  • Page:
  • 1
  • 2
All in one rebuild kit? 22 Sep 2016 16:34 #743223
  • GPzMOD750
  • GPzMOD750's Avatar Topic Author
  • Thank you received: 148
I'm making plans to build up the engine for my 82 GPz750 and was wondering if anyone offers a kit with EVERYTHING needed to button it all up again. I've found gasket kits with some seals, Seal kits with no o-rings and o-ring kits that don't have the oil pan rings.
I realize i might have to bore out my sleeves so it doesn't have to have a head gasket. It would just be nice to one stop shop everything else.
And what's up with the Cometic web site? I know they have KZ head gaskets but you can't search for them. They only have a handful of dirt bikes to choose from in the drop down search menu, Very annoying.
All in one rebuild kit? 22 Sep 2016 16:41 #743224
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2723
I'm sounding like a broken record on this issue but OEM Kawasaki gaskets are the best. No comparison really. Only possible exception is viton valve stem seals. Your choice in the end though.
The following user(s) said Thank You: GPzMOD750
Last edit: by Nessism.
All in one rebuild kit? 22 Sep 2016 17:16 #743234
  • 750 R1
  • 750 R1's Avatar
  • Thank you received: 394
Nessism wrote: I'm sounding like a broken record on this issue but OEM Kawasaki gaskets are the best. No comparison really. Only possible exception is viton valve stem seals. Your choice in the end though.
I prefer MLS gaskets for the head on any bike, you must have a mirror clean surface though... They were stock on the later ZR7 which uses the same engine... Here, have a read....
kzrider.com/forum/2-engine/555522-82-gpz750-head-replacement
All in one rebuild kit? 22 Sep 2016 19:07 #743253
  • Nessism
  • Nessism's Avatar
  • Away
Fair enough.
Kawasaki evolved the head gaskets on that family of engines quite a bit from the 650 days. The version I ordered was composite, but with an RTV skin to improve sealing. MLS sounds fine. Better have good gasket surfaces though as you say.
All in one rebuild kit? 23 Sep 2016 04:30 #743286
  • GPzMOD750
Is there somewhere you can buy the complete set?
All in one rebuild kit? 23 Sep 2016 05:26 #743291
  • Nessism
  • Nessism's Avatar
  • Away
Nope. You gotta order individual parts. I look for the more expensive items, like head gaskets, on ebay and get everything else from a source like Partzilla.
All in one rebuild kit? 24 Sep 2016 06:15 #743391
  • GPzMOD750
I'm starting to look around for the parts i need.
I recall reading a while back in a thread or 2 that someone on here sold viton valve guide seals.
All in one rebuild kit? 24 Sep 2016 16:00 #743432
  • 750 R1
  • 750 R1's Avatar
Warning: Undefined variable $itemid in /home/kzride5/public_html/libraries/kunena/bbcode/bbcode.php on line 262
GPzMOD750 wrote: I'm starting to look around for the parts i need.
Viton guide seals are easy to find, try ebay... ;)
All in one rebuild kit? 25 Sep 2016 05:01 #743480
  • GPzMOD750
I'm aware of that. I was thinking that I had seen that one of the members here sold them.
All in one rebuild kit? 25 Sep 2016 05:38 #743484
  • 750 R1
  • 750 R1's Avatar
No worries, just trying to help...
All in one rebuild kit? 26 Sep 2016 05:44 #743581
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 381
DFI sells the Viton seals. He just sent me a set.
PM him.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
All in one rebuild kit? 26 Sep 2016 17:02 #743643
  • 750 R1
  • 750 R1's Avatar
ThatGPzGuy wrote: DFI sells the Viton seals. He just sent me a set.
PM him.
There should be a sticky reference thread for all this type of stuff... ;)
  • Page:
  • 1
  • 2
