Jetting for stock '78 1000 02 Oct 2016 10:33 #744242
  • Mikaw
  • Mikaw's Avatar Topic Author
  • Thank you received: 1865
I'm looking for advise on main and pilot jet size. I have rebuilt the carbs and they are on the bench waiting to go back on the bike along with new manifolds. 25 years ago i remember this bike just not having the punch i thought it should have, its a bone stock '78 LTD 1000 engine with a 4 to 1 header and pods. Main jets are 105 and pilots are 15. I don't know the needle setting. My question is, should I, while they are on the bench replace the main and pilot jets.
Question 2). I know the answer to the next question about how to change the needle location (if needed), its gonna be get a FSM. At this point i don't have one so if someone would share the process I'd be very thankful.
Jetting for stock '78 1000 02 Oct 2016 11:29 #744246
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2632
You might try 117.5 mains and 17,5 pilots.
Jetting for stock '78 1000 02 Oct 2016 15:21 #744254
  • Mikaw
No disrespect Steve but I just had another suggestion from a well know carb guy and he suggested 122.5 min and leave the #15 pilot as is till the bike gets a shake down run. Your thoughts? I ask because I'd like to compare your suggestion to others. AKA pick your brain :whistle:
Jetting for stock '78 1000 02 Oct 2016 15:38 #744258
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2076
As suggested by the title of this thread, stock jetting will not work with your setup. The exact jetting you need will require a bit trial and error. The two suggestions posted above are perfectly reasonable places to start. Pick one and give it a try. You may want to put Jets r Us on speed dial.
Jetting for stock '78 1000 02 Oct 2016 15:46 #744259
  • TexasKZ
  • TexasKZ's Avatar
P.S. if you are using Emgo or Chinese filters, you might as well sign up for therapy now, because they will block the air intakes in the mouth of the carbs.
Jetting for stock '78 1000 02 Oct 2016 15:52 #744261
  • Mikaw
TexasKZ wrote: P.S. if you are using Emgo or Chinese filters, you might as well sign up for therapy now, because they will block the air intakes in the mouth of the carbs.
Yep I have already noticed that. Is it OK to cut the inner lip of the boot to clear the ports? Came with the cheepies and going to give them a try. Money is budgeted for other item right now. If they give me migraines Ill pop for real K&N :S
Jetting for stock '78 1000 02 Oct 2016 15:53 #744262
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
i was thinking the 78' KZ1000 used the same 26mm carbs my 77' has but a different needle and with leaner factory jetting?
Regardless. .., 117.5 to 120 mains and 17.5 pilot jets sounds close to me too. Especially if you are under 3500' mean sea level.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: by missionkz.
Jetting for stock '78 1000 02 Oct 2016 16:01 #744263
  • TexasKZ
  • TexasKZ's Avatar
Possibly. If you can assure a very smooth path for the air, they could work. If there is a sharp or rough transition in front of those ports, there may be too much turbulence for them to work as designed.
APE sells some high quality filters for less tha k&N.
Last edit: by TexasKZ.
Jetting for stock '78 1000 06 Oct 2016 19:49 #744654
  • Mikaw
OK, I don't see any issues with the boots blocking the air intakes but I wanted to ask the experts. I tried my best to not skew the angle of the photo to give a true representation of them
Attachment set.jpg not found
Attachment #3Carb.jpg not found
Attachment #4Carb.jpg not found
Jetting for stock '78 1000 06 Oct 2016 19:53 #744655
  • Mikaw
not sure why the other photos didnt post so ill try again
Attachment #3Carb-2.jpg not found
Attachment #4Carb-2.jpg not found
Jetting for stock '78 1000 06 Oct 2016 20:07 #744657
  • Mikaw
last try
Attachment #3Carb-2-3.jpg not found
Attachment #4Carb-2-3.jpg not found
Jetting for stock '78 1000 06 Oct 2016 20:16 #744658
  • Mikaw
Attachment IMG_0019.JPG not found
Attachment IMG_0020.JPG not found
