2 and 3 below shows DeWalt #2 and #3 modified bits.
I did find a place that sells authentic JIS bits. They don't list the #3 bit, but if you contact them they can provide the #3 JIS bits even though they are not listed on the website. These folks were very easy to work with, and the authentic bits do work great. Here's their site:
www.rjrcooltools.com/shop_item_detail.cfm?subcat_ID=89
Pictures 4 & 5 below show a comparison between my home made modified bits with the authentic JIS bits.
PICTURE 1
[IMG
PICTURE 2
[IMG
PICTURE 3
[IMG
PICTURE 4
[IMG
PICTURE 5
[IMG
Before reaching for that wrench or ratchet consider the following. The bolts are steel, but your engine and front forks are aluminum. The bolts are much tougher than the aluminum and if over tightened will strip the aluminum threads. Although these can be repaired, preventing damage by applying proper torque will save you grief, time, and money. Tightening fasteners properly requires torque wrenches. Various vendors, including Snap-on, CDI, Sears, etc., market torque wrenches. The two most popular types are the bar type and micrometer type. Either will work, but the micrometer type is a bit easier to use, especially if you are tightening several fasteners with the same torque - such as cylinder head covers. You will need a torque wrench calibrated in INCH POUNDS for many of the bolts. You will also need a torque wrench calibrated in FOOT POUNDS for the larger bolts. Don't try to use the foot pounds wrench on the smaller bolts as it will not be sensitive enough at low torque settings to provide accurate torque. There are many fasteners that require low torque. These include such things as 6mm oil pan bolts, cylinder head cover bolts, etc. for which the torque in 61-78 inch pounds. These low torque bolts require a wrench that is accurate at low settings and this wrench should be graduated in inch pounds. In addition, there are numerous high torque fasteners such as the front axle nuts (51 - 65 foot pounds) or swing arm pivot shaft nuts (58 - 87 foot pounds). These require a wrench that is accurate at higher settings; this wrench should be graduated in foot pounds. Using the proper torque wrenches to correctly tighten fasteners will help prevent damage and contribute to a safe bike. The Kawasaki Service Manual will list the various torque specs for the bolts. I suggest you get the manual before buying the torque wrenches so you can decide which wrenches best meet the torque specs.
Consider buying a can of Kroil penetrating oil and use it to soak stubborn fasteners for a couple days before trying to loosen them. Remember, the original screws and bolts were installed on your bike when Jimmy Carter was President, so many of them may be hard to remove. Kroil can be bought online, at guns shows, and at some other venues.
MOTOR OIL
The ingredients in oils have changed over the years. For example, today's Castrol GTX oil (and pretty much all other AUTOMOBILE oil) is not the same as it was in the 1980's. Back then it worked great in KZ bikes. But, things have changed. Early AUTOMOBILE oils contained zinc phosphorus compounds (ZDDP) to protect engine components from metal to metal contact. This was good for engines, but it was found to be destructive to catalytic converters. Consequently, in AUTOMOBILE oils ZDDP was virtually eliminated and replaced with different chemistry generically referred to as "Friction Modifiers." These work fine and offer good protection for normal AUTOMOBILE engines. However, today's AUTOMOBILE oil "Friction Modifiers" are destructive to wet clutches. KZ bikes (and many other brands) have wet clutches. As a result of these oil chemistry changes a distinction needed to be made between those oils which are suitable for wet clutches and those which are not. That distinction was documented by the Japanese Engine Oil Standards Implementation Panel (JASO). JASO developed a number of different oil specifications for different applications. The specifications that apply to 4 stroke motorcycles fall under the "4T Specifications." Within the 4T specifications the JASO MA class oils are specifically formulated for 4 stroke motorcycles with wet clutches.
There are synthetic, semi-synthetic, and non-synthetic oils that meet the JASO-MA standard and any of them will work ok. However, using oils that are not designated as meeting the JASO-MA standard is destructive to KZ clutches.
Good luck with your bike. Ed
  • AndrewBat
05 Jun 2015 09:58
#675371
Wow thanks for all the info! I will definitely pick up a factory shop manual. Im pretty good with engines in general so im not too worried about working on the bike but im greatful for those kz specific tips. I have already picked up the parts for the oil change, and i did get an oil thats "wet cluch safe" deaigned specifically for bikes. ( i think it is made by honda).
Ill throw a few of my #3 bits on the bench grinder before i do any work on the carbs. Thanks for the warm welcome. More pics and updates to come
  • AndrewBat
05 Jun 2015 10:03
#675373
Can you elaborate on what you mean by " looks like a runner"?
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Jun 2015 10:09
#675376
Road worthy. B)
05 Jun 2015 10:16
#675379
AndrewBat wrote: ...Ill throw a few of my #3 bits on the bench grinder before i do any work on the carbs. Thanks for the warm welcome. More pics and updates to come
Here's something that helps show the difference between JIS and Phillips bits. Ed
  • AndrewBat
05 Jun 2015 10:45
#675388
Oh of course. Yeah its already drivable, just a little rough. I thought there was some carb leak problem that you were calling a runner haha. I tend to overanalize things.
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
05 Jun 2015 11:06
#675392
Nice bike Andrew. My nephew just picked up almost an exact copy of your bike last week in the Chicago area. He is enjoying it so far. Here is a link I sent him where you can download the service manual in PDF format. You will also find the wiring diagram links there as well.
www.mbsween.com/kz750l3/manual.html
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • AndrewBat
05 Jun 2015 11:46
#675393
Thanks alot!
  • AndrewBat
05 Jun 2015 11:49
#675394
Ok so ill grind away the pesky 19 defree part so its flush with the blades, not the tip
