  • Page:
  • 1
  • 2
Need recomendation for a new rear shocks! KZ750 E 29 Jul 2015 11:03 #683311
  • matigipler
  • matigipler's Avatar Topic Author
  • Thank you received: 0
Alright so i finally got my 1980 KZ750 E to run right after a while of it not running at all! im happy now its been through a cafe racer redo. but i had a problem after my first ride..... i relocated my break light right under the loop i welded in the frame. it looks neat, only problem i came back from my first right and my light was gone...... i must have hit a bump and my wheel ate the light :laugh: .
any recommendations for a harder set of rear shocks????? not looking to break the bank with high tech or anything. same height and a harder spring rate will be fine.
anything helps! thanks
Need recomendation for a new rear shocks! KZ750 E 29 Jul 2015 11:39 #683318
  • undiablo
  • undiablo's Avatar
  • Thank you received: 64
I bought 3 years ago a set of shocks from Z1Enterprises. They have a really good chrome finish and are certainly way stiffer than stock... Jeff told me they were for bigger KZ´s like 900/1000; but they fit 650/750. I ride sometimes with my brother: 110kg + 100kg = 210kg and they hold great.
Price was 89 USD by that time.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
The following user(s) said Thank You: matigipler
Need recomendation for a new rear shocks! KZ750 E 29 Jul 2015 11:45 #683321
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1630
Harley-Davidson Sportster shocks are about the same length as the 750E's.
HD oem should be ~!3.5" or so, but there are also lowering & hugger shocks which range from 10-12" in length.
You'll have to swap bushings & the bottom eye is a tad too wide for the swing arm mount, so you'll either have to spread open the mount or grind down the eye 2-4mm.
Last edit: by martin_csr.
Need recomendation for a new rear shocks! KZ750 E 31 Jul 2015 08:23 #683593
  • baldy110
  • baldy110's Avatar
  • Thank you received: 510
Replacing the shocks is not the solution to your problem. Either limit the travel of the rear wheel or re-locate the light. No matter how stiff your shocks are sooner or later you will hit a bump that again allows the rear wheel to contact the light.
Last edit: by baldy110.
Need recomendation for a new rear shocks! KZ750 E 31 Jul 2015 10:44 #683603
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2635
Or you'll need a kidney belt. :lol:
Need recomendation for a new rear shocks! KZ750 E 31 Jul 2015 11:56 #683612
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
baldy110 wrote: Replacing the shocks is not the solution to your problem. Either limit the travel of the rear wheel or re-locate the light. No matter how stiff your shocks are sooner or later you will hit a bump that again allows the rear wheel to contact the light.
This is true. Although you get shocks that have a very short travel length. I doubt you will find anything long enough with short travel unless you go custom.
Need recomendation for a new rear shocks! KZ750 E 31 Jul 2015 12:06 #683616
  • Thank you received: 2829
If the current shocks work well you may want to see if you can use longer bumpers on the shocks' shafts to limit the travel. I don't know if that's easily done, but you may be able to do it. Ed
Need recomendation for a new rear shocks! KZ750 E 31 Jul 2015 12:17 #683617
  • martin_csr
The stock shocks probably weren't that great to begin with & now they're old.
I forgot to mention that the Sportster shocks may contact the chain guard a little.
I don't think it's much of a problem, especially with a plastic chain guard.
Need recomendation for a new rear shocks! KZ750 E 31 Jul 2015 12:25 #683620
  • JR
  • JR's Avatar
  • Thank you received: 435
undiablo wrote: I bought 3 years ago a set of shocks from Z1Enterprises. They have a really good chrome finish and are certainly way stiffer than stock... Jeff told me they were for bigger KZ´s like 900/1000; but they fit 650/750. I ride sometimes with my brother: 110kg + 100kg = 210kg and they hold great.
I bought same shocks from Z1. :cheer: Good to know I'm not the only one. :) They are pretty stiff and I think they are perhaps 2or 3cm (about an inch) longer.
I found with the longer shocks I had to check chain feee play with both wheels on the ground. If I checked free play with bike on centre stand and adjusted as described in the manual then the chain was to tight when wheels hit the ground. Took me a while to figure out a strange bump bump bump noise at about 50kph
Not wishing to hijack someones thread but just something to be aware of when changing shocks
The following user(s) said Thank You: missionkz, undiablo
Need recomendation for a new rear shocks! KZ750 E 31 Jul 2015 12:30 #683622
  • SWest
  • SWest's Avatar
  • 10 22 2014
Move the light.
Need recomendation for a new rear shocks! KZ750 E 31 Jul 2015 16:26 #683649
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
swest wrote: Move the light.
HA ha.. :P sometimes the obvious solutions are, well F'n simply obvious!!
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Need recomendation for a new rear shocks! KZ750 E 31 Jul 2015 16:40 #683655
  • matigipler
im trying not to move the light. i understand its sooo ovious but if i can leave it where it is. its going to look the best. (not all about look blah blah blah).
probably gona try the kz900 shocks. the bump i hit was a rather heavy one as i didnt see it.
there are around 3 inches of travel before contact. a bump stop wouldnt be a bad idea either.
i could put the light on the license plate but im gonna leave that as a last resort.
Last edit: by matigipler.
  • Page:
  • 1
  • 2
