Hey there,
Funny enough, I guess, I
can take a picture of the white wire since it would appear our bikes may be similar; right? I have a 1000 CSR and you have a 1000 LTD. So I will lift the seat on my dusty old thang and look for the white wire to snap a pic.
You mentioned in your first post:
".... I have a white wire coming off the main fuse block that I'm not sure where it goes..."
So I assumed, this white wire was just disconnected, dangling somewhere, and would be a relatively easy fix. Maybe you can explain how this white wire is being referenced to help me understand?
Is the white wire connected to a 20 or 30 amp fuse link or no?
I personally would not go to the trouble of removing or dismantling your new ignition switch
IF you already have it installed. Again, an assumption on my part - I thought it was just hanging out somewhere as you were installing it, not bolted down etc.
I was only suggesting using the multimeter because it would be very helpful to try and figure out the switch's configuration since it
seems like perhaps the wiring into/out of it is different (still I really don't understand why a company would make such a unique part and then... make it operate differently from it's intended replacement? Wire colors aside.. I get that but changing the circuit layout into a molex connector? And then not supply a wire diagram?)
I guess, I've learned something here... Don't buy an EMGO ignition switch.
It's funny because I just bought replacement switches for KZombie and I opted for stock original ignition and seat lock with a matching key because I wanted the key to match. I considered an aftermarket ignition switch (I wanna say it was the same price or even maybe a few cents less than?) but they only had an ignition and not the seat lock so I went for the older, original, scratched and "gently used..." LOL Seems I may have unknowingly side-stepped a landmine in that decision
OK man. I'll take my phone to the ol' 1000 (BTW, I haven't done anything electrical to that bike yet. The PO had changed up alot of the wiring for headlamp, signal lamps, no tail light present, so hopefully my bike doesn't confuse the issue, I just haven't done anything with it shy of roll it around the garage floor to get it out of the way of my every increasing exploded parts view KZombie restoration.
